Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
95 registered members (andyd, 4WD, Atrocious, 55hambone, Alfred_B, alchargo, 8 invisible), 2,204 guests, and 41 spiders.
Topics306,027
Posts5,285,126
Members71,566
Page 1 of 3 1 2 3
Chainsaw chain #5344434 02/08/20 10:25 AM
supton Offline OP
Picked up an Echo CS-310 for light work around the house. Chain got dull, tried to sharpen a couple of times, not having any real luck. Local shop charges $6 to do, but it is a week plus of time, so I am thinking of getting another chain or two. Swap as necessary. I don't burn wood and it's a tool that I would only use on weekends, and not every weekend at that.
So... shopping around I see that I can get an Echo chain for $20 at Home Depot. Or I can get Oregon. Or shop online and get Tallox or Sungator, which sound like cheaper chains, but for $30 or so I could get 3 or more chains. Is this something where you get what you pay for? Cheaper chains being softer and apt to dull quicker? Or are they all equivalent?
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Chainsaw chain [Re: supton] #5344444 02/08/20 10:34 AM
B
brages Offline
B
IMO, you get what you pay for...
Learn to sharpen your own. Hit it with a couple of strokes from the file before each time you use it and you will always have a sharp chain.
You also have to keep down the "rakers" (depth gauges) for it to cut well... this "2-in1" file does both at the same time:
https://www.amazon.com/Stihl-2in1-Chainsaw-Chain-Sharpener/dp/B010JJNOUE/
It's expensive, but there are also cheap knockoffs... you need the right size, too, of course.
Re: Chainsaw chain [Re: supton] #5344448 02/08/20 10:37 AM
Chris142 Online Content
Online Content
Buy the oregon chain. They are ok.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Chainsaw chain [Re: supton] #5344451 02/08/20 10:40 AM
spasm3 Online Happy
Online Happy
The box store oregon chains are soft. But you don't use a saw that often, so they are also easier to sharpen. Unless you use a saw a lot and have a lot of experience , the anti kickback chains are safer.
Don't hit the ground with the running chain, it will dull the cutters instantly. Don't run the chain until is super dull. Touch up the chain with a file every tank or so , before its really dull. Extra chains are good as you have them sharpened and ready to go.
Make sure you have the right size files for your chain.
WHAT LENGTH BAR?
This is a tougher chain than the box store chains but its not anti kickback. The cutters are harder. This is a 16inch length. I don't know if your saw has enough power to pull it.
https://www.amazon.com/OREGON-20LPX066G-Drive-Super-0-325-Inch/dp/B008PD0WJI/ref=sr_1_4
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Chainsaw chain [Re: brages] #5344452 02/08/20 10:41 AM
supton Offline OP
Tried that, saw is cutting sideways. I call it user error--I went until it was good and dull, like went through a gallon of gas and maybe hit a rock towards the end dull.
I did check the rakes and they seem low, the gauge indicated no problem. Just doesn't cut like new.
Re: Chainsaw chain [Re: supton] #5344454 02/08/20 10:42 AM
K
Kira Offline
K
Casual user? Go to TSC and buy their 2-packs.
Re: Chainsaw chain [Re: supton] #5344459 02/08/20 10:48 AM
spasm3 Online Happy
Online Happy
This chain is low kick back but has the harder blued cutters, and being a semi chisel, would probably work better on your saw than the full chisel chain i posted above.
https://www.amazon.com/Oregon-91PXL057G-Drive-Semi-Chisel-Profile/dp/B015CXK37Y/ref=sr_1_1
Re: Chainsaw chain [Re: supton] #5344460 02/08/20 10:50 AM
JohnnyJohnson Offline
Sharpening a chain for a saw is a piece of cake if you have the right file. Two chains and the stuff has paid for itself. I've sharpened all mine for over 40 years now. But then that's just me. I've had the same setup to sharpen them since I was thirty and it still works great.
2004 Corolla 140104
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Chainsaw chain [Re: supton] #5344463 02/08/20 10:54 AM
A
andyd Online Content
Online Content
A
You can have teeth sharp to the touch. But if you haven't touched the rakers, the saw will make dust like it is dull. I hand file the teeth with the right size round file. Every 3rd sharpening I hit the rakers with a flat file. I don't bother trying to make all the teeth even. I concentrate on following the existing angle as close and as level as I can. Its more by feel than sight. I get decent results. Maybe not perfect, but serviceable. Way more convenient and I remove a lot less material with 3 strokes per tooth than a grinder that sizes every tooth equally. I have lots of chains I had 5 or 6 from the early days when I had them done.So I cant advise you on what to buy except that Oregon used to be good.
Thick oil is better grin2
Re: Chainsaw chain [Re: supton] #5344467 02/08/20 10:57 AM
B
brages Offline
B
Take it to a saw shop or hardware store and have it sharpened, then keep it sharp, don't let it get dull. IMO, it's fairly easy to keep a chain sharp with a guide, even just the basic type. Without a guide, it's tricky. The more you do it, the better you will be at it.
Re: Chainsaw chain [Re: supton] #5344469 02/08/20 10:59 AM
spasm3 Online Happy
Online Happy
Examine the bar. Make sure you did not run out of bar oil and wore the bar.
I always fill my bar oil tank full, and i only put 3/4 of a tank of fuel, that way i usually run out of gas , before i run out of bar oil.
Re: Chainsaw chain [Re: spasm3] #5344483 02/08/20 11:10 AM
supton Offline OP
I kept an eye on it, never ran out. I do miss having the manual oiler, never quite trusted automatic ones, but I'm guessing a bit has changed in the couple decades since I used a saw.
Re: Chainsaw chain [Re: supton] #5344502 02/08/20 11:29 AM
doitmyself Offline
I only have experience with Stihl chains, which are very high quality (I get a big discount through workplace). My experienced student employees (some trained wildland fire fighters) think Oregon makes good chains also. You could probably hang out at Arboristsite.com and discover if more economical brands have value.
I would seriously study chain sharpening on line AND have a competent person give you some hands on training. While it is not rocket science, you need to understand the fundamentals of chain geometry and sharpening technique to get it right. I.E., your crooked cutting chain is due to differences in length/sharpness of one side of the chain teeth vs. the other. A right/left handed person teds to hand sharpen one side more than the other over time. A machine sharpening will get all the teeth equal again.
I.E., this Stihl tool checks ALL of the critical angles, raker depth, etc.:
[Linked Image from baileysonline.com]
You need to know about bar and sprocket maintenance too! They wear too, and you can correct bar abnormalities.
Re: Chainsaw chain [Re: supton] #5344503 02/08/20 11:30 AM
Astro14 Offline
I sharpen lots of things - Axes, plane blades, knives, chisels.
Never learned to sharpen saw chains. I've got 4 or 5 spare Oregon chains, when they get dull, I drop them off to be professionally sharpened.
I liken it to suits, and other dress clothes. I'll never learn to dry clean them myself, I farm that work out, and have more than one suit, so that I'm never without.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Chainsaw chain [Re: supton] #5344523 02/08/20 11:46 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Chain saws require a lot of maintenance. For every three hours use I'll spend about an hour maintaining it per suggestions mentioned above. Ditto to not touching the ground with the chain. It'll dull the chain instantly.
Page 1 of 3 1 2 3
