Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
32 registered members (97prizm, AurionX2, BlueOvalFitter, Blkstanger, carlprop, Aichiguy, 1 invisible), 913 guests, and 16 spiders.
Topics301,813
Posts5,203,176
Members70,784
Amsoil Ea15k12 cut open #5344916 02/08/20 08:52 PM
cronk Offline OP
Just changed the oil on the wife's Nissan Quest. This Amsoil filter was in service about 10 months and 8k miles. Fill was Amsoil Signature series 0w40.
Another good looking Amsoil filter.
Wire backed media looks good and sturdy construction all around.
Same filter and oil went back in and on.
Will be interested in the next filter cut on this as the new Amsoil filter looks like a new design, had black texture grip paint and claims 99% at 20 micron instead of 98.7%.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Amsoil Ea15k12 cut open [Re: cronk] #5344918 02/08/20 08:55 PM
cronk Offline OP
I think camera angle makes the seam pleat look crooked, it is actually not. Here is a better pic.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
Re: Amsoil Ea15k12 cut open [Re: cronk] #5344931 02/08/20 09:18 PM
T
Triple_Se7en Offline
T
The media looks like it worked hard for that 8K run. But that could be due to it's small size.
Nice quality on both the oil and filter.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Amsoil Ea15k12 cut open [Re: cronk] #5344950 02/08/20 09:54 PM
O
oilboy123 Offline
O
I've cut a few EA filters up. The screen that supports the media is pretty tough. As is the media. Makes the media appear saturated.
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
Re: Amsoil Ea15k12 cut open [Re: cronk] #5345061 02/09/20 05:16 AM
Sayjac Offline
Champ Labs made. I've seen noted that the Wix/Napa Gold 5/7356 element (which I use), seems small to some. That said, pretty sure it significantly larger than topic. That said, this would be the 6607 equivalent filter. Looks fine, like it got the job done.
Ever considered using the 7317 application size in the Quest? It's what I use in an extended family Nissan Rogue now.
Thanks for c&p.
Re: Amsoil Ea15k12 cut open [Re: Sayjac] #5345092 02/09/20 07:12 AM
cronk Offline OP
Thanks for c&p.
I have considered using the longer Nissan filter size. It sits sideways and there is a splash shield that is near the end. I suspect I probably have room for it.
The small filters never seem like they have much of anything in them, so I don't worry much about it.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
Re: Amsoil Ea15k12 cut open [Re: cronk] #5345101 02/09/20 07:28 AM
53' Stude Offline
Looks good sir. Did you put another of these filters back on? What oil went back in? Thank You
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Amsoil Ea15k12 cut open [Re: 53' Stude] #5345150 02/09/20 08:43 AM
R
Rat407 Offline
R
2002 Silverado 5.3 0w-20 AMSOIL®
Re: Amsoil Ea15k12 cut open [Re: cronk] #5345220 02/09/20 10:23 AM
Sayjac Offline
...I have considered using the longer Nissan filter size. It sits sideways and there is a splash shield that is near the end. I suspect I probably have room for it......
2017 2.5L Rogue has a same orientation and similar shield, no issue with the longer 7317 installed. In fact, never seen a Nissan where it didn't fit.
You're correct though, either will work. I just figure same cost, same specs with more media area in the ~3/4" longer filter. Same case with the sae thread 4967 vs 4386 used on Toyotas.
Re: Amsoil Ea15k12 cut open [Re: 53' Stude] #5345553 02/09/20 07:07 PM
cronk Offline OP
Same Amsoil filter and Amsoil Signature series 0w40 went back in/on.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
Re: Amsoil Ea15k12 cut open [Re: cronk] #5345704 02/09/20 09:37 PM
K
kstanf150 Offline
K
Filter looks fine
But doesn’t look any better or worse than a Fram XG for less money
Thanks for the post
Re: Amsoil Ea15k12 cut open [Re: cronk] #5345719 02/09/20 09:52 PM
SubieRubyRoo Offline
Thanks for C&P... is the air filter on the Quest in good shape? That looks filthy for only 8k miles (but at least that part isn't in the engine anymore)... maybe Nissans just put lots of particulates/insolubles into the oil. That engine isn't GDI, is it?
De omnibus dubitandum.
Re: Amsoil Ea15k12 cut open [Re: SubieRubyRoo] #5345724 02/09/20 09:58 PM
cronk Offline OP
The media is actually not very dirty at all, It always looks worse in pictures than it does in person.
The bits of debris in the photos is from me cutting the filter open with an air grinder with a cutoff wheel.
The micro glass media kind of glistens when it is oil soaked, and almost looks like a layer of sludge on the media.
Maybe next one I'll wrap in some paper towels to dry out the media for a better pic.
Oil had darkened some but was still a dark amber on the dipstick.
I did check and replace air filter, as this was the 100k service, old air filter still looked nice though.
Also got new NGK Ruthenium plugs, new pcv valve, and a drain and fill of Amsoil CVT fluid.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
Re: Amsoil Ea15k12 cut open [Re: cronk] #5345729 02/09/20 10:06 PM
Cool! Syn media also usually looks darker. You're good on the maintenance side, definitely investing in that thing to keep it ship-shape! thumbsup
Re: Amsoil Ea15k12 cut open [Re: cronk] #5345790 02/10/20 12:25 AM
B
bbhero Offline
B
Very good job there man...
I am like sayjac in that I typically run a longer 7356/7317 oil filter on my VQ motor... Easier to get a holt of if for me smile
I'm heading towards 300,000 miles on my VQ motor... Got 296,600 miles right now. . Bought the car with only 39,990 miles.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
