Too close to home..
by Mad_Hatter - 02/28/20 10:03 PM
Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
107 registered members (4WD, A310, 69GTX, 55hambone, ammolab, 12 invisible), 1,780 guests, and 18 spiders.
Topics302,060
Posts5,208,292
Members70,826
2004 Toyota Sequoia No crank, no start #5345096 02/09/20 07:15 AM
B
bama7x57 Offline OP
B
2004 Toyota Sequoia SR5 4x4
I’m getting a no crank, no start after an engine replacement. All connections are plugged in.
I’m using the original harness from my vehicle. Every connector had a connection on new engine.
All lights come on dash, headlights and power windows, ect working fine. Battery is fully charged and engine ground is tight.
I’ve checked every fuse and swapped out one starter relay and checked the other with a meter.
I confirmed the neutral switch on transmission is plugged in and selector is all the way back in park.
Wiggling the shifter and trying in neutral has not worked.
Apply 12v to the starter solenoid and the starter engages.
Jumping the starter with key in run position, I do not have any spark, but I do have pressurized fuel in the fuel rail.
I’m using 2 different correct old keys.
Needing some suggestions
23 Buick Conv. 36K
99 F-250 TD 396K
99 K1500 Tahoe Z71 170K
01 K1500 Suburban 263K
04 K1500 Tahoe Z71 180K
07 K1500 Tahoe Z71 185K
07 K1500 Suburban 182K
Re: 2004 Toyota Sequoia No crank, no start [Re: bama7x57] #5345106 02/09/20 07:39 AM
G
GSCJR Offline
G
Check for 12v at the starter solenoid terminal while an assistant cranks.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 157KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: 2004 Toyota Sequoia No crank, no start [Re: bama7x57] #5345196 02/09/20 09:54 AM
Chris142 Online Content
Online Content
Something is not plugged in or plugged into the wrong spot.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2004 Toyota Sequoia No crank, no start [Re: Chris142] #5345203 02/09/20 10:05 AM
J
JMJNet Offline
J
x2, assuming the new engine is good.
  • 2017 Toyota Sienna
Re: 2004 Toyota Sequoia No crank, no start [Re: bama7x57] #5345213 02/09/20 10:17 AM
J
JC1 Offline
J
How about ground connections any missing or loose?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 2004 Toyota Sequoia No crank, no start [Re: JC1] #5345225 02/09/20 10:27 AM
M
mattd Offline
M
Assuming this is a 4.7, starter is not easily accessible as it’s under the intake manifold
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: 2004 Toyota Sequoia No crank, no start [Re: bama7x57] #5345249 02/09/20 10:51 AM
crainholio Offline
Salvage yard engines may sit for months or years between the pull and the sale, leaving things like fuel injectors and starter solenoids seized.
As mentioned above, next step is to check for 12VDC being sent to the starter solenoid pull wire from the relay while the ignition key is in the START position.
If no 12VDC on that circuit while the key is in START position, it's a wiring or control problem.
If you find 12VDC on that circuit while the key is in START position, it's a starter problem and likely the solenoid stuck/seized.
Re: 2004 Toyota Sequoia No crank, no start [Re: bama7x57] #5345500 02/09/20 05:46 PM
9
92saturnsl2 Offline
9
He mentioned that applying +12V to the starter solenoid results in a cranking engine.
Therefore there is no start +12v at the solenoid when the key is turned. Anti-theft system would be my best guess, if it has one...
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
Re: 2004 Toyota Sequoia No crank, no start [Re: bama7x57] #5345648 02/09/20 08:44 PM
1
14Accent Offline
1
Are the 30A ST fuse and 7.5A STA fuse under the hood good? The 30A powers the starter S terminal through the starter relay, the ignition switch sends +12v through the STA fuse to the start signal input on the ECM. The ECM actually controls the +12v side of the starter relay, from what I can see, the ground side of the relay coil windings are constant.
Here's the starter relay wiring:
Pin 1 is a BLK/RED wire that should have +12v when cranking. This comes from the ECM.
Pin 2 is a WHT/BLK wire that should have continuity to ground at all times.
Pin 3 is a BLK/WHT wire that should have continuity between the relay and the starter S terminal.
Pin 5 is another BLK/RED wire that should have +12v at all times.
An easy test to start would be to jump pins 3 and 5 at the starter relay, with the relay removed. If it cranks over, that part is fine. Then you're looking at an ECM inhibit situation, most likely.
That being said, have you pulled codes? Not just generic, but OEM level. There could be useful information there.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 2004 Toyota Sequoia No crank, no start [Re: 92saturnsl2] #5345997 02/10/20 09:34 AM
W
wag123 Offline
W
+1
