Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
73 registered members (brages, 4WD, Astro_Guy, bullwinkle, 2002 Maxima SE, 7 invisible), 1,497 guests, and 22 spiders.
Topics301,732
Posts5,201,620
Members70,766
Ravenol Oil specification and opinions? #5345289 02/09/20 12:08 PM
J
jssaab Offline OP
J
So I picked up a 2013 Jaguar XF 3.0 AWD Supercharged and modified it to 460 HP. ( Added a tune and Crank pulley)
Jaguar Spec oil Jaguar Land Rover STJLR.51.5122 I have read the car requires C5? (not familiar ) so it seems this poil matches that spec. 7 qts for $ 100 plus shipping
Ravenol data sheet lists the following Oil Specifications and Quality Standards:
ACEA C5
API SN Resource Conserving
ILSAC GF-5
Licensed: API SN Resource Conserving
Formal Factory Approvals:
Mercedes-Benz MB 229.7
[Linked Image]
Any thoughts on comparable oils in the US? Seems a bit hard to find.
2013 Jaguar XF 3.0 AWD Supercharged, Tuned 460HP Castrol Edge 5w-30 90k
2006 Saab 9-3 Aero 160K tuned 360 HP Mobil1 European 5W-30
Re: Ravenol Oil specification and opinions? [Re: jssaab] #5345306 02/09/20 12:35 PM
CleverUserName Offline
That looks like a quality oil by Ravenol.
That looks like a 0w20 based on the PDS? I’d be using something thicker in a modified vehicle. Like a 0w30 or 5w30 with similar specs.
Re: Ravenol Oil specification and opinions? [Re: CleverUserName] #5345310 02/09/20 12:53 PM
dbias Online Content
Online Content
Yeah I'd think with the mods stepping up to a 5w-30 might be ok.
https://www.ravenolamerica.com/motor-oil/5w-30-motor-oil-ravenol-vmp/
2011 VW JETTA RIP totaled at 180k 😥
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: Ravenol Oil specification and opinions? [Re: dbias] #5345340 02/09/20 01:34 PM
J
jssaab Offline OP
J
Good thoughts about the mods.
The engine is the same as the Jaguar R-S and R models (stock tuned Supercharged V8 engines that come wiht 425hp) with one less set of cylinders so I will look at those recommendations is 5W-20
Sad thing is that these engines is that timing gear are weak and a bear to replace. Trying to get some big miles out of it will require some paying attention
Re: Ravenol Oil specification and opinions? [Re: jssaab] #5345343 02/09/20 01:41 PM
K
kschachn Offline
K
ACEA C5
ILSAC GF-5
What is Mercedes-Benz MB 229.7 approval?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Ravenol Oil specification and opinions? [Re: kschachn] #5345433 02/09/20 04:01 PM
J
jssaab Offline OP
J
ACEA C5
ILSAC GF-5
Dunno ? Ravenol lists only JRL and MB ( these specific approvals) for this oil. They list lots of other manufacturers that should be "equivalent" but not specified
Re: Ravenol Oil specification and opinions? [Re: jssaab] #5345485 02/09/20 05:34 PM
Z
zeng Offline
Z
This oil is a Jaguar Land Rover STJLR.51.5122 0W20, which is a fuel economy long life oil with mid-saps 0.8 limit .
This oil should also carry VW 50800 50900 .
With mod and tune, as others advise, you should consider stepping up to xW30 . If i may add, with long life and midsaps features intact .
The closest that comes to my mind is any 5W30 (or 0W30) that carries VW 50400 50700 approvals bases on mid-saps C3 (not C5,fuel economy)
Re: Ravenol Oil specification and opinions? [Re: jssaab] #5345535 02/09/20 06:35 PM
J
JohnG Offline
J
Looked earlier, there is no MB 229.7 approval. Only 229.71, which is a 0W-20, Low SpAsh (MB term). Hence the C5 rating.
Quote
ACEA C5 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, for further improved Fuel Economy, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable and OEM-approved for use of Low Viscosity Oils with a minimum HTHS Viscosity of 2.6 mPa*s.
Re: Ravenol Oil specification and opinions? [Re: zeng] #5345589 02/09/20 07:57 PM
J
jssaab Offline OP
J
Thanks, I'v always use 0W-30 on my modified Saabs.
These cars are known to die of oil starvation (not sure if its due to people not checking the oil because it has an electronic oil level that requires active intervention to see (dumbest thing ever. You have a computerized car and it doesn't do the check and report on its own.
Also there are weak plastic chain guides. Not sure Jaguar chose a specific oil to compensate for these issues. Wold that change your suggestion ?
Re: Ravenol Oil specification and opinions? [Re: jssaab] #5345600 02/09/20 08:07 PM
sloinker Offline
I would consider Red Line for this application although Ravenol is also excellent oil.
https://www.redlineoil.com/euro-series-5w30-motor-oil
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Ravenol Oil specification and opinions? [Re: jssaab] #5345607 02/09/20 08:17 PM
Z
zeng Offline
Z
These acra are knwo to die die to oil starvation (not sure if its due to people not checking the oil because it has an electronic oil level that requires active intervention to see (dumbest thing ever. You have a computerized car and it doesn't do the check and report on its own.
No.
All the more the reason to switch/upgrade to VW 50400 50700 with minimum HTHS 3.5 cP, vis-a-vis min HTHS 2.6 cP in STJLR.51.5122 IF price isn't an issue ,never mind you aren't going Long Life change intervals .
If price IS an issue, go for VW 50200 50500 50501 (typically xW40) at standard interval , with extra/additional 0.1 or 0.2 cP HTHS if that matters.
Re: Ravenol Oil specification and opinions? [Re: kschachn] #5345618 02/09/20 08:25 PM
B
bbhero Offline
B
ACEA C5
ILSAC GF-5
You do realize someone might have actually hit the wrong number while typing that right smile
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Ravenol Oil specification and opinions? [Re: sloinker] #5345623 02/09/20 08:28 PM
J
jssaab Offline OP
J
I'll check it out thanks
Re: Ravenol Oil specification and opinions? [Re: bbhero] #5345670 02/09/20 09:08 PM
K
kschachn Offline
K
Absolutely, that's why I asked. I couldn't figure out which Ravenol oil it was to check their website.
1994 BMW 530i, 251K
Re: Ravenol Oil specification and opinions? [Re: kschachn] #5353934 02/18/20 07:27 PM
B
Big_B Offline
B
Looks like Ravenol ECS 0w20.
