Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
34 registered members (blufeb95, bbhero, avi1777, ArrestMeRedZ, 14Accent, 6 invisible), 1,061 guests, and 20 spiders.
Topics301,683
Posts5,200,448
Members70,756
DIY high capacity pan/sump? #5343399 02/07/20 07:26 AM
M
Mad_Hatter Offline OP
M
I was checking out YT and came across some DIY mods for increasing the oil pan capacity. I guess the 2 obvious benefits that come to mind are longer drain intervals and better cooling? But aren't like the stock mfg OE pans, filters and pump all matched/calibrated? Like if you brake suddenly the pickup tube doesn't run dry?
[Linked Image]
Re: DIY high capacity pan/sump? [Re: Mad_Hatter] #5343416 02/07/20 07:52 AM
I
Imp4 Offline
I
Cooling is no better. Oil temperature will still reach standard operating temperature and be regulated by the radiator/oil cooler.
Risk of starvation at the pickup goes up because of the nonstandard modification with no performance validation testing.
Seems like staying away from this one is a no brainer.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: DIY high capacity pan/sump? [Re: Mad_Hatter] #5343455 02/07/20 08:34 AM
R
Ride_Red Offline
R
I would only expand the oil capacity if there was a really good reason, maybe a race car for track days or a dedicated 4x4 in steep terrain.
My 4Runner 4.0 V6 takes 6.6 quarts. That's a lot of oil. My T&C 3.8 V6 only takes 4 quarts.
I'm sure Toyota increased the oil capacity 4Runner 4.0 based on design criteria such as making sure the sump doesn't go dry when ascending or descending hills while 4-wheeling and as a result of the larger oil capacity were able to extend to a 10K mile OCI. There's not a lot of room under there to increase it more without sacrificing ground clearance.
2019 4Runner 4.0L, 18K Mi, M1 EP 0W-20, OEM
2010 CR-V 2.4L,100K Mi, M1 0W-20 AFE, M1-110
2009 T&C 3.8L, 130K Mi, ST 5W-20, Fram
2006 Cobalt 2.2L, 184K Mi, ST 5W-30 HM, Fram
Re: DIY high capacity pan/sump? [Re: Mad_Hatter] #5343471 02/07/20 08:58 AM
K
Kira Offline
K
Hey Mad_Hatter, reading about customizing your oil pan PROVES how daisy fresh you are.
What car do you drive? Were you seriously thinking about playing with sheet metal?
The COOLEST customized oil pan I ever saw was at a car show where a tube was welded through a pan such that a tie rod could go through it.
Re: DIY high capacity pan/sump? [Re: Kira] #5343485 02/07/20 09:09 AM
M
M
You and your daisy fresh...no, not thinking about it at all... just watched a video of a DIY and was wondering about it is all. Was wondering what the advantage is, I guess for a race/Nascar maybe?? Don't Nascar rides use a supplemental sump??
Re: DIY high capacity pan/sump? [Re: Mad_Hatter] #5343536 02/07/20 09:52 AM
R
ragtoplvr Offline
R
the best system is dry sump. there is only minimal oil in the oil pan, the rest in in a well baffled tank near the engine.. It can be as big as you can fit. I have seen them up to 16 quart. I am sure bigger exist.
Re: DIY high capacity pan/sump? [Re: Mad_Hatter] #5343721 02/07/20 01:23 PM
L
Lasthope05 Offline
L
People who are building/using larger capacity oil sumps are not doing it for cooling or longer drain intervals. It's mostly used in conjunction with baffles and trap doors to alleviate oil starvation issues at high sustained g forces or extreme angles from off roading.
Re: DIY high capacity pan/sump? [Re: Mad_Hatter] #5343729 02/07/20 01:30 PM
O
Olas Online Content
Online Content
O
My sump is of the standard capacity, but baffled and trap-doored because turning hard-left at speed causes the oil to ‘slosh’ over to the other side of the sump, away from the pick-up.
You only have to lose oil pressure in a corner once and you will always trust in baffles for a wet sump afterwards.
If you increase the capacity make sure you still have enough clearance to refit
Cable ties should hold it
