Originally Posted by Gokhan
Originally Posted by Mad_Hatter
Q:...
- How long have VM's been around?
- How long have turbo's been around?
- Where's the graveyard of (t)gdi engines?
- What good are certs/approvals and the testing that goes into obtaining them?
My opinion, and you know what they say about opinions, is this (VII's) is waaaay "over thunk", on the heels of Gokhan's RGT v. T6 thread.
The VII is the number one enemy of the turbochargers.
See the Afton Chemical Corporation paper I posted and discussed:
GM turbocharger test: No correlation for deposits with TEOST 33C or moly
I'm not disputing that fact. What I am questioning is how much of this is "worry wart'ing"? I mean, doesn't Dexos Gen 2 already have a turbocharger deposit test as well as the mfgs, like XOM, having their own proprietary tests for oil deposits, varnishing and coking?? Is the suggestion here that the GM turbo coking test used for D1G2 (which RGT is certified) is now in some way insufficient in re today's turbocharged engines?
Fact is, unless you run a straight grade, you can't 'escape' VII's, so you're always gonna be a little bit pregnant..so to speak. ...
