War of 1812
by pkunk - 02/16/20 09:40 PM
Difference in brake hose brands?
by dan_erickson - 02/16/20 09:30 PM
End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
Daytona 500 engine related question
by OilUzer - 02/16/20 07:37 PM
2006 Subaru Forester 2.5 NA
by 762fermeandyou - 02/16/20 07:29 PM
DIY Paintless Dent Removal....
by dblshock - 02/16/20 07:17 PM
Bad sports teams
by 53' Stude - 02/16/20 06:42 PM
Valvoline 20W-50 Baja 1000 Race oil
by kstanf150 - 02/16/20 06:21 PM
How to stand on the roof of a Saturn Vue?
by atikovi - 02/16/20 06:09 PM
Spliceline wire connectors
by Donald - 02/16/20 05:22 PM
Found a few clearance oils at AZ today
by PantherFan88 - 02/16/20 04:55 PM
NASCAR electric
by CourierDriver - 02/16/20 04:52 PM
Valvoline Modern Engine vs Regular synthetic?
by PantherFan88 - 02/16/20 04:50 PM
Converting 1970 396 to Fuel Injection
by 007 - 02/16/20 04:47 PM
2016 frontier.
by red7404 - 02/16/20 04:34 PM
Ruger .22 SA - not a good show
by JHZR2 - 02/16/20 03:48 PM
engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
FlightRT, 74Widebody, mmmmmnnn, jjrockbush, eamerritt
70721 Registered Users
79 registered members (01VFR, ammolab, 74Widebody, AC1DD, 4WD, Ag76, 12 invisible), 1,698 guests, and 54 spiders.
Topics301,545
Posts5,197,688
Members70,721
Most demanding gaming program? #5346162 02/10/20 12:48 PM
cjcride Offline OP
Is it safe to that a good flight simulator is probably the most demanding you can get for a gaming computer?
Re: Most demanding gaming program? [Re: cjcride] #5346173 02/10/20 12:58 PM
Quattro Pete Offline
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Most demanding gaming program? [Re: cjcride] #5346176 02/10/20 12:59 PM
B
BMWTurboDzl Offline
B
Note even close. FPS games are generally the most demanding because users demand high levels of ground level detail with realistic levels of special effects. Ex, PUBG, COD, Battlefield series, etc.
Flight Sims just don't require the same level of detail.
435i
Re: Most demanding gaming program? [Re: cjcride] #5346178 02/10/20 01:00 PM
J
jayjr1105 Offline
J
Anything modern can be extremely demanding if you turn the settings up high enough. Most new games with realistic scenery will really hit a system hard. Why do you ask?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Most demanding gaming program? [Re: Quattro Pete] #5346191 02/10/20 01:07 PM
cjcride Offline OP
From a graphics point of view.
Re: Most demanding gaming program? [Re: BMWTurboDzl] #5346197 02/10/20 01:10 PM
cjcride Offline OP
If you are in a dogfight the sharp turning, descending/climbing and power changes I thought would be the max. demand on a system.
Re: Most demanding gaming program? [Re: cjcride] #5346198 02/10/20 01:10 PM
O
OVERKILL Offline
O
The old benchmark used to be Crysis, but I'm sure that's been long usurped by something even more demanding. Typically, flight sims, as others noted, are on the light end of the demand scale with heavy detail FPS games being on the other.
Re: Most demanding gaming program? [Re: jayjr1105] #5346203 02/10/20 01:13 PM
cjcride Offline OP
I'm thinking of setting up an Ok gaming system for a Flight Sim. Not gonna break the bank.
I saw the other thread asking about a gaming build and I got to thinking that maybe the flight sim. is most demanding
Re: Most demanding gaming program? [Re: OVERKILL] #5346208 02/10/20 01:20 PM
cjcride Offline OP
Many years ago I had one of the Microsoft Flight sims and the sim would buffer if I got too busy on the controls. Nothing else I had would caused that with the system.
Re: Most demanding gaming program? [Re: cjcride] #5346213 02/10/20 01:23 PM
K
KrisZ Offline
K
Not sure where I've seen the tests, but most true simulators are very CPU intensive. Graphics are usually not all that demanding when compared to FPS games.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Most demanding gaming program? [Re: cjcride] #5346218 02/10/20 01:27 PM
Spktyr Online Content
Online Content
Not so much, no. Mostly because a lot of modern FPS/milsim games include flight simulation ***as a sub-function*** to support the combat. All while rendering many more objects (including hypersonic projectiles and particle weapons) at much higher resolution in real time.
Back in ancient times when dinosaurs like the IBM PS/2 roamed the earth, flightsims were more demanding than the bitmap-heavy FPS, but that hasn't been the case since the 90s/00s. FPS have far and away ruled the roost in graphics horsepower requirements for about two decades now.
Re: Most demanding gaming program? [Re: cjcride] #5346243 02/10/20 01:51 PM
R
Rand Offline
R
Would agree fps is most demanding.. also
many fps games if competitive are played at high refresh 144hz+
Flight sim is fine at a steady 60fps.
for example cs:go while relatively light as far as fps games go can be demanding if you are playing it at 240hz
On the other hand if I had a flight sim I might want a 28" 4k monitor which is 4x as demanding as 1080p.
or at least 1440p
Re: Most demanding gaming program? [Re: cjcride] #5346244 02/10/20 01:53 PM
J
jayjr1105 Offline
J
See the pcpartpicker link I posted in the other thread. Was around $625 for the system that was no slouch.
Re: Most demanding gaming program? [Re: cjcride] #5346273 02/10/20 02:27 PM
L
LoneRanger Offline
L
If I was building a desktop PC for gaming I would build for PC VR gaming. That opens the door to some uber cool gaming (VR), plus a VR ready system will run non-VR games that have serious system stressing demands very smoothly. Some of the high end video cards today blow my mind. Numerous cooling fans, double or triple boards, I'm surprised the house lights don't flicker or dim when the user powers-on some of these hardcore gaming and VR ready desktop PC's !!!
'19 F-150 2.7 twin turbo DI V6 .....(Motorcraft synblend 5W30 SN+)
'19 GMC Terrain 1.5 turbo DI I4....(Warren 0W20 1DexosGen2)
'16 Moto Guzzi NTX 1151cc v-twin (Eni 10W60)
Re: Most demanding gaming program? [Re: cjcride] #5346373 02/10/20 03:53 PM
Donald Offline
calculate pi
2015 Ford F-250 w/Powerstroke
