Originally Posted by The Critic
Originally Posted by wemay
But after changing the oil today, I like how simple and practical it is. You can't over tighten because it has a finite number of turns then clicks into place. It comes off just as easily buy using a simple flathead screwdriver. Along with the filter topside, it makes for a clean oil change.
About the only thing that could put some off is that the engine under-tray needs to come off.
There is actually an inexpensive SST for the drain plug. While a normal flat-head screwdriver works, it does damage the plugs slightly.
https://asttool.com/detail_page.php?from_search=y&tool_number=VW10549&offset=0&stype=advanced&manf=Volkswagen,Audi&category=Oil%20Change%20Products
I keep one in my toolbox for the occasional VW I see.
I'm a total tool junkie, but I just can't bring myself to buy this tool. A 1/4" slotted screwdriver fits in there nearly perfectly. Yes, there may be some infinitesimal amount of the damage to the plastic plug, but it would almost all occur during removal--and it's a single use plug. I can't see a reason for that tool besides selling tools.
