Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
32 registered members (97prizm, AurionX2, BlueOvalFitter, Blkstanger, carlprop, Aichiguy, 1 invisible), 913 guests, and 16 spiders.
Topics301,813
Posts5,203,176
Members70,784
How To Safely Clean A Circuit Board #5345511 02/09/20 06:06 PM
W
walterjay Offline OP
W
The main circuit board on my tractor is filthy. It is full of grass, dirt and debris. I want to clean it . I gave it a few shots with compressed air but it is still grimy. If I remove it how can I safely deep clean it?
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345518 02/09/20 06:14 PM
A
atikovi Offline
A
Alcohol.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345528 02/09/20 06:25 PM
R
Rand Offline
R
circuit board on a tractor? what model?
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345529 02/09/20 06:27 PM
V
vwmaniaman Offline
V
I know you won't want to try this but when I worked in a tv shop, we cleaned the boards in a dishwasher.
Don't waste your time on a slipshod repair.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345531 02/09/20 06:29 PM
N
Neely97 Offline
N
Dampen a cotton swab with isopropyl alcohol. You should use isopropyl alcohol that is at least 90%-100% alcohol. ...
Brush the cotton swab across the grime to dislodge it. ...
Allow the alcohol to dry. ...
Use compressed air to blow away any dislodged grime.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345534 02/09/20 06:35 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I too was taught to clean circuit boards in water and non-abrasive detergent, such as spicnspan.
Use a paint brush for some gentle scrubbing.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345537 02/09/20 06:35 PM
W
W
Hi Rand. It is a John Deere X585 Garden Tractor with a 25 hp water cooled Kawasaki. The board controls the fuel injection system and not sure what else.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345548 02/09/20 06:59 PM
N
Neely97 Offline
N
Get these guys.
[Linked Image from aat-corp.com]
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345551 02/09/20 07:05 PM
A
AC1DD Offline
A
@Neely97
That'a cool pic.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345568 02/09/20 07:18 PM
Z
ZeeOSix Offline
Z
The circuit board is open to the environment?
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345576 02/09/20 07:30 PM
Dave9 Offline
We'd need GOOD pics of the board to see what components are on it.
"Most" don't mind getting wet, but some do.
"Some" of those that mind, can be covered.
"IF" you can't get it wet then you need to use electrical contact cleaner after the initial prep steps of getting the majority of the big particles off.
"IF" it has an EPROM you need to be careful about stray ESD using a brish.
"IF NOT", you can use a dry brush to first get off the bulk of the material.
"IF" the board can get wet, you can use hot, strong, detergent solution and submerge the board and use a soft bristled (paint, etc) brush to dislodge gunk. If it's can't get wet, you'll be doing that with residue-free electrical contact cleaner.
"IF" the grime is only cosmetic except for the the electrical contacts to wiring harness, you may not even need to get the whole board clean, just those electrical contacts. How to clean those depends on whether they are gold or silver plated and just need grime cleaned off, or tin with a median amount of oxidation, or brass with a lot of it. Tin can usually be cleaned with a paper towel/etc and contact cleaner. Brass needs a brass cleaner then a rinse if it leaves behind an anti-oxidative film, or abrasion cleaning if it is more readily exposed to facilitate that.
Relays, if not sealed, should not be allowed to get contact cleaner inside unless it is a last ditch effort because they are shorting out and you need to use the equipment prior to having a chance to replace the relay. Relays that are sealed but have a breather hole covered with tape, might have the tap fall off if sprayed with contact cleaner. Worse things can happen but it is best not to get any inside.
If it's a full blown mainboard with a computer real time clock, the battery should be removed prior to exposure to water. Any socketed chips should be removed, following ESD safe procedures, before cleaning then reinserted after the board is dry.
After a detergent wash you can rinse with water that has alcohol in it to break the surface tension, or a drop of dishwashing machine rinse agent to break the tension, or worse case shaken gently, then blown dry. If it is a modern construction using water soluble flux, do not let pools of dissolved flux sit in any area while it dries as they can cause corrosion and short circuits.
If it has rosin core flux residue left behind and you use alcohol, then you should similarly make sure there are no pools of that muck left behind unless it is very hard from old age, not flowing anywhere.
Be very careful with compressed air, that velocity is not really needed and if the board flexes too much you risk breaking solder joints or components, depending on what's on it.
The next consideration is why it got so filthy. Does it have passive heatsinks and needs airflow to stay cool enough or was it just a substandard job sealing it from the elements? You might see whether you can improve that.
That's about it, I shouldn't have written this much before seeing pics.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345587 02/09/20 07:53 PM
Chris142 Offline
Spray electronics cleaner?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345591 02/09/20 07:59 PM
W
W
I can't get a pic. But if you google John Deere AM 132500 Ignition module you can see it. And these boards are subject to lots of moisture.
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345593 02/09/20 08:01 PM
sloinker Offline
Careful with commercial electronic contact cleaner. Some styrene plastics won't hold up. I second the alcohol or plain water method but only on certain electronics.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: How To Safely Clean A Circuit Board [Re: walterjay] #5345603 02/09/20 08:12 PM
Z
zzyzzx Offline
Z
Wash it with water and a toothbrush in a sink. Dry completely before reinstalling. However, if those rectangles are relays I would keep the water away from those or use another method. The bottom of the board I would be OK with water and a toothbrush. I suspect that the dirtiest part is the top part though.
