Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
103 registered members (64bawagon, 53' Stude, alchargo, 2003f7, 2015_PSD, 2004tdigls, 4 invisible), 2,112 guests, and 16 spiders.
Topics301,900
Posts5,205,001
Members70,798
16" Wheels on 09 Lexus RX 350 ... #5343248 02/06/20 11:54 PM
B
BrocLuno Offline OP
B
I'm shopping for a Lexus RX 350. Prolly get an 08 or 09 as I prefer the layout of the interior/dash on that model. It will be daily driver with OEM wheels and recommended tires, maybe +1 ...
But occasionally it will have to go off-road. I made my living doing OHV trail assessments and erosion surveys for decades before I retired so I'm not concerned about my of the vehicle. But I'd like some more sidewall and a fatter casing to work with when I have to air down for sandy washes in the SoCal desert or the beaches in Oregon.
Stock is 65 aspect ratio on 17" wheels. There are constrictions to just growing tire size like the rear strut structure. So I'm considering 16" wheels with a 30mm positive offset. Coupled with 70 series tires I get more to work with.
This all works IF I can squeeze 16" wheels around the brakes on that model ?? All the pictures I see show clearance between caliper and rim that makes me think it's doable ...
Anyone know about this vehicle and wheel fitment ??
Re: 16" Wheels on 09 Lexus RX 350 ... [Re: BrocLuno] #5343265 02/07/20 12:48 AM
N
NothingNew Offline
N
TireRack doesn't show a 16" wheel available for a 2009 RX350 AWD. That leads me to believe 16" wheels will not provide adequate clearance. Just get an AWD model and pair it with some good on/off-road all-terrain tires: TireRack Tires
Re: 16" Wheels on 09 Lexus RX 350 ... [Re: NothingNew] #5343615 02/07/20 11:02 AM
L
Lolvoguy Offline
L
Check the Lexus forums. As much as I like TireRack, they often do not have the alternative items that could fit.
I once had an 03 Focus that came with 16's from factory. When looking for a winter setup, the smallest thing listed online was 15's (I wanted to run 14's).
After some running around, I realized the 14 inch steel wheel setup from an early 90's Tempo/Topaz cleared the rotors perfectly.
Strangely, the optional Tempo/Topaz alloy 14 inch wheels did NOT clear the front rotors.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: 16" Wheels on 09 Lexus RX 350 ... [Re: BrocLuno] #5343693 02/07/20 12:41 PM
Supersonic Offline
A look at Rock Auto, just to compare rotor size to 2010 Sienna, 291mm Diameter Rotor vs 2009 RX 350 319mm Diameter Rotor for Wagner's specs, I was thinking it is the same drive train, but they are slightly bigger for the Lexus. I have 16 inch rims on the Sienna.
