Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
19 registered members (ctechbob, Bjornviken, Hohocc, dlundblad, BBDartCA, john_pifer, 2 invisible), 1,058 guests, and 17 spiders.
Topics301,932
Posts5,205,751
Members70,801
Virgin Napa Platinum 41334 C&P with element weights #5345660 02/09/20 08:57 PM
SubieRubyRoo Offline OP
So, I had a couple of these for trans filter spin-ons (my Subies all have case-mounted trans filters) and I wanted to see what it looked like. Pleats were a little bit skewed but not bad, I'm sure it will work fine. In use on a 4EAT, this is likely a lifetime filter LOL I like the Wix ADBV sealing on this, even with the combo valve. It was my first time messing around with one, and other than the bypass valve being nitrile, it feels plenty capable. Enjoy!
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
De omnibus dubitandum.
Re: Virgin Napa Platinum 41334 C&P with element weights [Re: SubieRubyRoo] #5345703 02/09/20 09:37 PM
M
mpgo4th Offline
M
I've cut open a few of those platinum filters too. Haven't found a perfect one yet. Nothing that made it look unusable but always had funny pleat spacing or pleat twisting. Also the media is smaller than the end cap diameter on them. Who knows if it matters but for the price it should be better.
Re: Virgin Napa Platinum 41334 C&P with element weights [Re: mpgo4th] #5345712 02/09/20 09:45 PM
Z
ZeeOSix Offline
Z
Doesn't matter, gotta have some room for the pleat adhesive.
Re: Virgin Napa Platinum 41334 C&P with element weights [Re: SubieRubyRoo] #5345713 02/09/20 09:45 PM
I agree construction could take a lesson from some of the MIC filters, but one thing to note is this does have the heaviest element, and it doesn't appear to be solely from the endcaps. They appear about the same thickness as the XG, so it would come down to the media and mesh backing. I won't even get into the efficiency part, because ZeeOSix has educated us that these are not a "fine filtration" element at lower micron sizes, but it will likely work just fine, and for extended distances as well.
As I've stated before, I run these Platinums as trans filters on my Subies and ones I service, and in all reality they would only need to come off if the can rusts or is damaged, in those applications.
Re: Virgin Napa Platinum 41334 C&P with element weights [Re: SubieRubyRoo] #5345848 02/10/20 05:10 AM
M
mpgo4th Offline
M
I might try one as well on my EcoBoost next service. I'm trying to decide on filter for this vehicle.
Re: Virgin Napa Platinum 41334 C&P with element weights [Re: SubieRubyRoo] #5346409 02/10/20 04:20 PM
53' Stude Offline
Chris: you ran this filter although I believe it was a 51515 on your old Fusion that I chopped. This filter looks serviceable smile
Another great c&p so Thank You smile
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
