Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
96 registered members (Astro_Guy, alex_at, ajchien, asleepz, b1amgm47, 1978elcamino, 9 invisible), 2,365 guests, and 23 spiders.
Topics301,909
Posts5,205,197
Members70,798
Current OEM Transmission Fluid '08 CR-V #5345976 02/10/20 09:13 AM
G
Gebo Offline OP
G
I'm not a knowledgable Honda guy so I need help. What is the current Honda spec'd ATF for a 2008 CR-V?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5345982 02/10/20 09:18 AM
J
jeepman3071 Offline
J
Honda ATF DW-1 Synthetic
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (58k) - Liqui Moly 5w40, MANN HU816X
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5345987 02/10/20 09:21 AM
G
Gebo Offline OP
G
It seems like a lot of mfr are constantly upgrading their ATF's. Thanks!
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5345990 02/10/20 09:26 AM
J
JeffKeryk Offline
J
Yes, the spec is DW-1. It is back spec'ed for other Hondas as well.
I just serviced our 1998 Accord LX with the Idemitsu DW-1 equivalent.
Very easy job.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5345992 02/10/20 09:27 AM
N
nwjones18 Offline
N
Just FYI, but my 2008 CRV has been perfectly happy on Maxlife ATF.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 and Mopar filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
2007 Mazda 3 2.3 130k 5w-30 syn-blend and Denso filter
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346005 02/10/20 09:46 AM
Chester11 Offline
Be gentle on the drain plug - and make sure it isn't cross-threaded. I thrashed mine by acting like a gorilla, and it wasn't an easy fix.
I tried Maxlife and the downshifts became harsh with a bit of a RPM flare. My trans may be on the way out - everyone else seems to have no problems.
Re: Current OEM Transmission Fluid '08 CR-V [Re: Chester11] #5346014 02/10/20 09:54 AM
J
JeffKeryk Offline
J
Good point. Every Honda AT drain bolt have been super tight from the factory. Crazy tight. Stupid tight.
When reinstalling, set your torque wrench to 36 pound feet.
2018 Lexus RX450h
2006 Acura TSX
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346036 02/10/20 10:24 AM
G
Gebo Offline OP
G
Well, I’ll be getting oil and AT drain plugs. Thanks fir your help!
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Current OEM Transmission Fluid '08 CR-V [Re: JeffKeryk] #5346038 02/10/20 10:27 AM
J
jeepman3071 Offline
J
This.
A friend just acquired a 2000 Honda Civic with 160k on it. The trans fluid looked okay (was serviced at some point during it's life) but definitely needed changing. I went to crack the plug loose and needed a breaker bar and a section of pipe. crzy
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346040 02/10/20 10:30 AM
G
Gebo Offline OP
G
Now I’m starting to sweat as this is a church member’s car. I gotta change it though. I gotta.
Oh, what is the procedure for checking ATF level in this car? I only know Toyota’s. Is it same as Toyota with dip sticks?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346047 02/10/20 10:38 AM
ctechbob Offline
Should just be a dipstick on a warm transmission for checking. Nothing crazy
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346052 02/10/20 10:42 AM
G
Gebo Offline OP
G
Engine running?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346083 02/10/20 11:12 AM
Dave Sherman Offline
Originally Posted by Gebo
Engine running?
Nope, a 2008 CR-V has ATF checked with the engine off. I had one.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346085 02/10/20 11:14 AM
J
JeffKeryk Offline
J
Not running. I don't think it changes much hot or cold.
After I service a Honda trans, I just let it idle, select each gear for 10 seconds both up and down.
Easy peasey.
2018 Lexus RX450h
2006 Acura TSX
Re: Current OEM Transmission Fluid '08 CR-V [Re: Gebo] #5346106 02/10/20 11:30 AM
W
WhyMe Offline
W
5 quarts motor oil took my 2011 crv to the perfect level everytime i changed oil. i used maxlife ATF in mine and it was ok. mine took about 3.5 or so quarts. its an easy drain and refill
