1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
21 registered members (Bjornviken, dlundblad, Brian553, ctechbob, Gokhan, 4 invisible), 1,124 guests, and 17 spiders.
Topics301,933
Posts5,205,754
Members70,801
Page 1 of 5 1 2 5
Fram Ultra Bad? #5344504 02/08/20 10:30 AM
7
762fermeandyou Offline OP
7
Hi all,
Before X-mas I bought a 6 pack of Fram Ultra XG8A from Ebay for my 4.0 Jeep ($24.00 shipped!). Seemed like a great deal. These are the 15,000 mile filters. Just opened 1 up to fill with oil and it rattled. I can shake it and something is loose in the bottom of the can. The others don't rattle. Later I will saw it open to check it out. Installed one with Havoline oil, no leaks or noise. Wonder if anyone has had this experience. The knowledge on this site is incredible. Thanks.
62 Mercury Meteor 5.0 10w30 VPB blend / FL1A
95 Jeep ZJ 4.0 5w30 Havoline Conv / Rislone ZDDP / XG8A
15 Silverado 5.3 0w20 QSUD / PF63E
17 Explorer 3.5 N/A 5w20 Napa syn / Napa Proformer
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344521 02/08/20 10:45 AM
V
Vern_in_IL Offline
V
Send it back to Fram for a replacement. If you saw it open you void your warranty.
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344525 02/08/20 10:47 AM
Sayjac Offline
Based on the description, reads like a compromised compression spring. Been at least one other similar anecdote posted here before. I would not use it. Return for replacement if possible.
Cause of other similar anecdote was claimed filter dropped at some point prior to use. To his knowledge, purchaser said otherwise.
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344529 02/08/20 10:53 AM
F
Farnsworth Offline
F
This is an issue with them. loyalists try to sweep it under the rug. To me it’s just another oil filter. The element is heavy so it can knock the spring harder. It’s a lot heavier with the thick mesh. This is where a coil spring is better.
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344534 02/08/20 10:57 AM
Chris142 Offline
Send it in. They may send you extras for your troubles.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Fram Ultra Bad? [Re: Chris142] #5344536 02/08/20 10:59 AM
JohnnyJohnson Offline
Or perhaps tell you its a counterfeit.
2004 Corolla 139139
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344541 02/08/20 11:07 AM
69GTX Offline
You still got 5 filters for under $5 each. Wow. I wouldn't complain about that one bit. Normally these 6 packs sell for $36-$40 on line.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Fram Ultra Bad? [Re: JohnnyJohnson] #5344547 02/08/20 11:14 AM
7
7
Thank you all for the replies. Yeah I wont use it, but sending it to Fram is a good idea. The box has the Mileage minder thing stuck inside, filters don't look abused, boxes are shelf worn, counterfeit, that would be interesting.... Chris142, thanks for all the Jeep 4.0 info you post at BITOG and Jeep sites, helps me out alot. Take care guys, If I get a respond from Fram, I will post back. Ken
Re: Fram Ultra Bad? [Re: 69GTX] #5344558 02/08/20 11:31 AM
7
7
Yes a decent deal, however these are NOS. New ones are 20,000 mile. I change filter every oil change for piece of mind so mileage capability is of no concern.
Re: Fram Ultra Bad? [Re: JohnnyJohnson] #5344584 02/08/20 12:00 PM
G
Gebo Offline
G
Sounds possible.
Be interested in finding out if they are the real Frams.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344601 02/08/20 12:20 PM
Sayjac Offline
Not the anecdote I was thinking of/referencing earlier, another one with same filter, similar description linked. Topic XG8A is a relatively large filter application too.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4611938/1
Being more a believer in Accam's Razor and less in conspiracy theories and tin foil hats, similar anecdote added I'll stick with previous explanation, compromised compression spring.
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344604 02/08/20 12:23 PM
CT8 Offline
While all filter brands can fail, the leaf spring is a deal breaker other than that is a great filter for the money.
2015 F150 2.7
2018 F350 6.2
Re: Fram Ultra Bad? [Re: Sayjac] #5344605 02/08/20 12:25 PM
W
Wolf359 Online Content
Online Content
W
Originally Posted by Sayjac
Not the anecdote I was thinking of/referencing earlier, but another one with same filter, same description linked. Topic XG8A is a relatively large filter application too.
Being more a believer in Accam's Razor and less in conspiracy theories and tin foil hats, similar anecdote added I'll stick with previous posit, compromised compression spring.
You mean Occam's Razor? Wait til you run into Bell's inequality. Shows that even Einstein could have been wrong although the basic premise of the EPR paradox may still stand in that it could still be considered incomplete.
Re: Fram Ultra Bad? [Re: Wolf359] #5344609 02/08/20 12:30 PM
Sayjac Offline
Yeah Occum's Razor, my bad. But you knew what I meant. The simplest explanation is usually the right one. As I always make a point to qualify where possible, more a believer in that than the alternative referenced.
Linked is the thread I first referenced. It got lock and the OP banned.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3000474/1
Re: Fram Ultra Bad? [Re: 762fermeandyou] #5344619 02/08/20 12:39 PM
H
hallstevenson Offline
H
And people get so excited about cutting filters open after they've been in use ! If anyone bad is found, it's too late now !
Page 1 of 5 1 2 5
