what about Red Rubber Grease???
anyone?
anyone?
Wish I had known about the mineral oil. Just did some prep for my car as it now sits outside. Found this Superlube on Amazon and it worked well. Thicker than oil, but not super thick as a grease so it went on well. They sell it in larger containers, but I've done 2 vehicles prepping for winter both inside and outside rubber weatherstripping and still had some left over. You can see the difference it made in the photos and its still working and very water resistent. Only caveat I learned was that 'less is more'. If applied too heavily, it runs down onto the glass and smears when rained on or car is washed. Overall, I'm very pleased with it. Heck, its even food grade!!A mixture of white mineral oil and baby oil. Approx. 50:50. Apply heavy, let soak for some time - even days. Wipe off excess.
Cheapest possible material, lasts forever, protects and shines. Rubbers will never freeze on You.
Can also be used to freshen up and deep clean door sill covers made from plastic.
Markus
I used baby oil on my tonneau cover in 77. Isn’t it mineral oil?A mixture of white mineral oil and baby oil. Approx. 50:50. Apply heavy, let soak for some time - even days. Wipe off excess.
Markus
Yes....I used baby oil on my tonneau cover in 77. Isn’t it mineral oil?
Gummi Pflege Stift.What is your favorite liquid treatment for cleaning / nourishing the rubber door trim seals on your vehicles ?
Rubber is rubber. Tire dressing is fine. Meguiar's Hyper dressing at 50% strength.What is your favorite liquid treatment for cleaning / nourishing the rubber door trim seals on your vehicles ?
