5w-20 PP Walmart & Amazon $12
by jayjr1105 - 04/03/20 02:28 PM
Chicken Marsala Recipe Help
by 97prizm - 04/03/20 02:02 PM
Oil Filter Removal
by Kansas_Ron - 04/03/20 01:24 PM
Pressure regulator made in USA
by rainman49 - 04/03/20 01:08 PM
mitsubishi outlander
by ernied - 04/03/20 12:43 PM
WM - Pennzoil Platinum $18.68
by The Critic - 04/03/20 12:13 PM
Going from a PAO to a Ester base MT oil
by Bill_W - 04/03/20 11:54 AM
Spring Cleaning
by Mad_Hatter - 04/03/20 11:40 AM
Starting Over - 2013 Prius
by Greg L - 04/03/20 11:15 AM
Glue for dovetail joints
by spasm3 - 04/03/20 11:08 AM
In my face "wake up" call
by Kira - 04/03/20 10:58 AM
repairing old stereo equipment
by Donald - 04/03/20 10:44 AM
Valvoline Syn. Grease 14oz tube
by zfasts03 - 04/03/20 10:39 AM
WIX XP oil filter leaking....
by dkryan - 04/03/20 10:36 AM
K&N PS 1017 VIRGIN FILTER CUT OPEN
by 53' Stude - 04/03/20 09:56 AM
Got bored so I fired up the smoker
by BeerCan - 04/03/20 09:43 AM
VIRGIN M1-209A CUT OPEN
by 53' Stude - 04/03/20 09:39 AM
Roasts: what kind do you folks buy?
by 53' Stude - 04/03/20 09:12 AM
TJim, Andreeas1978, lawmanracing14, ebarker, Knop
71082 Registered Users
100 registered members (97prizm, 53' Stude, 2003f7, 01rangerxl, 007, alchargo, 15 invisible), 2,669 guests, and 18 spiders.
Topics303,527
Posts5,236,975
Members71,082
Anyone use a nut like this? #5343166 02/06/20 11:16 PM
F
Fitz98 Offline OP
F
I have some rusted out nuts pressed in the roof of my 2003 Suburban for mounting the roof rack side rails. I originally thought they were welded in, since there is not a nut from the underside. It looks kind of like a t-nut, but the flange is on the exterior side, so what prevents it from popping out?
I have already butchered one hole cutting and bending steel to slide a t-nut underneath and epoxied in place, but I feel there must be an easier, less destructive, more stable way.
Re: Anyone use a nut like this? [Re: Fitz98] #5343172 02/06/20 11:21 PM
P10crew Offline
Have you looked at nut serts?
Re: Anyone use a nut like this? [Re: Fitz98] #5343179 02/06/20 11:27 PM
T
tcp71 Offline
T
Google “blind rivet nut”.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Anyone use a nut like this? [Re: Fitz98] #5343183 02/06/20 11:32 PM
M
mk378 Online Content
Online Content
M
When the bolt is tightened the first time, part of the sleeve collapses and bulges out like a pop rivet, permanently securing the nut into the sheet metal.
Removal would be the same as a pop rivet-- drill away the top part until the bottom part is free to fall out. This should be possible without enlarging the hole in the car.
Re: Anyone use a nut like this? [Re: Fitz98] #5343187 02/06/20 11:33 PM
P10crew Offline
[Linked Image]
Re: Anyone use a nut like this? [Re: mk378] #5343271 02/07/20 02:12 AM
T
tcp71 Offline
T
Generally they require a tool to,set and collapse the collar. Just tightening the screw makes them spin and not collapse.
https://www.mechanicalcaveman.com/best-nutsert-tool-review-rivnut-insertion-8mm/
[Linked Image]
Re: Anyone use a nut like this? [Re: tcp71] #5343327 02/07/20 06:15 AM
T
Trav Offline
T
[Linked Image]
2 nuts a couple of washers put any one of them in as good as a tool.
