Cartridge Filter Question
by Tundra73 - 02/25/20 01:21 PM
Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
108 registered members (01VFR, aquariuscsm, ABerns, alex_at, AlaskaMike, Astro_Guy, 7 invisible), 2,461 guests, and 21 spiders.
Topics301,910
Posts5,205,213
Members70,800
2015 2.7L Tacoma and towing #5345930 02/10/20 08:00 AM
N
Nessmuk53 Offline OP
N
Toyota calls for 0W-20 with the mention of using a higher viscosity if doing extended high speeds or extreme duty.
I will be towing a 6x10 cargo trailer approximately 3500 miles this April. This will be the first time that I have towed it more than 8 hours at highway speeds. Weight will be about 2500 pounds.
I am considering 0W-30 for my next oil change. I am just wondering what others would do 0W-30, 0W-40?
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5345938 02/10/20 08:13 AM
Snagglefoot Offline
Welcome to Bitog. No numerical data, but I’m currently running Pennzoil Platinum Euro LX 0w30 in a Chev 6.0 LS engine. This has a kv100 that is on the high side of a 30 grade. 5w30 would suffice as well.
If you want the job done right......do it yourself.
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5345962 02/10/20 08:56 AM
T
Triplicate Offline
T
For what it's worth, my dad and I towed a 73 VW thing on a 2 axle trailer from Massachusetts to Maryland in his 2WD crew cab 2013 Tacoma 2.7, no sweat. 70 mph in traffic, there was never a point where the Taco didn't have enough grunt. We towed 8+ hours at highway speeds. We even got a flat tire on the NJ Turnpike to add some excitement to the trip. Luckily it was the Tacoma's tire and not the trailer tire, because he didn't have a spare for the trailer.
Factory Toyota 0w-20 oil and filter.
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5345998 02/10/20 09:35 AM
Bryanccfshr Offline
Any decent 10w30 synthetic would be my go to (I am running Havoline pro DS 10w30 in my v6 Tacoma right now), Mobil 1 0w40 works real well.
I would also consider RGT 5w30 (since I have a lot of it from clearances and rebates),
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346003 02/10/20 09:42 AM
T
Triple_Se7en Offline
T
Mobil-1EP 0W20. Enjoy some of it's PAO on the 8+-hr ride with you. Some say it's the best mid-priced 0w20 out there.
Trolled Here? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346010 02/10/20 09:52 AM
A
aquariuscsm Online Content
Online Content
A
I’d think towing would be harder on the transmission and differential,with no additional stress on the engine,since the transmission and differential are taking up the additional stress,right?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: 2015 2.7L Tacoma and towing [Re: aquariuscsm] #5346030 02/10/20 10:14 AM
Bryanccfshr Offline
Everything in the driveline is taking additional stress.
The truck will have to be run in a lower gear to maintain interstate speeds, especially with headwinds and hills, by keeping it in a higher bar you risk excessive shifting with an auto, and lugging the engine under load.
So properly running the transmission in a lower gear means the engine will be turning at sustained higher than normal rpms. Which means it is creating more heat. It is a good idea to run a thicker oil in this situation. Because fuel mileage is no longer a concern..
Towing a similar trailer a couple of weeks ago expect gas mileage to drop. In half. I averaged 10-11 mpg with a fully loaded 6x12 loaded enclosed trailer with a mild headwind. Maintaining 65-70 for 250 miles.
Re: 2015 2.7L Tacoma and towing [Re: Bryanccfshr] #5346058 02/10/20 10:44 AM
supton Online Content
Online Content
If it has an engine oil cooler, I'd "know" that 0W20 would be fine. If it didn't, I'd "feel better" with something thicker. And regardless I'd just use xW30. smile
It's a single run in a vehicle that has some indication of being used as a work vehicle. Toyota does not just toss out 0W20 for fun (I'm not sure any of the OEM's did). Day in and out towing, sure I think xW30 is better. One run though and I don't see the problem. Since you can plan ahead, I'd run the thicker, but I wouldn't lose sleep if you suddenly towed with "thin" oil.
That's a good point, if this thing is winding out for 3,500 miles then, if nothing else, a short OCI is in order, like 5k.
OP, is this an auto or stick?
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346062 02/10/20 10:46 AM
A
ad244 Offline
A
5w-30 or 10w-30 Synthetic all day long.
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346077 02/10/20 11:01 AM
K
ka9mnx Online Content
Online Content
K
The rear axle will experience the most stress in this situation. Also, lugging the engine will put more stress on the bottom end engine bearings.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346092 02/10/20 11:21 AM
N
Navi Offline
N
In the owners manual are tables showing what you can tow. The Toyota 2.7 liter 4 cylinder is the most durable one they make. The transmission you should worry about more.
That said I personally wouldnt tow anything except for a U-Haul with a light truck. A 6x10 sounds like a Uhaul style trailer so it should be ok.
As for viscosity towing or no towing Im not using 20 anything. I would go thicker.
Re: 2015 2.7L Tacoma and towing [Re: ka9mnx] #5346169 02/10/20 12:57 PM
demarpaint Offline
Good point and why I'd prefer a 30 grade oil for an extra safety margin while towing. That said lugging an engine should be avoided.
God Bless Our Troops
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346281 02/10/20 02:34 PM
N
N
It’s a Pace American Cargo Sport and is not built nearly as rugged as a Uhaul. I changed fluids in my diffs and transmission (5sp manual) for a higher viscosity already.
I think I am going to put Mobil 1 0W-30 in it.
For the past 5 years I have towed it regularly over to the highest point in West Virginia with no problems. Never towed it all day for extended periods before.
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346371 02/10/20 03:53 PM
M
madeej11 Offline
M
I would go with a 5w30 year round. Something like Valvoline Advanced Full Synthetic.
Re: 2015 2.7L Tacoma and towing [Re: Nessmuk53] #5346393 02/10/20 04:12 PM
Cdn17Sport6MT Offline
A (presumably) 4x2 Taco with 4 cyl / 5mt is likely one of the most durable, long-lived trucks out there. Not great looking with its smallish-looking stock wheels - but talk about practical and durable. Hard to find 'em with 5mt... and reasonable miles. Kudos to you for having it / running it 😊 .
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
