drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
Valvoline NextGen Conventional
by Char Baby - 02/21/20 07:20 AM
Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
104 registered members (apollo18, 750IX, 53' Stude, antone, 1978elcamino, 928, 8 invisible), 2,386 guests, and 22 spiders.
Topics301,750
Posts5,202,058
Members70,766
Dodge 42RLE transmission fluid change. Or not? #5346081 02/10/20 11:05 AM
F
Fordiesel69 Offline OP
F
I know the answer but want your opinions......
On my ford 4R70W, 4R75E variants, I have never caused a failure by changing the fluid and filter. Even when the fluid was poor.
I have a 42RLE in a dodge nitro, and with 150k I do not know the history. It shifts perfect but I experianced a neutral flare after a very sharp right had turn. I think it sucked air from the super aggressive turn and it being a touch low. The fluid is a brownish motor oil color and smells stale, not burnt! I heard ATF+4 does not retain its color dye very well with age. And acceptable fluid can look bad and not smell burnt.
I want to pull the pan, and unless it is covered in clutch debris change the filter and put in new fluid for however much came out, and call it a day. I do not want to do a "flush" or multiple fluid change with that kind of mileage and condition of existing fluid.
Is this ok, or is this tranny sensitive to fluid changes washing the debris into the valve body and damaging the rest of the transmission?
99' Crown Vic Police - SAP (P71)
00' Crown Vic Police - SAP (P71)
08' Crown Vics Police - SAP(P71's) (total of 3 garage queens)
13' Taurus Police
14' Fusion S Base
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346147 02/10/20 12:23 PM
J
jeepman3071 Offline
J
Yes, definitely change the fluid. Chrysler transmissions are very sensitive to having good fresh fluid. Use only ATF+4.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (58k) - Liqui Moly 5w40, MANN HU816X
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346155 02/10/20 12:30 PM
demarpaint Offline
I'd do it. But if I were dropping the pan, I'd change the filter unless everything inside was pristine.
God Bless Our Troops
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346182 02/10/20 01:01 PM
slacktide_bitog Online Content
Online Content
Get an aftermarket pan with a drain plug, so future ATF changes are much easier smile
Redline C+ is good stuff to use where ATF+4 is called for. If that costs too much for you, then use any ATF+4.
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346184 02/10/20 01:03 PM
K
Kira Offline
K
I think the OP wants to change the filter.
The "unless" he employed referred to going to a plan B due to severe internal woes.
When the pan resembles a person's lawn after a roof tera-off, it's bad.
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346242 02/10/20 01:50 PM
T
TriMoto Offline
T
These 42RLE are garbage. FWD trans flipped around.
Re: Dodge 42RLE transmission fluid change. Or not? [Re: TriMoto] #5346478 02/10/20 05:31 PM
Z
zrxkawboy Offline
Z
How have they failed for you? Ours has 130k miles and is going strong.
"Think of all the Ford owners who will someday want an automobile." John Dodge
