Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
23 registered members (Compagnion, 3311, blufeb95, bbhero, BlakeB, 3 invisible), 965 guests, and 16 spiders.
Topics301,684
Posts5,200,468
Members70,756
NA vs EU oil spec for 1.6 ecoboost #5346419 02/10/20 04:28 PM
P
ppepitoyou Offline OP
P
My 14 fiesta st specs 5w20 oil. However, in Europe, the same car with the same exact 1.6 ecoboost engine specs 5w30. Does anyone have an opinion on what viscosity would be most beneficial for the engine?
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346439 02/10/20 04:50 PM
PimTac Offline
Similar stage name to another new member her.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346479 02/10/20 05:31 PM
B
benjy Offline
B
thats typical as in the usa $$$$ rules + manufacturers bow to what is politically correct but WRONG!!
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346531 02/10/20 06:09 PM
Marco620 Offline
My Civic is 1.8 R18 and EU spec is 0w30 or 5w30. Im now starting to run M1 0w30 and will top off with 5w30. If your Fiesta ST is the sport model and you drive it hard or plan to modify then I think a 30 wt is the way to go. If you wanted to stay w a 5w20 but wanted something stout try Redline 5w20. Its 3.0 on hths.
15' Civic 1.8 i-vtec 310,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346606 02/10/20 07:17 PM
slacktide_bitog Offline
welcome
You may be better off with 5w30, and I would probably do so if I had a turbo car. Also, you may want to use premium instead of regular gasoline.
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346621 02/10/20 07:31 PM
T
Tech819 Offline
T
I put you car in the mobil uk site and it said use 5w20 not 5w30, https://lubes.mobil.com/UK-English-LCW/carengineoils_which-oil.aspx
Same with shell Helix, https://www.shell.com/motorist/find...ZW50L2ZpZXN0YV8xXzZfc3RfdmlfRmF3RWNXRTNt
Both say you can use 5w30 as Alternative recommendations.
2017 Impreza Sport Hatch M1 0w20 OEM filter
2003 Corolla Magnatec 5w30 OEM Filter
2018 VW Golf Motul 5w40 OEM filter
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346660 02/10/20 08:10 PM
W
wdn Offline
W
In other words the recommended 5W20 is an international standard motor oil for this engine, not shadowy political subterfuge.
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346668 02/10/20 08:18 PM
R
RazorsEdge Offline
R
2015 Ford Escape 1.6 Ecoboost
We use Schaeffers 5w20 with Mobil 1 Oil filter
2cents
Schaeffer Oils 👍😎
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5346792 02/10/20 11:48 PM
U
umungus1122 Offline
U
In SoCal I'd use PP 10w-30.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'04 Crown Vic 95k Maxlife full syn 5w-20
Re: NA vs EU oil spec for 1.6 ecoboost [Re: Tech819] #5347303 02/11/20 03:23 PM
P
P
Thanks for that. I’m trying to find what I’m talking about but ford EU came out with a service bulletin after the car came out saying to run 5w30 in the engine to lower NVH. However nothing in ford North America says to run 5w30.
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5347461 02/11/20 06:09 PM
G
Gokhan Offline
G
5W-20 is a lot better than 5W-30.
5W-20 has a thicker base oil, which results in less engine wear, less VII, which results in less engine and turbocharger deposits, lower Noack, which results in less oil consumption, and lower HTHS, which results in better fuel economy.
You only need 5W-30 if you're regularly driving the car in excess of 85 mph.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 4,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: NA vs EU oil spec for 1.6 ecoboost [Re: umungus1122] #5347881 02/12/20 07:54 AM
SR5 Offline
Same here, PP 10W30 is a good oil and will work fine in a warm climate.
Still a quality 5W20 will not let the team down either.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: NA vs EU oil spec for 1.6 ecoboost [Re: Gokhan] #5347882 02/12/20 07:55 AM
W
weasley Offline
W
Originally Posted by Gokhan
[quote=ppepitoyou]5W-20 has a thicker base oil
Can you explain your thinking here?
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: NA vs EU oil spec for 1.6 ecoboost [Re: weasley] #5347887 02/12/20 08:01 AM
SR5 Offline
Oh No ! ...You have opened Pandora’s box
Re: NA vs EU oil spec for 1.6 ecoboost [Re: ppepitoyou] #5347985 02/12/20 10:07 AM
B
BMWTurboDzl Offline
B
Autobahn
435i
