The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
41 registered members (14Accent, 1WildPig, 74Widebody, 3311, 69GTX, 4 invisible), 1,068 guests, and 17 spiders.
Topics301,682
Posts5,200,442
Members70,756
rear clunking noise found, bearing or cv axle? #5344627 02/08/20 12:46 PM
T
tookien Offline OP
T
I was trying to find the source of rear clunking noise, and finally found it.(rav4 2003)
The cv axle has in and out play where it meets the wheel hub/bearing assembly. (not at the differential)
But I'm not sure if it's the cv axle that is the problem or the wheel bearing itself.
There is no bearing type noise or symptoms of bearing problems, just clunking noise. Could it still be the bearing or is it just the axle itself?
Re: rear clunking noise found, bearing or cv axle? [Re: tookien] #5344691 02/08/20 02:03 PM
Chris142 Offline
Is the big nut loose?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: rear clunking noise found, bearing or cv axle? [Re: Chris142] #5344702 02/08/20 02:18 PM
T
tookien Offline OP
T
The CV axle nut? No. I tried to torque it down and it's already torqued to max.
Re: rear clunking noise found, bearing or cv axle? [Re: Chris142] #5344712 02/08/20 02:43 PM
T
tookien Offline OP
T
It's also the same on both sides.
Clunking noise is apparent coming from OUTER CV joint when pulling on the shaft while car is raised.
It appears the problem is inside the boot because I can't see any other movement otherwise.
All other suspension components are fine including stabilizer bar, links, as well as control arms etc....
So is it safe to say the CV axles need to be replaced?
Thanks
Re: rear clunking noise found, bearing or cv axle? [Re: tookien] #5344727 02/08/20 03:14 PM
M
mk378 Offline
M
Those rear axles may be designed for in and out movement at the outer joint, instead of the inner as is universal on front wheels. One of the joints must allow the axle to move in and out. When the car hits a bump it changes the angle of the axle, so the length of the axle must also change.
The real sign of a bad CV joint (inner or outer) is rotational play. With the tire off the ground, hold the axle still while turning the wheel. The parts of the joint should move together.
Re: rear clunking noise found, bearing or cv axle? [Re: mk378] #5344732 02/08/20 03:23 PM
T
tookien Offline OP
T
How does turning the wheel make any sense when this is for the REAR CV axle?
So the loud clunking noise which is clearly coming from the rear outer axle when I'm pulling it in and out is normal?
Re: rear clunking noise found, bearing or cv axle? [Re: tookien] #5344735 02/08/20 03:30 PM
Dave9 Offline
Hubs don't generally clunk, so yeah the CV is the prime suspect. It is the conventional design with movement at the inner joint not outer.
Turning the wheel means the tire/rim not the steering wheel. Play would be slop when you turn it one way then change the direction and turn it the other way. We're not talking about spinning the wheel, just observing play changing wheel direction wiggling it back and forth between forwards and backwards rotation.
You want to observe whether the rotational slack is happening at the joint based on how much the CV shaft after it is turning with the wheel, and of course a clunk sound or feeling.
Re: rear clunking noise found, bearing or cv axle? [Re: tookien] #5344736 02/08/20 03:30 PM
M
mk378 Offline
M
My point is that some joints are made to move in and out, but a bad joint will be loose in other dimensions as well. Not knowing the specific design of the car but that you had similar motion on both sides I was guessing it could be a design feature.
Re: rear clunking noise found, bearing or cv axle? [Re: Dave9] #5344744 02/08/20 03:52 PM
T
tookien Offline OP
T
Oh okay thanks for clearing that up.
Re: rear clunking noise found, bearing or cv axle? [Re: mk378] #5344751 02/08/20 04:04 PM
T
tookien Offline OP
T
Thanks. I know what you mean about the design feature. My previous vehicle had that slight in out movement at the cv axles by design.
I checked every single suspension component and re-torqued (stabilizer bar, links, control arms etc...,which were all replaced anyways due to rust) and the outer CV is the only one making the clunking noise, it's loud enough that I can tell it's the exact type of noise which I believe is being transferred over into the cabin.
I had to lift the car to relieve tension and I can feel and hear consistent clunking while pulling the cv axle shaft...
Re: rear clunking noise found, bearing or cv axle? [Re: tookien] #5344752 02/08/20 04:05 PM
T
tookien Offline OP
T
Really appreciate all the help. Will do some more diagnosis but it seems the rear CV axles need to be replaced at some time as I cannot find any other source for the clunking.
Re: rear clunking noise found, bearing or cv axle? [Re: tookien] #5344760 02/08/20 04:20 PM
Dave9 Offline
You wrote "axles". While it is possible that both are the factory axle and both have similar wear, it is not necessary to replace both at the same time, won't cause any *imbalance* like non-matching shocks/tires/brakes would.
If you're having a shop do the work, I might have them do both sides if there's a significant cost savings but as far as DIY, I'd start by just replacing the questionable side unless you need it in tip top condition for a long road trip, or are going offroading.
Re: rear clunking noise found, bearing or cv axle? [Re: Dave9] #5344765 02/08/20 04:27 PM
T
tookien Offline OP
T
DIY. But the problem is both sides.
Weird huh?
Maybe I'll do a video of it tomorrow and post it here.
Re: rear clunking noise found, bearing or cv axle? [Re: tookien] #5344791 02/08/20 05:19 PM
T
Trav Offline
T
The inner joint is a tripod on this cv axle and it is supposed to have in and out movement as the suspension travels and a very minor amount of play is normal.
Re: rear clunking noise found, bearing or cv axle? [Re: Trav] #5344792 02/08/20 05:20 PM
T
tookien Offline OP
T
But this is the outer joint
