Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
19 registered members (3311, Compagnion, blufeb95, bbhero, BlakeB, Cdn17Sport6MT, 2 invisible), 902 guests, and 16 spiders.
Topics301,684
Posts5,200,467
Members70,756
6T70E fluid drain and fill 2015 Malibu #5344692 02/08/20 02:03 PM
ls1mike Offline OP
Used in a bunch of GM stuff from 2007 until 2015. (Equinox, Malibu, SRX, Impala, Vue, Terrain, and some other stuff I am forgetting.)
Plus I think in some Ford stuff as a 6F60/6F55 it was a joint venture. The plug and fill are the same spot on Ford.
This transmission was used in A LOT of stuff.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
A complete fluid swap is about 9.5 quarts. A drain and fill is 5 to 5.5 quarts.
There is no serviceable filter. You have to split the transmission case to get to it.
I needed a funnel, 11mm socket and drain pain. Easiest drain and fill I have ever done.
I think it took me 30 minutes. Fluid was dirty but not horrible. I will do another drain and fill next oil change.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 6T70E fluid drain and fill 2015 Malibu [Re: ls1mike] #5344695 02/08/20 02:09 PM
Mr Nice Offline
To properly measure the ATF level did you need a scanner and have to reach ____ F degrees ?
Or simply drain and measure old fluid , add the same amount and Check dipstick ?
I hate some vehicles no longer have a dipstick to check ATF.
Re: 6T70E fluid drain and fill 2015 Malibu [Re: Mr Nice] #5344697 02/08/20 02:11 PM
ls1mike Offline OP
Or simply drain and measure old fluid and add the same amount and Check dipstick ?
It has a dipstick. Got it up to temp and made sure it was in the same spot as before I refilled it, Plus anal me measures how much I took out and how much I put in.
GM's own procedure is to get it up to temp run it through the gears and then check it. Really easy.
I need to do the Caprice. That is a no dipstick, use the weep hole procedure...blah.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 6T70E fluid drain and fill 2015 Malibu [Re: ls1mike] #5345075 02/09/20 06:12 AM
J
joekingcorvette Offline
J
I wish my Chevrolet Corvette was that easy. My Honda is easy and I wish all cars and trucks were that simple.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: 6T70E fluid drain and fill 2015 Malibu [Re: ls1mike] #5345303 02/09/20 12:26 PM
J
JTK Offline
J
Nice! Was this the first drain/fill? Good to know it's so easy to do on those year ranges.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 6T70E fluid drain and fill 2015 Malibu [Re: ls1mike] #5345337 02/09/20 01:24 PM
K
KrisZ Offline
K
Nice, its easier than a regular oil change since no filter has to be touched. How much does it cost at the dealer for such an easy service?
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: 6T70E fluid drain and fill 2015 Malibu [Re: JTK] #5345625 02/09/20 08:29 PM
ls1mike Offline OP
First one, didn't look too bad. I was actually surprised.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 6T70E fluid drain and fill 2015 Malibu [Re: KrisZ] #5345626 02/09/20 08:30 PM
ls1mike Offline OP
I don't know, they usually do a flush which is 179.00.
Will do another drain and fill at the next oil change.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 6T70E fluid drain and fill 2015 Malibu [Re: ls1mike] #5345674 02/09/20 09:10 PM
P10crew Offline
Thanks for posting Mike.
What fluid did you use?
Re: 6T70E fluid drain and fill 2015 Malibu [Re: P10crew] #5345709 02/09/20 09:43 PM
ls1mike Offline OP
GM Dexron VI
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
