How do you grease rakc and pinion inner tie rod ends? Going to be doing a front even overhaul with Moog on my F150 and would like to pre-grease the inners with my moly grease. They do come decently greased with a blue, likely lithium, grease. I notice there are little holes 180 degrees apart on the wrench flats on the socket as well as one at the very end of the socket threads, can I just a injector nozzle to force grease or is it not a patent lumen to the ball socket? These ends don't have a dedicated grease boot as they are contained within the r&p boot. You can kind of see one of the holes I'm talking about at the top of this picture:
Moog EV800457
Moog EV800457
