Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
More home made junk
by P10crew - 04/04/20 08:11 AM
Battery for Crosstrek
by Donald - 04/04/20 07:41 AM
0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
Castrol GTX Magnatec
by David1 - 04/04/20 04:03 AM
Should i change my oil change routine ?
by M119 - 04/04/20 03:56 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
97 registered members (atikovi, 2009Edge, Alfred_B, 2015_PSD, AlienBug, alchargo, 6 invisible), 2,971 guests, and 17 spiders.
Topics303,583
Posts5,237,727
Members71,094
2019 Stelvio #5343568 02/07/20 11:19 AM
R
ronasty Offline OP
R
Anyone know if is ok to use Castrol Edge 0W-30 European Formula Full-Synthetic Motor Oil in these motors? I use this in my M235i Beamer and BMW service said was ok with them no warranty issue.
Re: 2019 Stelvio [Re: ronasty] #5343575 02/07/20 11:24 AM
J
Jimmy_Russells Offline
J
I would probably use an oil with the spec that is recommended in the manual
Re: 2019 Stelvio [Re: Jimmy_Russells] #5343587 02/07/20 11:36 AM
R
ronasty Offline OP
R
0W30 euro is spec, only prob is dealer suggest Pennzoil and just not finding strong supply in area. cost at dealer is just stupid. guess could order supply at worst. service wont say yes or no on the Castrol. Manual actually says Mopar API SN PLUS Certified SAE 0W-30 Full Synthetic Engine Oil and service adviser looked like a deer in headlights with no answer? idk. Maybe I try to get an email to a tech in Italy.
Re: 2019 Stelvio [Re: ronasty] #5343605 02/07/20 11:53 AM
1
14Accent Offline
1
That engine looks to be spec'd for Chrysler MS-13340, which means you can either use the Chrysler 0W-30 oil or Pennzoil Platinum 5w-30 which carries the MS-13340 spec.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 2019 Stelvio [Re: ronasty] #5343620 02/07/20 12:15 PM
DriveHard Offline
If you find a way to reset BOTH oil monitors, please let me know!!!
From everything I have found only the dealer can reset it for now.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: 2019 Stelvio [Re: DriveHard] #5343713 02/07/20 02:16 PM
R
ronasty Offline OP
R
i know, been researching that also, such bs dealer only. looking for one of the saddle plug in and smart phone apps may be able to, not sure yet.
Re: 2019 Stelvio [Re: ronasty] #5343844 02/07/20 04:43 PM
A
ARCOgraphite Offline
A
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 2019 Stelvio [Re: 14Accent] #5343879 02/07/20 05:32 PM
J
JunkdrawerDog Offline
J
This^^^ Factory fill was probably Selenia Digitek 0w-30 which meets FIAT 9.55535-GS1. There is no direct read across equivalent for this in the domestic oil market so I believe that MS-13340 is sort of a bridge spec from FIAT spec to API. So... 13340 is what you want and Pennz Plat 5w-30 meets it. Says so right on the bottle.
Re: 2019 Stelvio [Re: ronasty] #5343904 02/07/20 06:06 PM
J
J
Is this the quattroformaggio, or the regular one?
