RGT clearance at BJs Wholesale
by dadto2 - 04/02/20 07:38 AM
Dollar General: LA's Awesome Orange 1 gall~$2.25
by dwcopple - 04/02/20 07:05 AM
Are all JWS3309 ATF’s the same?
by dlundblad - 04/02/20 05:03 AM
Shell selling rebranded Pennzoil in Europe?
by FordCapriDriver - 04/02/20 02:54 AM
Mitsubishi Mirage for Basic Transportation
by parimento1 - 04/02/20 12:54 AM
Amsoil EaOM103
by Lufty - 04/02/20 12:46 AM
Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Knop, AConstructionGuy, MPDano, ferdna, Code
71078 Registered Users
90 registered members (aba4430, 53' Stude, AndyB, 18LateModelFan, 007, 94astro, 11 invisible), 1,231 guests, and 18 spiders.
Topics303,474
Posts5,235,796
Members71,078
Can Maxlife mix with SP-III? #5345682 02/09/20 10:19 PM
I
Icyd Offline OP
I
Hi i have a kia rio ub, 98k km (60k-ish miles) with 4-speeder that calls for SP-III fluid. I'm going to service the gearbox with filter change and using Maxlife. I know the old fluid will not be fully drained and will have Maxlife mixed in with old fluid from factory by some percent. is this ok or do i have to do a full flush?
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345688 02/09/20 10:24 PM
K
kschachn Offline
K
It will mix fine. You do not need to flush.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345699 02/09/20 10:34 PM
G
Gebo Offline
G
I would never flush any AT. I'd do a drain and fill with the OEM spec'd fluid if possible. Is SP-III not available in Malaysia?
I don't know how it will mix with your SP-III.
If you research Maxlife ATF, the bottle says it is recommended for pretty much any transmission ever made.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Can Maxlife mix with SP-III? [Re: Gebo] #5345721 02/09/20 10:53 PM
I
Icyd Offline OP
I
thanks.
SP-III still aplenty but mostly from unknown brands unless i go for OEM which is expensive. I also heard good stuff about Maxlife. Or is it? Is it considered an upgrade or just merely a compatible replacement?
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345781 02/10/20 12:53 AM
J
Jetsfan421 Offline
J
I have done a drain and fill on my own 07 Kia Rio. It had a Valvoline service with presumably maxlife in it's service history around 70k miles, then I changed the fluid again at 120k miles with idemitsu hk sp3 replacement. It's not oem fluid and it does a good job. The shift feel before and after did not change for the worse or better, but it was good to begin with and the fluid was red before and after the change. I also added 1oz lubegard red per quart to the total fill of the transmission. The fluid after almost a year looks nearly identical to when I did the service. I'm sure it's a mix of factory fill, Valvoline maxlife, idemitsu hk and lubegard red. It shifts very smoothly.
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345810 02/10/20 02:54 AM
I
Icyd Offline OP
I
ahh..right from the horse's mouth.appreciate that. as of now the old fluid still looks clear but im getting a little bit of delay when engaging reverse. hope the service will cure it
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345860 02/10/20 06:41 AM
Z
zeng Offline
Z
I had been using 7ish cSt branded Mobil 3309 and branded Toyota Type IV interchangebly in a Yota calling for Type IV at 12-15 k miles oci with smooth shifts .
Current odo is 300k km or 180k miles , original .
SPIII is likely a 7ish cSt ATF and I personally won't opt for 6ish Maxlife ,granted it's popular on Bitog .
Re: Can Maxlife mix with SP-III? [Re: kschachn] #5345900 02/10/20 08:32 AM
Sayjac Offline
+1 Linked is a thread which discusses SPIII alternatives, included are several MaxLife anecdotes. As can be seen by thread date, the SPIII spec not a new one, been around awhile.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2502685/1
As for the term "flush", in my observation many use that term for any complete fluid exchange, eg., a cooler line exchange. As an example this popular youtube for a cooler line exchange refers to it as a flush. https://www.youtube.com/watch?v=MsdPAadc9fY . At least in Honda's case, my understanding the warning against a "flush" comes when any type cleaning agent is used in the process ie., anything other than ATF. An example of that would be the Pat Goss promoted BG cleaning agent flush process.
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345919 02/10/20 08:48 AM
G
Gebo Offline
G
thanks.
Ok, here's my logic. I have different models of Lexus and a Toyota. The Toyota calls for Dexron III, the Lexus calls 2 different transmission fluids. The old Lexus calls for T-IV and the newer Lexus call for WS. These are all very different transmission fluids. How in the world can anybody make a transmission fluid that will satisfy the requirements of all three different ATF's? Maxlife says it can replace all 3 of these fluids. I don't subscribe to "one size fits all." The fact of the matter is, you could run D-III in your car and it would probably run fine, for a while. Many people here love Maxlife Universal ATF and they seem to almost worship it. You are just gonna have to pick one. I would guess you will see about a 60:40 split between Maxlife and OEM here on this forum so there is no clear winner. LOL
Whatever you do, please don't do a flush. Research flushes first.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345925 02/10/20 08:54 AM
Propflux01 Offline
You should be using SPiv-M now anyhow. It is the latest upgraded fluid from Kia/hyundai. Max life will probably work, but keep in mind, from the bottle: Max life is recommended by Valvoline for use... is Valvoline going to pay for your Tranny if it goes out?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345937 02/10/20 09:10 AM
A
atikovi Offline
A
Unless this is some beater, I'd get the factory fluid and avoid universal multi-make brands that claim to work in many different cars.
Re: Can Maxlife mix with SP-III? [Re: Icyd] #5345954 02/10/20 09:43 AM
dubber09 Offline
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Can Maxlife mix with SP-III? [Re: atikovi] #5345973 02/10/20 10:09 AM
P
pandus13 Offline
P
in his case SP-III would also be the same as KIA fluid or Mitsubishi Diamond. Probably easier to find since Mitsubishi has a big market in Asia.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Can Maxlife mix with SP-III? [Re: Sayjac] #5346471 02/10/20 06:25 PM
H
hallstevenson Offline
H
No
When Honda says "flush", in the Honda world, that means draining and refilling with Honda ATF. When it comes to aftermarket flush systems, they "strongly recommend that you avoid using them on any Honda vehicle".
[Linked Image]
Re: Can Maxlife mix with SP-III? [Re: Sayjac] #5346545 02/10/20 07:22 PM
Sayjac Offline
OT As noted in my previous the term "flush" can have multiple meanings including but not limited to a cooler line exchange as one example. Thus the use of eg. in my previous post and the youtube linked as documentation. If one reads this forum often, I know of no one knowledgeable that would say anything wrong with doing a cooler line exchange on a Honda which is sometimes referred to as a flush. In fact, a cooler line exchange frequently is recommended by some in place of a d&f or multiple d&fs on this forum
So, while Honda may refer to multiple d&f as a flush that doesn't eliminate a cooler line exchange like the one linked as a type of flush as properly noted. I also believe that flush machines that use a cooler line exchange with no cleaning agents is also suitable for that purpose. Based on this thread some/many would agree. So I maintain that as "my understanding". Whether a Honda dealer may call a d&f a flush is irrelevant to me.
I would note that left out of the 08 service notice is an added reference in the cited link below* that states, "Due to confusion, I must add that this procedure was written for service technicians at a DEALER who will do this while on a lift." So a Honda dealer telling a customer they are going to do a flush on a trans, is really doing multiple d&fs. That said, safe to say imo 'most' on this forum are sophisticated enough to know the differences between a d&f or multiple d&fs sometimes called a spill and fill and a complete return line exchange sometimes called a flush.
I think that more than clears up what my previous post said including but not limited to snippet not indicted as such.
https://www.crvownersclub.com/threads/honda-auto-trans-flush-procedure-official.2324/
Note the re: to me as clarification of previous post.
