Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
73 registered members (alarmguy, AndyB, aba4430, 4WD, Aero540T, 94astro, 7 invisible), 1,615 guests, and 17 spiders.
Topics301,732
Posts5,201,639
Members70,766
Stone Valve Cover Gaskets #5343708 02/07/20 01:06 PM
The Critic Offline OP
I volunteered to reseal the valve covers on a Tacoma 3.4L V6 and since this was a low-budget job, I used an inexpensive valve cover gasket kit from our supplier that was made by “Stone.” For only $54, the kit included both valve cover gaskets, the spark plug tube seals, pcv grommet, cam caps and the valve cover bolt washer/grommets. Despite the low price, I expected quality since the kit was Made in Japan.
As you may see in the pictures below, the new gaskets appear to be abnormally "compressed." To me, these new gaskets are barely taller than the ones I removed. Luckily the gaskets fit well into the groove, but were very "compressed" from a height standpoint. The valve cover bolt washers/grommets were also bulging after I torqued the bolts to spec and spec is only 53 inch-lbs.
For now, the oil leak has stopped but I have a feeling that these gaskets will not last more than a few years.
Does anyone have experience with the Stone brand of gaskets?
http://www.stone-tkk.com/stone/
https://www.carid.com/stone/engine-valve-cover-gasket-set-mpn-jvs-10420.html
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Stone Valve Cover Gaskets [Re: The Critic] #5343737 02/07/20 01:34 PM
B
BigD1 Offline
B
Ishino Stone use to make Toyota factory gaskets. Who knows now since Corteco runs the show.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: Stone Valve Cover Gaskets [Re: BigD1] #5343740 02/07/20 01:40 PM
K
kschachn Offline
K
Yes, that is what I was going to say - about them being "Ishino Stone". FWIW I used a set on my old Accord a while back and several years later they are holding up fine.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Stone Valve Cover Gaskets [Re: The Critic] #5343748 02/07/20 01:51 PM
A
atikovi Offline
A
They may many Honda OEM gaskets so I wouldn't worry about it.
Re: Stone Valve Cover Gaskets [Re: The Critic] #5343753 02/07/20 01:52 PM
A
ad244 Offline
A
I did the valve cover gaskets along with all the other gaskets (resealed the half moons etc) on my 3.4L a few months back with all Toyota OEM parts. I was amazed as to how hard and brittle the gaskets had become. My varnish looked very similar to yours as well in that picture. Not a hard job but I broke the [censored] out of the plastic shrowd on my wiring loom protector on the drivers side. What a pain that was.
Did you change the gaskets on the spark plug tubes too?
Re: Stone Valve Cover Gaskets [Re: ad244] #5343755 02/07/20 01:56 PM
This one crumbled as well.
Yes, I replaced the spark plug tube seals. Surprisingly, the old gaskets were not very brittle but they still leaked like a sieve.
Re: Stone Valve Cover Gaskets [Re: The Critic] #5343765 02/07/20 02:05 PM
A
ad244 Offline
A
Nice!!
Next up U joints for my Tacoma. 235K Strong.
Re: Stone Valve Cover Gaskets [Re: The Critic] #5343983 02/07/20 06:27 PM
slacktide_bitog Offline
Ishino Stone is an OE supplier and could be a reboxed OE gasket set
Many Fel-Pro and Beck/Arnley gaskets for Japanese cars are reboxed OE stuff too, possibly also Ishino/Stone
I used Victor Reinz a few years ago for a 4th gen Maxima, and they were made in Japan. Most likely reboxed OEM, probably Ishino/Stone. Lasted 30k with no problem, and I got rid of the car without them leaking again
Re: Stone Valve Cover Gaskets [Re: The Critic] #5344249 02/08/20 02:51 AM
G
GMBoy Offline
G
I've had valve cover gaskets as you describe - seemed too "thin" to seal but they sealed fine. My bet is you will be fine especially since others are saying that brand is an OEM supplier.
Re: Stone Valve Cover Gaskets [Re: The Critic] #5344853 02/08/20 07:01 PM
N
nthach Offline
N
Ishino is part of Corteco, which part of Freudenberg - one of the major suppliers of seals, gaskets and CAFs. Freudenberg has a JV with NOK in the US - Freudenberg-NOK Sealing Technologies that makes TransTec rebuild kits and pistons for ATs.
I'd trust them over a Chinese white box gasket.
