Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
97 registered members (53' Stude, 4WD, Alaskanmont, 2K2AcuraTL, alarmguy, 007, 11 invisible), 1,937 guests, and 19 spiders.
Topics303,305
Posts5,233,646
Members71,038
Page 1 of 4 1 2 3 4
Michelin Introduces New "X-Ice Snow" #5346141 02/10/20 01:14 PM
SubLGT Offline OP
Michelin had a recent event in Umea, Sweden to introduce the replacement for the X-Ice Xi3 and Latitude Xi2 studless winter tires.
https://shina.guide/press/22903/#more-22903
Some excerpts from the Russian report linked above (with the help of Google Translate):
Quote
...Michelin has prepared a new generation of studless tires for cars and SUVs for the winter season 2020/2021. According to the manufacturer, the characteristics of the new Scandinavian type Michelin X-Ice Snow and Michelin X-Ice Snow SUV have significantly improved compared to the predecessor models Michelin X-Ice Xi3 and Michelin Latitude X-Ice Xi2, respectively.....
...The performance properties of the Michelin X-Ice Snow and Michelin X-Ice Snow SUV tires were honed during testing in Finnish Ivalo. The company emphasizes that their braking performance and traction during acceleration on ice and snow remain at the same level throughout the entire service life, up to a residual tread depth of 3 mm...
...But the main emphasis that was made when developing new products is longevity. On the tires of the new model, you can cover 1900 km more than on similar products Continental, Goodyear or Nokian - say Michelin....
...Michelin X-Ice Snow's internal tests were conducted at Test World in Finland, where they were compared with direct competitors Continental VikingContact 7 , Bridgestone Blizzak DM-V2 , Nokian Hakkapeliitta R3 and Goodyear UltraGrip Ice 2 . Not only new tires, but also tires with two degrees of wear were tested: after a run of 10,000 km, which corresponds to the average of one winter season, and with a residual tread depth of 4 mm (an expected result after three winter of operation)...
...According to the test results, Michelin X-Ice Snow defeated their rivals both in a new condition and in a worn out one. The only exception was the braking performance of new tires on ice, where the braking distance of the Continental VikingContact 7 was slightly less...
....But it seems that this fact does not upset the manufacturer, who notes that the advantage of X-Ice Snow over competitors increases with wear and tear, which is fully consistent with its Long Lasting Performance philosophy that its tires should remain safe, no matter how many kilometers they are have passed....
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346144 02/10/20 01:19 PM
SubLGT Offline OP
Tread design of the X-Ice Snow:
[Linked Image from shina.guide]
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346152 02/10/20 01:28 PM
O
OVERKILL Offline
O
Well now! Looks like they seriously changed up the tread design. If only they produce them in the size for my Jeep, that'd be amazing.
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346157 02/10/20 01:40 PM
dubber09 Offline
And how are they better than General Altimax Arctic 12? Or Blizzak WS90?
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346161 02/10/20 01:48 PM
K
krzyss Offline
K
General is studable winter tire so ice traction without studs will be very likely much worse than studless, especially top tier studless. Other results - tests will be needed.
Against WS90 - we need to wait for tests but it was Bridgestone doing catch up and frequently changing models (70 -> 80 -> 90) while Michelin was making Xi3 and Ix2 Lattitude during he same time frame.
Next winter customer should have broader selection of studless tires compared to this one.
Krzyƛ
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346164 02/10/20 01:50 PM
SubLGT Offline OP
https://www.vibilagare.se/nyheter/f...-nya-vinterdack-anpassat-mildare-vintrar
Quote
...- As always with Michelin, they emphasize the durability and their Long Lasting Performance philosophy that means the tire should perform well down to the last legal millimeters. This is achieved by the fact that the pattern and seams really go all the way down the tread and that the pattern opens up and becomes wider as the tire is worn....
...- The pattern is surprisingly coarse and attractive. .... The advantage of the open pattern is that it handles water and slush better than before. This is otherwise the Achilles heel with Nordic friction tires whose dense pattern is poor at evacuating water.
- In discussions with the tire designers, it appears that they have made a conscious adjustment to the increasingly wet winters with more rain and slush than white powder snow. This is what Michelin itself claims. We will of course include the new Michelin tire in our own, independent, winter tire tests that we will be doing later this winter. Then we can see how well X-Ice Snow performs against competitors on ice, snow, dry and wet. We will publish these results this fall for next winter...
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346195 02/10/20 02:09 PM
SubLGT Offline OP
https://moottori.fi/ajoneuvot/jutut/michelin-x-ice-snow-uutuusrengas/
Quote
...The Michelin X-Ice Snow will be replacing the X-Ice Xi3, which has been on sale for years, as its grip on snow and ice has been overshadowed by the latest competitors....The Michelin X-Ice Snow seeks to challenge Continental's dominating position of studless winter tires.
...Michelin promises that the novelty tire will provide 4% better grip on snow than its predecessor, and ice grip is reported to have improved by as much as 8%. There is also a clear improvement in water and slip properties...
...Economy is also likely to be better, as rolling resistance is reported to have decreased by 9%. The noise level Michelin says has stayed on the same line as its predecessor.
...The X-Ice Snow product family is sold in 123 different sizes, of which 42 are new. Of these, 82 will be on sale this year, covering 85 percent of sales; the remaining 41 sizes will be available in stores next spring.
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346212 02/10/20 02:23 PM
SubLGT Offline OP
Some more tire photos here:
http://colesa.ru/news/63088
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346217 02/10/20 02:27 PM
SubLGT Offline OP
[Linked Image from colesa.ru]
New "Snow" on left, old Xi3 on right.
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346222 02/10/20 02:32 PM
R
Rand Offline
R
excellent, this is what I wanted when I purchased the vikingcontact 7 this year.
Which have been VERY good so far.
Still have about 2 winters remaining on my Jeep's blizzak dm-v2
Maybe my next set of winter tires on the jeep or its replacement(vehicle) will be these Michelins
Thank you for all the tire posts. While some are more useful than others it is very convenient to click on them here instead of sorting through pages of results on a search engine.
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346241 02/10/20 02:48 PM
W
wdn Offline
W
Thanks for the writeup, very informative. Ice grip increasing by 9% is a lot.
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346269 02/10/20 03:24 PM
SubLGT Offline OP
Nokian is feeling the heat from competitors. 10-20 years ago it was valid to say they were the class leaders for studded and studless tires. But over the last 5 years or so Nokian winter tires have been equalled or surpassed by the offerings from Continental, Michelin, Bridgestone, and Pirelli.
The Xi3 was introduced 8 years ago, and the independent, objective tests at that time revealed that the only significant weakness of the Xi3 was it slush planing performance. The new tread design of the X-Ice Snow suggests that weakness may have been remedied. But we will have to see how it does in independent testing.
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346291 02/10/20 03:42 PM
B
buck91 Offline
B
When I had the X-ice 2 on my Mustang they were absolutely phenomenal. Can't imagine these aren't as good.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346349 02/10/20 04:34 PM
E
edyvw Offline
E
They obviously addressed slush issue with Xi3.
Next season I am probably dumping Nokian R2 from Tiguan so maybe I give these a try. Though I am conflicted about Vikingcontact7 as they are just that good.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Michelin Introduces New "X-Ice Snow" [Re: SubLGT] #5346369 02/10/20 04:52 PM
E
edyvw Offline
E
10-20 years ago Nokian's, on European market, largest winter tire market in the world, were afterthought except in Finland. I left Europe for US in 2005, and if one wanted top tier winter tire, he/she would go Good Year or Continental. Good Year was absolute king in 1990's in winter tire market in Europe. Continental took that throne in beginning of 2000's and it is not letting it go.
What we get here is mixed offering at best, though it is getting better.
Page 1 of 4 1 2 3 4
