Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
56 registered members (97f150, bachman, 74Widebody, 2013ecof150, ArrestMeRedZ, alphadog, 4 invisible), 1,275 guests, and 22 spiders.
Topics301,810
Posts5,203,157
Members70,784
Question about changing oil by month or mileage? #5345388 02/09/20 03:06 PM
B
boostedtsiawd Offline OP
B
So the last time the previous owner changed the oil on my car was at 122,418 miles fully synthetic and now the car has 129,400 but the thing is he changed it back in March of 2019 and it should be done every 10k miles according to the owner's manual but its almost been a year so should it still be ok? I plan on changing it soon either way just wanna know what your opinions are on that? He was a old man who didnt put much mileage on it just use to go to work and home pretty much.
2006 AUDI A8 4.2
[Linked Image]
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345393 02/09/20 03:09 PM
Brian553 Offline
I would change it based on operational time. Does it have an hour counter?
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345405 02/09/20 03:26 PM
Dave9 Offline
If he was short tripping his mileage, then it may be past due for an oil change, but since you are the new owner, now YOU establish the OCI you want to have based on YOUR driving scenarios.
However I dispute the idea that he didn't put much mileage on it if it has been 7K in less than a year. That may not be an average mileage but is far from low, and yet if all he did was go back and forth to work, possibly it wasn't short tripped at all to get 7K/yr.
If you want to do it yearly, sure now is a fine time. It won't hurt to change oil every day, just waste oil and time. wink You're close enough that you might as well change it when that is convenient.
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345406 02/09/20 03:27 PM
K
ka9mnx Offline
K
Once a year but it would be nice to know what vehicle and engine.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345426 02/09/20 03:56 PM
M
Mad_Hatter Offline
M
I've always done a couple of short oil changes on a new to me car with a good cleaning oil like PYB. And check all your fluids and service them unless they've been recently done.
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345443 02/09/20 04:16 PM
A
ARCOgraphite Offline
A
I do the oci when you get a chance in the next month or two.
Has the engine had a timing chain serviced?
These are very complex .
[Linked Image]
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Question about changing oil by month or mileage? [Re: ARCOgraphite] #5345446 02/09/20 04:22 PM
B
B
[Linked Image]
The timing belt and water pump were replaced at 77K miles.
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345484 02/09/20 05:33 PM
I
Ihatetochangeoil Offline
I
Anything that anyone says, including the Oil Life Monitor, is all speculation until you have a Used Oil Analysis done by a test lab.
No one knows what kind of oil or driving conditions have been used/encountered, how do you expect an intelligent answer?
An honest answer is perhaps you're OK; most likely you're OK, my two cents is that "an old man" who had his timing belt and water pump replaced at 77K miles probably took decent mechanical care of the car.
Change the oil when it is convenient to do so for you, find something more important to obsess over.
https://www.bobistheoilguy.com/foru...-change-since-2013-should-i-be-concerned
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345505 02/09/20 05:55 PM
2
2K2AcuraTL Offline
2
For me its a balance of both....
typically, winter OCI get changed early... lots of city stop-go and short distance, sometimes in extreme cold >> possible condensation and fuel dilutions issues...
IMO this season is harder on oil rather than the engine itself.
summer OCI, on average run longer.. because of more highway miles
my 2c
J.
2002 Acura TL-P --- 2013 Acura MDX-Elite --- 2008 Civic
ALL on PP and PP Ultra & Petro-Can Duradrive synth ATF
2007 Chev Trailblazer LT
1998 Pontiac Transsport
1984 Firebird SE
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345510 02/09/20 06:05 PM
T
Triple_Se7en Offline
T
Desired Mileage, unless the vehicle idles long spells or in much stop & go traffic. That's when you shorten the OCI, but at your discretion.
I have let new oil stick for only a few weeks. I've also let it stick for two years. It all depends on how the engine's being driven and how often. Depends on how the dipstick looks after a couple hard-driven OCIs.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345622 02/09/20 08:28 PM
CT8 Offline
If you have to ask change it.
2015 F150 2.7
2018 F350 6.2
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345678 02/09/20 09:15 PM
O
oldhp Online Content
Online Content
O
All of my stuff is by time now. I'm retired so don't do a lot of miles now. 4 months is the max now.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345684 02/09/20 09:21 PM
G
Gebo Offline
G
I'm a 6 month, 3K man myself. $20 for an oil change with Toyota filter makes this a no brainer for me.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Question about changing oil by month or mileage? [Re: boostedtsiawd] #5345761 02/09/20 11:01 PM
T
tiger862 Online Content
Online Content
T
I was doing 3k then 6 month or 5k then 5k. I hit 5k in 9 month time frame so now I am rethinking it and see if I can go once a year which is less than 7500. As far as oil it was Conventional, High Mileage, Synthetic and now Synthetic Blend but will go with Synthetic on next oil change to see if OLM or year comes first. Keep in mind this is over 40 years of changes. Oils today are much better than yesteryear. We even have a new oil specification that will be out in May that should help engines last longer with less oil changes.
Tiger862
2018 Grand Caravan
