Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
More home made junk
by P10crew - 04/04/20 08:11 AM
Battery for Crosstrek
by Donald - 04/04/20 07:41 AM
0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
93 registered members (2009Edge, Bottom_Feeder, BHopkins, blufeb95, 2015_PSD, Bighorn2500, 5 invisible), 2,493 guests, and 23 spiders.
Topics303,586
Posts5,237,809
Members71,094
Anyone use a nut like this? #5343166 02/06/20 11:16 PM
F
Fitz98 Offline OP
F
I have some rusted out nuts pressed in the roof of my 2003 Suburban for mounting the roof rack side rails. I originally thought they were welded in, since there is not a nut from the underside. It looks kind of like a t-nut, but the flange is on the exterior side, so what prevents it from popping out?
I have already butchered one hole cutting and bending steel to slide a t-nut underneath and epoxied in place, but I feel there must be an easier, less destructive, more stable way.
Re: Anyone use a nut like this? [Re: Fitz98] #5343172 02/06/20 11:21 PM
P10crew Offline
Have you looked at nut serts?
Re: Anyone use a nut like this? [Re: Fitz98] #5343179 02/06/20 11:27 PM
T
tcp71 Offline
T
Google “blind rivet nut”.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Anyone use a nut like this? [Re: Fitz98] #5343183 02/06/20 11:32 PM
M
mk378 Online Content
Online Content
M
When the bolt is tightened the first time, part of the sleeve collapses and bulges out like a pop rivet, permanently securing the nut into the sheet metal.
Removal would be the same as a pop rivet-- drill away the top part until the bottom part is free to fall out. This should be possible without enlarging the hole in the car.
Re: Anyone use a nut like this? [Re: Fitz98] #5343187 02/06/20 11:33 PM
P10crew Offline
[Linked Image]
Re: Anyone use a nut like this? [Re: mk378] #5343271 02/07/20 02:12 AM
T
tcp71 Offline
T
Generally they require a tool to,set and collapse the collar. Just tightening the screw makes them spin and not collapse.
https://www.mechanicalcaveman.com/best-nutsert-tool-review-rivnut-insertion-8mm/
[Linked Image]
Re: Anyone use a nut like this? [Re: tcp71] #5343327 02/07/20 06:15 AM
T
Trav Offline
T
[Linked Image]
2 nuts a couple of washers put any one of them in as good as a tool.
