Virgin EcoGard X4610 C&P with element weights
The land of USA-made Subies!
Another $2 filter at Rural King, nitrile ADBV but good looking. Interchange is 7317 size, looks fine for the shorter-OCI crowd (probably nearly any OLM-changing people). Suprised at how good a $2 filter can look, filtering efficiency needs a follow-up since I don't know it offhand.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
kstan, it is really close, but if you look at the weights there are obviously some differences there. $2 either way, your choice, and they look well-constructed for the money. No wavy pleats nor horrible gaps, etc. I think either one would be fine for 5k.
Originally Posted by SubieRubyRoo
... filtering efficiency needs a follow-up since I don't know it offhand.
I know on the x4651 (Fram PH2 size) it is 98.8% efficient > 30um and 87.97% efficient > 20um per the Ecogard rep I talked to.
I know someone else had contacted them about a different size filter (don't remember model off hand) and were given slightly different numbers for that specific model.
I do agree for $2 I would use one of these filters for most any "routine" OCI. Problem is nobody around me has them on the shelf, and online they are more than a Fram orange can at Walmart.
Chris: looks better than one other filter you cut and posted. Thank You for all cut and posts even though I was being a wise rear end
Good cut and posts also
Haha no harm no foul Adam, was just getting stir crazy during this dark, dreary monsoon winter and needed something to do.
