Pecan Pie Cheesecake Recipe
by GumbyJarvis - 04/06/20 05:03 AM
Dewalt DXCM251 25-Gal Oiled Air Compressor
by The Critic - 04/06/20 03:40 AM
Windows File & Folder Fix Tool
by ZeeOSix - 04/06/20 01:53 AM
$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
F7daved, khouan, daniell, carguy1701, London
71106 Registered Users
62 registered members (avi1777, atikovi, Astro_Guy, 77GrandPrix, Astro14, 4WD, 6 invisible), 1,466 guests, and 16 spiders.
Topics303,661
Posts5,239,356
Members71,106
Installing drop axles on landscape trailer? #5343626 02/07/20 12:20 PM
M
motor_oil_madman Offline OP
M
My trailer has two issues. The deck is a little high and would like to lower it some, so the ramp isnt as steep, then the other issue is the axles only have an inch or so of space before it hits the frame.
I was thinking we were going to have to raise up the fenders, but now that I think about it all we need to do is install longer leaf spring spacers.
I'm going to install 4" drop axles, so Dexter axle only requires 3" of frame clearance, then I can ditch the taller 235/80r16 tires for smaller 225/75r15 tires and that should make the trailer 1.25" lower then subtract the existing 1-1.5" space the axles currently have and that should drop the trailer about 2.5" plus keep the axle from hitting the frame.
Opinions? Is my thinking correct on adding the longer spring hangers is all it takes technically? Btw this trailer has a C channel frame.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5343633 02/07/20 12:24 PM
1
1978elcamino Offline
1
Make a bi-fold ramp, two 5ft sections that fold in half, the longer ramp would be less steep. Much cheaper than replacing axles and trying to move the fenders around, less wind resistance too.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5343640 02/07/20 12:29 PM
M
M
That doesn't fix the axles from hitting the frame. That's my main complaint.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5343714 02/07/20 02:17 PM
T
tcp71 Offline
T
Install torsion axles, maybe?
[Linked Image]
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5343723 02/07/20 02:25 PM
M
Miller88 Offline
M
Friend of mine has torsion axles on an equipment trailer. They seem to work pretty well. Not sure how long before they lose their torsion, but I imagine with how old that trailer is and how hard it's been whipped it is quite a while.
What are you going to do about fenders? Drop axle is going to put the tires through the fenders unless you relocate them -- if you block the leaf springs and go with a drop axle, I'm not sure if that would get you anywhere.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344020 02/07/20 08:15 PM
M
M
https://www.etrailer.com/Trailer-Axles/Dexter-Axle/8327860.html?feed=npn&msclkid=8fc367c067da1802069f39fe6d553115&utm_source=bing&utm_medium=cpc&utm_campaign=Bing%20%7C%20Shop%20-%20All&utm_term=4577266908256271&utm_content=Catch%20All%20Products
The axle is the part that drops giving me the axle to frame clearance I need, the wheels will pretty much be in the same spot. The fenders may just need to be moved up a couple inches. Just a matter of cutter them off then cutting the mesh siding and welding them back on.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344021 02/07/20 08:15 PM
M
M
Torsion axles are for boat trailers typically.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344038 02/07/20 08:37 PM
R
Rand Offline
R
used trailers seem to hold their value fairly well..
maybe sell yours and buy what you want?
Then you have new everything and 5+ years of trouble free service (maybe a brake job and tires)
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344077 02/07/20 09:26 PM
P10crew Offline
^ not exactly... torflex is the high end option on just about every trailer these days and imho we’ll worth the cash.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344085 02/07/20 09:34 PM
M
M
This trailer is already sort of custom. I don't see why I can't have this fixed for no more than $1500, axles included. It has a front side gate and a full c channel frame vs just angle iron. Did this so I can load a 1000 pound lawn mower from the side with no twisting.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344087 02/07/20 09:36 PM
M
M
I just don't want it any higher than it is now and want the axle spacing fixed so I'm not beating my mowers to death go down the road on every little bump.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344091 02/07/20 09:43 PM
P10crew Offline
I guarantee you that 2 torsion axles are way under that price. I usually only put brakes on the front axle .
Can you do your own work??
Re: Installing drop axles on landscape trailer? [Re: P10crew] #5344097 02/07/20 09:50 PM
M
M
Grind off the old spring hangers then bolt on the new torsion axles? Yes. Do I have the place to do it? Not really. The torsion axles might work because you get rid of the 2" spring hangers, so the trailer might be lower still. I'll check my boat trailer tomorrow and see.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344099 02/07/20 09:52 PM
M
M
The torsion axles might be an easier fix. I'll be honest though I've never seen a landscape trailer with them. They're all spring axles with the equalizer in the middle.
Re: Installing drop axles on landscape trailer? [Re: motor_oil_madman] #5344115 02/07/20 10:12 PM
tom slick Offline
Torflex axles don’t equalize the load like spring axles in a multi axle trailer but they can still be used on them.
You get what you pay for...
So keep in mind how much you paid for this advice.
