Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
23 registered members (BlueOvalFitter, Brian553, c502cid, bbhero, Char Baby, alcyon, 2 invisible), 1,137 guests, and 18 spiders.
Topics301,932
Posts5,205,743
Members70,801
Page 1 of 3 1 2 3
Oil Capacity 2008 CR-V #5345968 02/10/20 09:03 AM
G
Gebo Offline OP
G
Changing oil in a 2008 Honda CR-V and the owner's manual says 4.4 qts with filter change. Amsoil site says 4.4 qts with a filter change. I changed filter with OEM Honda filterband added 4.5 qts and the oil only comes up to the bottom mark on the dipstick (after setting over night). I added the extra 1/2 qt and it only comes up to the middle of the marks on the dipstick. It appears the engine takes 5.5 qts. This is my first time changing the oil in this car (and it ain't mine) and I am a little confused.
Any ideas from you CR-V owners?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5345980 02/10/20 09:16 AM
J
JeffKeryk Offline
J
I service the K24 with 5 quarts of synthetic 5w30 or 5w20 oil and a good filter.
I let it drain for a minimum of 15 minutes, generally longer. More oil drains if you remove the filter with the oil plug uninstalled.
Brings the level up to the top mark.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Oil Capacity 2008 CR-V [Re: JeffKeryk] #5345986 02/10/20 09:20 AM
G
Gebo Offline OP
G
Originally Posted by JeffKeryk
. ....More oil drains if you remove the filter with the oil plug uninstalled.
That is exactly what I did and a bunch of oil came out when I removed the filter. I mean a bunch.
I have put in 5.5 qts and it is at top notch on stick.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5345988 02/10/20 09:23 AM
Chester11 Offline
09 here. I always thought the 4.4 was a little light. I always seem to end up using very close to 5. I have to "angle" the dipstick out - it come straight up and hits the hood - so I figured I was throwing off the measurement a bit.
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5345989 02/10/20 09:25 AM
2
2010Civic Offline
2
I've found Honda's oil capacities to be wrong. Just figure out how much it takes to get to the full mark and go from there.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5345993 02/10/20 09:29 AM
N
nwjones18 Offline
N
I put 5 quarts in my 08 CRV and it brings it up to the full line (or pretty close) on the dipstick.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 and Mopar filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
2007 Mazda 3 2.3 130k 5w-30 syn-blend and Denso filter
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5345994 02/10/20 09:30 AM
J
JeffKeryk Offline
J
I have never needed more than 5 quarts. And I have serviced K24s more than 30 times.
Check the level cold on a fairly level surface; please post your results. Ya never know...
2018 Lexus RX450h
2006 Acura TSX
Re: Oil Capacity 2008 CR-V [Re: JeffKeryk] #5346000 02/10/20 09:39 AM
G
Gebo Offline OP
G
It drained over 5 hours. FYI (Daytona and Joker)
Will do. It’s sitting in my garage now. I’ll give it a few hours and recheck with pic. thumbsup
When you do a drain and fill of AT, how much ATF you get out? I’m off today and Planning on buying 3 qts DW-1 from my Acura PM buddy. Will 3 be enough?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5346007 02/10/20 09:47 AM
J
JeffKeryk Offline
J
3 quarts should be perfect. Buy 4; ya might spill.
If the ATF is brown or dark, do it twice with a short run in between.
Otherwise, do it again at next OCI.
In fact, see if Honda will give you a price on a case, which is 12 quarts.
Or buy online...
All good. You will love that Honda. The mighty K24 is one engine they really got right.
2018 Lexus RX450h
2006 Acura TSX
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5346009 02/10/20 09:50 AM
G
Gebo Offline OP
G
What should I expect the DW-1 to cost?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5346018 02/10/20 09:57 AM
J
JeffKeryk Offline
J
Amazon DW-1
Idemitsu DW-1 Equivalent
Of course dealer will be higher. I always ask for a discount, especially on a case.
Regarding the oil drain plug: If the threads are damaged at all, or it doesn't thread easily by hand, or the head is beat up at all, get a new one.
I keep a few on hand...
2018 Lexus RX450h
2006 Acura TSX
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5346033 02/10/20 10:20 AM
G
Gebo Offline OP
G
[Linked Image]
5.5 qts. ????? It may be 1 mm above the dot????
My dealer $7.25 per qt DW-1. I always get great pricing from my Acura and Lexus dealers. I’ll get a spare drain plug as we will be doing 3K OCI’s sailing
Thanks for your help! Thank God it has a AT dipstick!!!
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5346076 02/10/20 11:00 AM
CT8 Offline
Oil drains from the oil passage ways .
2015 F150 2.7
2018 F350 6.2
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5346088 02/10/20 11:18 AM
J
JeffKeryk Offline
J
You are doing a great job.
I would check air and cabin filters.
Pull a plug; it it ain't the OEM NGK or Denso, swap 'em out. 13 pound feet.
Funny story - When I firsy changed the plugs in our 2006 TSX with the K24, there were 2 NGK and 2 Denso plugs installed at the factory.
OK, then flush the PS fluid and brake fluid.
And wash that bad boy!
2018 Lexus RX450h
2006 Acura TSX
Re: Oil Capacity 2008 CR-V [Re: Gebo] #5346120 02/10/20 11:40 AM
H
hallstevenson Offline
H
Normally I'd say you're done based on the dipstick reading but if you put 5.5 quarts in, I don't think you're getting a good reading. I suspect you've overfilled it.
Page 1 of 3 1 2 3
