Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
This is a good example of engineering today.
by Exhaustgases - 02/16/20 04:25 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
111 registered members (Aichiguy, 762fermeandyou, 4WD, alchargo, AndyB, 53' Stude, 12 invisible), 2,647 guests, and 36 spiders.
Topics301,518
Posts5,197,166
Members70,712
New radiator or Radiator bypass and add aftermarket cooler? #5345214 02/09/20 10:18 AM
Dogred08 Offline OP
I've got a 2006 Nissan Pathfinder SE 4WD with the potential problem of coolant and transmission fluid mixing in the cooler in the bottom of the radiator. I was wondering if I can get away with just bypassing the radiator cooler and adding a Hayden 679 external cooler. I feel like it would keep it cold enough I was just wondering if it would over cool it. I live in NC and sometimes it gets below freezing in the winter and I don't want to over cool it if it's possible. If I got a derale Transmission thermostat then it would end up costing as much as a new radiator. What would be the best option and do I really need the derale thermostat? Btw there is already a factory external cooler as well but it seems too small and I plan to tow occasionally.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345222 02/09/20 10:26 AM
J
JC1 Offline
J
Are you planning on changing the radiator? I would change the radiator to get the leak issue resolved. If there is a factory cooler already you are probably ok with towing using that existing setup.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: JC1] #5345227 02/09/20 10:31 AM
Dogred08 Offline OP
I wasn't planning on changing the radiator because it's not leaking I was just wondering about preventing it from possibly happening by bypassing the stock radiator cooler and adding an extra external cooler. I just didn't want to over cool the transmission if it's possible.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345235 02/09/20 10:37 AM
Astro14 Offline
If you don't want to cool it too much, then add the thermostat. Is total cost a big concern? You can do a thermostat, remote filter, and new plate-type cooler for about $150 in parts. Bypass the factory system, make changing the filter much simpler, and increase cooling.
Here's a write-up on how I modified my Volvo - note that I've done all three of them the same way, just have pictures from the first one. Now, in my case, I wasn't worried about contamination, so I left the factory radiator cooling loop in place. You could easily delete that loop to allay your concerns.
https://www.volvoxc.com/forums/showthread.php?27334-02-XC70-Transmission-Flush-From-Bottom/page2
I should add that this transmission is known for failing in Volvos of this year. I've got over 258,000 on the XC-70 on the original transmission. I contend that longevity is due to better cooling and reasonable fluid changes.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345239 02/09/20 10:40 AM
Spktyr Offline
Replace the radiator first. The reason for the Strawberry Milkshake Of Death is the original in-radiator coolers were a bit defective and would leak. Even if you bypass the stock trans cooler, you have the problem of it then just leaking coolant onto the ground when the cooler goes instead. Replacing the radiator has to be done first.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345242 02/09/20 10:41 AM
T
tcp71 Offline
T
if a new radiator has been updated and doesn’t have the same potential issue, I would go that route. You won’t overcool the fluid in SC if you choose to bypass and add a bigger oil to air cooler either, but the potential for the coolant in the original radiator to pass into the defective oil cooler is still a possibility, even when it has been bypassed, possibly leaking or getting contaminated, which is why I would replace the original radiator completely if possible with an updated version that won’t leak.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Astro14] #5345243 02/09/20 10:42 AM
Dogred08 Offline OP
Is the derale thermostat the best thermostat option? I already have the Hayden 679 I got a discount on it for about 38 bucks and the derale thermostat is around 50. And a new radiator of decent quality seems to be around 160. And there is already a filter in the pan so I'm not sure if an in line filter is totally necessary.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: tcp71] #5345245 02/09/20 10:44 AM
Dogred08 Offline OP
How could it still contaminate if it's completely bypassed? I was obviously gonna seal the Barb's on the end of the radiator to keep it from possibly leaking coolant on the ground.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Spktyr] #5345246 02/09/20 10:45 AM
Dogred08 Offline OP
What if I just seal the Barb's on the bottom of the radiator with vacuum caps?
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345250 02/09/20 10:53 AM
Spktyr Offline
The coolant could become contaminated. Capping the barbs off with vacuum caps and hose clamps isn't a great idea - those usually fail in a few months.
If you buy a new Nissan radiator, it will have all the fixes - some of the aftermarket ones are copies of the original, defects and all. Also, the plastic end tanks on those radiators mean they do eventually need to be replaced anyway - the similar one on my 4Runner finally failed this January after being in service some 20 years (and it probably should have been replaced 3-4 years prior due to developing issues that could be seen in visual inspection). The 4Runners also have the SMOD issue, though to a lesser degree and it takes longer than the Nissans do.
I would replace the radiator if for no other reason than age alone and then hook up the trans cooler you bought in series with the one in the radiator.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345258 02/09/20 11:00 AM
M
mk378 Online Content
Online Content
M
Any 15 year old plastic radiator is on borrowed time. If you're going to touch this at all, change out the radiator and be ready for another 15 years.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: mk378] #5345261 02/09/20 11:05 AM
Dogred08 Offline OP
What radiators would you recommend? They all look about the same just prices seem to vary. There's a no name on eBay for about 60 and prime choice on Amazon for 64 a koyorad for 141. And quite a few others but they all look the exact same is there really a difference?
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345263 02/09/20 11:12 AM
Spktyr Offline
Yes, there is a big difference. The Koyorad should be okay, they're a Nissan supplier and will have updated their product. The no-name or random aftermarket one will generally not hold up in a Nissan or Toyota and will likely have the same defective cooler design.
Go with a Nissan or Nissan OE radiator, don't go cheap. Don't forget to replace the radiator cap with Nissan or Nissan OE while you're at it.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Dogred08] #5345264 02/09/20 11:15 AM
Spktyr Offline
Also, Nissan has the Value Advantage line, which is aftermarket parts that pass Nissan testing. You can get that for less than the original - Rock Auto carries the Nissan Value Advantage version of the radiator for $204.
Rock Auto also sells a Denso radiator (another Nissan supplier) for $115.79, which would be what I'd get. Check any radiator bought through the mail carefully for damage, they're often not packed well.
Re: New radiator or Radiator bypass and add aftermarket cooler? [Re: Spktyr] #5345279 02/09/20 11:48 AM
Dogred08 Offline OP
Is a OSC radiator a good option I'm trying to avoid using Rock Auto I've had bad experience with them on defective parts. it has the brass Barb's and looks identical to denso
