2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
33 registered members (bachman, ArrestMeRedZ, BlakeB, 97prizm, bernau, AurionX2, 2 invisible), 797 guests, and 15 spiders.
Topics301,813
Posts5,203,179
Members70,784
QS HM 5W30 99 4.6 2500 miles #5343280 02/07/20 02:11 AM
F
FordFETruck Offline OP
F
A copy of the first UOA I've done. Not the best, not the worst. Oil had a ton of idle hours and a ton of cold starts, plus hilly terrain and often loaded. Oil was in service from March 25th to December 22nd. Oil consumption was ZERO!
1986 F250. 4x2 351w Edelbrock heads, xe250h cam and the works. 245k miles
1999 Mercury Grand Marquis gs 4.6. 3.27 LSD, JMOD 120k miles
Re: QS HM 5W30 99 4.6 2500 miles [Re: FordFETruck] #5343318 02/07/20 04:50 AM
T
Triple_Se7en Offline
T
Your link went dark on me and the little Microsoft wheel spinned. I'll try to open it again after work.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: QS HM 5W30 99 4.6 2500 miles [Re: Triple_Se7en] #5343871 02/07/20 04:20 PM
F
F
Huh, that's odd. Showed right up for me both logged off and logged in.
Re: QS HM 5W30 99 4.6 2500 miles [Re: FordFETruck] #5344011 02/07/20 07:01 PM
T
T
(back from work) Link is gone from original post and the Lab Analysis now showing.
Re: QS HM 5W30 99 4.6 2500 miles [Re: FordFETruck] #5344970 02/08/20 10:30 PM
M
Mad_Hatter Offline
M
This is the HiMi blend right? What happened to the 100c viscosity? It went from an +11cSt to a thick Xw20 after only 2.5k miles? Is this engine known for beating up on oil? Unless I'm missing something it looks like the VM's got shredded after only 2500 miles??
Re: QS HM 5W30 99 4.6 2500 miles [Re: FordFETruck] #5345516 02/09/20 06:11 PM
F
F
Yeah, this is the high mileage synthetic blend. The oil probably had 50 or so hours of idle in traffic time during those 2500 miles. The engine is incredibly clean inside looking through the fill hole. I'm not sure if this engine is hard on oil or not. When I bought the car I did a 500 mile quick flush and then ran this oil 2500 and did the analysis to see what I had. I have the same oil in it now but next change I have havoline HM smart change 5w30 and a fram ultra filter. Going to do a uoa on that oil change. I also put a better air filter in it and made a foam pre filter. The old filter was super cheap and had a poor seal and I could see right through the media.
Re: QS HM 5W30 99 4.6 2500 miles [Re: FordFETruck] #5356524 02/21/20 12:22 PM
F
Fordiesel69 Offline
F
The 4.6L 2 valve engine in your grand marquis is VERY easy on oil. Your metals are a bit out of spec because of the high silicon. When silicon is high, and iron follows that means there is an air filter issue. I would bet the airbox is warped and only WIX and MOTORCRAFT fitlers fit well. Napa Gold is a wix by the way. If you visit crownvic.net look for my warped airbox fix under the body of knowledge and inspect all other sources for a leak.
Also you could be cleaning up the engine causing things to come loose, therefor skewing your UOA. Either way rest easy knowing that the 1999 model year is one of the best and that the 4.6L is near bulletproof. Your UOA is good overall.
99' Crown Vic Police - SAP (P71)
00' Crown Vic Police - SAP (P71)
08' Crown Vics Police - SAP(P71's) (total of 3 garage queens)
13' Taurus Police
14' Fusion S Base
