Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
45 registered members (Amkeer, ArgleBargle, bbhero, BlakeB, AZjeff, bmod305, 5 invisible), 1,204 guests, and 21 spiders.
Topics301,934
Posts5,205,773
Members70,801
Inner tie rod ends? #5344048 02/07/20 07:48 PM
B
buck91 Offline OP
B
How do you grease rakc and pinion inner tie rod ends? Going to be doing a front even overhaul with Moog on my F150 and would like to pre-grease the inners with my moly grease. They do come decently greased with a blue, likely lithium, grease. I notice there are little holes 180 degrees apart on the wrench flats on the socket as well as one at the very end of the socket threads, can I just a injector nozzle to force grease or is it not a patent lumen to the ball socket? These ends don't have a dedicated grease boot as they are contained within the r&p boot. You can kind of see one of the holes I'm talking about at the top of this picture:
Moog EV800457
[Linked Image from rockauto.com]
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Inner tie rod ends? [Re: buck91] #5344079 02/07/20 08:29 PM
1
14Accent Offline
1
I've never in all my years greased an inner tie rod prior to installation. Compared to other suspension components, they articulate relatively little, and are completely shrouded by the tie rod boot. I see no reason to add any additional grease.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Inner tie rod ends? [Re: buck91] #5344317 02/08/20 06:51 AM
T
Trav Offline
T
You could but I have never done it. When they reman racks many times they don't replace the inner rods as they are still okay, getting the boots off, replacing them and getting them sealed up again is more than the job is worth IMO.
Re: Inner tie rod ends? [Re: buck91] #5344336 02/08/20 07:33 AM
cronk Offline
You may do more harm than good trying to add more grease. They are pre greased, and if you add grease that isn't compatible, it will cause the grease to seperate and get thin and watery and run out of the part.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Inner tie rod ends? [Re: buck91] #5344391 02/08/20 08:43 AM
R
RAR Online Content
Online Content
R
I installed new inner and outer tie rods on my 2011 Dodge Charger before the snows came last year. The new inners are pre-greased and are shrouded in the boot on that end. I never grease them as there isn’t a way to do it. I’ve replaced many Chrysler LX platform front ends and had no issues (maybe because they need replacing more often?) 😎.
2019 Ram 1500 Big Horn 5.7 4x4
2008 Dodge Ram 1500 4.7 4x4
2011 Dodge Charger Police 5.7 RWD
2010 Ford Crown Victoria PI (Decided to hold onto for a loaner car)
Re: Inner tie rod ends? [Re: buck91] #5344450 02/08/20 09:39 AM
Chris142 Offline
You don't.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Inner tie rod ends? [Re: Chris142] #5344659 02/08/20 01:26 PM
G
GSCJR Offline
G
Originally Posted by Chris142
You don't.
+1
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 157KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
