Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
Tgarst, Predator35001819, Markapuu, jds59, JimMorrison
70728 Registered Users
113 registered members (ArrestMeRedZ, 01VFR, Alfred_B, Astro14, 3311, 14 invisible), 1,989 guests, and 26 spiders.
Topics301,594
Posts5,198,671
Members70,728
Recommend a 5w-30 for my Chevy Volt #5344693 02/08/20 02:08 PM
dvancleve Offline OP
Howdy folks.
My family recently purchased a Volt that has relatively high ICE/gas miles (probably close to 100K) compared to most. I have all the receipts for it from day one, and it looks like it generally got partial syn Dexos 1 at various GM dealerships. The OLM is currently at 48%, but I would like to get full syn in there and it might be a long time until it says to change it. I would like to run whatever has the best cleaning ability, seems to me like PUP used to be considered best for that but I'm not sure that is still true. I have a 5qt jug of M1 AFE that I won't use in any of my other cars, so if that is as good as anything I will happily use it.
Only semi-related, is it safe to use full syn, Dexos 1 5w-20 in the Volt? The manual is very specific about the Dexos rating, less clear on whether some other viscosity that is Dexos rated is okay. Again, if I can use this without harm in the Volt at some point, I will. I was planning on running it it my now-totaled '06 Prius, which called for 5w-30 but not sure about the Volt...
Thanks, Doug
1962 & 1968 VW sunroof Bugs
2007 Subaru OBXT Ltd. 5MT, ~75K mi
2013 Chevy Volt, ~130K mi
2013 VW Beetle 2.0 gas turbo convertible, ~36K mi
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344698 02/08/20 02:14 PM
CT8 Offline
What does the owners manual recommend for viscosity and why would some one buy a vehicle where the engine would need a cleaning? I am trying to learn.
2015 F150 2.7
2018 F350 6.2
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344700 02/08/20 02:16 PM
Snagglefoot Online Content
Online Content
Ditto. The 2015 owners manual asks for 5w30. What year is yours? (OP).
If you want the job done right......do it yourself.
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344703 02/08/20 02:21 PM
J
JohnG Offline
J
How are you going to use the vehicle?
And how do you know how many ICE miles are on it?
If the previous owner charged at home and drove under 50 miles back and forth to work (which this car was designed for) then you will have ZERO miles on the engine.
Anyway, it probably says Mobil1 on the oil filler cap. Not direct injected engine, so any Dexos1 oil should be fine.
For engine cleanliness at this point, I like the Pennzoil Platinum GTL technology, but that's just me.
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344729 02/08/20 03:20 PM
So, here is what I know or at least suspect. My Trip B shows 99999.9 miles, which I'm pretty sure means it has never been reset and that it maxes out at 100K miles. It shows 2171.5 gallons used and 61.1mpg, which is weird because multiplied out that gets 132, 678 miles which is really close to the odometer reading of 132,672. So it seems like the gallons and mpg average are current even though the mileage stopped? Anyway, pretty certain it has a lot of highway miles and relatively few EV miles compared to most Volts.
The owners manual says "Use only engine oil licensed to the dexos1 specification, or equivalent, of the proper SAE viscosity grade. ACDelco dexos1 Synthetic Blend is recommended." and "SAE 5W-30 is the best viscosity grade for the vehicle. Do not use other viscosity grade oils such as SAE 10W-30, 10W-40, or 20W-50. Cold Temperature Operation: In an area of extreme cold, where the temperature falls below−29°C(−20°F), an SAE 0W-30 oil may be used." So it is very clear about the Dexos requirement, not so much about viscosity IMHO, excluding heavier grades.
The car was very well cared for, better than if I had owned it the whole time. I have no reason to think the engine "needs" cleaning, just that is has done more ICE driving than most Volts and probably with semi-syn only. If there is something I can throw in there that is better than average for clealiness, seems like a good idea wink In the near future, most of the mileage will be EV but it will probably be our road trip car since nobody wants to drive my Outback XT with stick shift and it gets pretty bad fuel economy.
Thanks again, Doug
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344737 02/08/20 03:35 PM
A
atikovi Online Content
Online Content
A
Looks like 5W30 it is.
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344742 02/08/20 03:49 PM
Online Content
Pennzoil Platinum 5w30 will be fine as would any other 5W30 Dexos D1G2. smile
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344753 02/08/20 04:08 PM
V
Villalobos Offline
V
I like OEM.
2000 Suburban 250k
2014 MKX 100k
2015 IS250 50k
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344754 02/08/20 04:15 PM
T
Triple_Se7en Offline
T
Any SN Plus certification will do the job. What's more important is avoidance of overworking / overstaying the oil.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344838 02/08/20 06:40 PM
spasm3 Online Happy
Online Happy
I would probably run mobil extended performance 5w30.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344869 02/08/20 07:29 PM
J
JohnG Offline
J
At least you have an answer to your oil question.
This really brings up a lot of questions for me though. I think your assumptions are correct on the mileage estimates, at least they appear to be. It also seems like the previous owner went by the OLM for oil changes, which is also a good thing. If he went by time, the manual says to change it every TWO years.
But this car was never rated at 61.1 MPG! Every review and everything put out by the EPA stated somewhere near 36 to 40 mpg tops! Now we find that all that was wrong, and in fact it gets better fuel economy (Not being used properly) than a PRIUS! This just can't be possible. How can so many people be wrong?
Now, speaking from my own time as a Volt owner, in 4 years I averaged about 195 MPG, which is as far as the computer would calculate it. But I plugged mine in at night, used regen braking as much as possible, and drove short trips. Hardly ever used to gas engine. In fact, I'd put about 9 gallons of gas in a year. Sometimes the fuel quality minder would run the engine just so the gas would not go bad in the tank!
Looking at it another way though, you should have an almost brand new propulsion battery. As for the starting battery, that might be a whole other matter! Enjoy your new car, you're going to love it!
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344920 02/08/20 09:02 PM
M
mattwithcats Offline
M
Mobil 1 AFE in 0W-30 is Dexos 1 rated.
If you look in the “Product Rebates, Sales, And Promotions” at the bottom of the forum list, Pennzoil has a $22 rebate until February 23...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Recommend a 5w-30 for my Chevy Volt [Re: JohnG] #5344966 02/08/20 10:26 PM
Thanks JohnG! I assume the 61.1 is my total mpg, gas and electric combined since the car was new. I don’t know what straight up highway ICE/gas mpg is on this or any Volt, I’ve been told 40 is a reasonable guess. The other thing that puzzles me about mine is the center display shows 57.2 lifetime mpg whereas Trip B shows 61.1mpg. We charge it when we can, but we also have a Fiat 500e and only 120v charging. They can’t charge at the same time, and obviously the Fiat gets priority since no charge equals no drive on that one. One thing I did that I wish I had not done is fill the tank before I even got it home from buying it. Oh well, eventually it will go on a road trip and burn that up... Doug
Re: Recommend a 5w-30 for my Chevy Volt [Re: mattwithcats] #5344969 02/08/20 10:29 PM
Thanks, I’m a bit torn. The Mobil 1 AFE is not suitable for my wife’s VW turbo or my Subaru turbo, so the Volt is the only place it can go and it’s good stuff… OTOH, I’d probably prefer to put PUP 5w-30 in it since it might be in there for two years. What to do, what to do…
Re: Recommend a 5w-30 for my Chevy Volt [Re: dvancleve] #5344998 02/08/20 11:39 PM
O
oldhp Offline
O
Mobil 1 AFE 5W30 for the WIN and fuhgedaboudit. cheers
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
