Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
23 registered members (2013ecof150, AnthemBassMan, Compagnion, Black_Thunder, 4 invisible), 1,000 guests, and 17 spiders.
Topics301,684
Posts5,200,469
Members70,756
Purolator filters bad? #5345599 02/09/20 08:07 PM
M
Micahmcmeen Offline OP
M
I have seen some talk on here that purolator filters are bad. They seem pretty quality to me? What are your thoughts? I also have used premium guard extended performance on my jeep. I like the filters quite a bit. Thoughts?
Re: Purolator filters bad? [Re: Micahmcmeen] #5345611 02/09/20 08:19 PM
spasm3 Offline
The concerns are, tears in the pleats. Members here have cut open filters and found torn pleats, frequently in the same areas.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Purolator filters bad? [Re: Micahmcmeen] #5345612 02/09/20 08:20 PM
T
Triple_Se7en Offline
T
What specific Purolator Filters?..... they make different levels.
Or just Stick with the Premium Guard EPs.
Only Purolator I would buy is the Boss on sale.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Purolator filters bad? [Re: Micahmcmeen] #5345616 02/09/20 08:23 PM
K
kschachn Offline
K
If you've seen "some talk" on here then you've also seen the pictures of torn media, right? That doesn't seem very quality to me.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Purolator filters bad? [Re: Triple_Se7en] #5345629 02/09/20 08:31 PM
M
M
I bought the purolator one. The one I saw where it tore was after 11k miles (which they are not rated for) and was using a synthetic blend.
Re: Purolator filters bad? [Re: Micahmcmeen] #5345635 02/09/20 08:34 PM
J
jayjr1105 Offline
J
Exactly, don't complain if you went above and beyond manufacturer's recommended interval. I ran a Purolator one with Mobil 1 AFE and had a really good blackstone lab report.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Purolator filters bad? [Re: Micahmcmeen] #5345643 02/09/20 08:40 PM
A
adams355 Offline
A
Most are confused on here about Purolator filters, type, name, old design vs new design, PureOne and Puralator One etc. Considering the Purolator One is class leading at 99.9% efficiency @ 20 microns and 10,000 miles. All of the reviews I have seen online are excellent.
Re: Purolator filters bad? [Re: adams355] #5345652 02/09/20 08:47 PM
K
kschachn Offline
K
Not at all. The OP said "I have seen some talk on here that purolator filters are bad" which is true as stated.
1994 BMW 530i, 251K
Re: Purolator filters bad? [Re: Micahmcmeen] #5345655 02/09/20 08:50 PM
Z
ZeeOSix Offline
Z
Lots of them reported here that tore media had less than 5K miles on them. They most likely tear shortly after being installed, as I don't think it's mileage dependant.
There haven't been many of the newer Purolators cut and posted, but it's posdible they are better now. Use it, and cut it open and report back with photos.
Re: Purolator filters bad? [Re: Micahmcmeen] #5345661 02/09/20 08:58 PM
Chris142 Offline
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Purolator filters bad? [Re: ZeeOSix] #5345675 02/09/20 09:11 PM
M
M
I will be sure to do that.
Re: Purolator filters bad? [Re: kschachn] #5345727 02/09/20 10:05 PM
A
adams355 Offline
A
There was a thread on here the other day reporting issue with a Purolator filter after 10k miles or so, everybody was quick to put the boot in. Ended up being an old pureone filter as stated by OP rated for 5k.
Re: Purolator filters bad? [Re: adams355] #5345737 02/09/20 10:18 PM
Z
ZeeOSix Offline
Z
^^^ Mileage rating doesn't have much to do with the media tearing mechanism.
Re: Purolator filters bad? [Re: ZeeOSix] #5345754 02/09/20 10:41 PM
A
adams355 Offline
A
You proved my point they don't make that filter anymore. Its years old to begin with and has been superseded with a different design.
Re: Purolator filters bad? [Re: adams355] #5345769 02/09/20 11:18 PM
Z
ZeeOSix Offline
Z
You got old vs new media design specs from Purolators engineering department that shows that Purolator improved the media to make it less prone to tearing?
As Chris142 posted above, that's a pretty recent (way after the "redesign") Purolator with torn media.
If you think they're all "fixed" then go for it. But until I see engineering data from Purolator, or a direct statement from Purolator saying that they made changes to address media tearing, then nothing seems to have changed besides the can paint jobs and names.
