Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
30 registered members (Bjornviken, Bighorn2500, Best F100, 53' Stude, Amenhotep, Aichiguy, 3 invisible), 1,164 guests, and 17 spiders.
Topics301,934
Posts5,205,764
Members70,801
Waterproof Grease --Aluminum or Calcium Complex #5345613 02/09/20 08:21 PM
P
pburchett Offline OP
P
I am in need of a waterproof grease. Its only purpose is to provide a barrier to the intrusion of water.
The application is Honda ATV brake hubs. The hubs are designed to use grease in grooves around and within circular flexible seals that rotate with the brake hub and are in contact with a metal backing plate. The grease barrier between the hub and the backing plate is the only thing that keeps the water out of the brakes.
Lithium marine greases do not last one ride if I have to ford much water. Since I will have to order the grease I was wondering if anyone could comment on the waterproof characteristics of the aluminum vs calcium complex greases or which one would be best for this application.
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345631 02/09/20 08:31 PM
CT8 Offline
Give it a try [ the Aluminum base] and report back .
2015 F150 2.7
2018 F350 6.2
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345644 02/09/20 08:41 PM
R
Rand Offline
R
https://www.amazon.com/WD-40-Specia...+sulfonate&qid=1581302433&sr=8-4
IIRC
calcium sulfonate type greases are widely compatible and handle "severe" water conditions well.
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345662 02/09/20 08:58 PM
M
Mainia Offline
M
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345666 02/09/20 09:01 PM
R
Rudy1999 250 Offline
R
TRC Texas Refinery - Paragon 3000 the water washout rate is extremely low ...
A Salesperson/Problem Solver
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345871 02/10/20 06:17 AM
J
joekingcorvette Offline
J
I am not a grease expert but I would have to believe any Marine grease would work because boat trailers are submerged in water.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345883 02/10/20 06:49 AM
B
buck91 Offline
B
How about a silicone grease? I was having issues with Super-Lube getting washed out of my polyurethane bushings when I used to DD my Mustang. Switched to Jet-Lube NLGI #3 silicone grease and it lasts multiple times longer between greasings.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345886 02/10/20 06:58 AM
B
Boomer Offline
B
Aluminum greases are great when immersed in salt water as sodium will not really break the bonds of the detergent molecules to the aluminum ions. But calcium greases will do well in fresh water. So either should do you fine
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345921 02/10/20 07:51 AM
R
ragtoplvr Offline
R
I recommend a sliicone grease like Krytox
BMW motorcycles of the oilhead vintage use needle bearings on pivot points for the final drive that are very poorly water sealed. I have replaced them several times. Last time, I washed out the bearing and packed thoroughly with silicone grease and then on assembly but in a barrier of more silicone grease. Never had a problem again.
Rod
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: ragtoplvr] #5345935 02/10/20 08:05 AM
K
kschachn Offline
K
Krytox is not a silicone, that is the point of the material.
There are fluorosilicone greases such as Molykote 3451 which cost a whole lot less than Krytox.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5345936 02/10/20 08:06 AM
Snagglefoot Offline
Mystic Marine Grease uses an anhydrous calcium system.
If you want the job done right......do it yourself.
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5346270 02/10/20 02:24 PM
T
Trav Offline
T
This is one that Mola put me on to for inner tripod CV joints in the NLGI #1 variant, it happens to be waterproof also.
https://www.schaefferoil.com/synforce-green.html
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5346525 02/10/20 06:03 PM
J
JunkdrawerDog Offline
J
I always used Bel Ray on the dirt bikes. I believe it was an aluminum compound and it was commonly available at motorcycle shops.
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: pburchett] #5346725 02/10/20 09:35 PM
R
RDMgr Offline
R
Bel-Ray Waterproof grease is an aluminum complex grease modified with barium complex grease. It is probably one of the most water resistant greases available and will act as an excellent seal against infiltration. It is available in a lot of motorcycle and powersports shops in small tubs.
Re: Waterproof Grease --Aluminum or Calcium Complex [Re: RDMgr] #5346892 02/11/20 06:46 AM
B
berlyn Offline
B
^^ great info here, thank you. If only the access to their TDS's was easier.. At least in EU.
