Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
Cartridge Filter Question
by Tundra73 - 02/25/20 01:21 PM
Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
98 registered members (alex_at, aquariuscsm, A_User55555, 01VFR, ABerns, AlaskaMike, 7 invisible), 2,497 guests, and 20 spiders.
Topics301,912
Posts5,205,229
Members70,800
Maxlife ATF now sates Honda 3.x compatible #5343171 02/06/20 10:20 PM
Drew7a Offline OP
I just spent $30 a quart for Honda 3.1 ATF and later saw that Maxlife PDS claims they are compatible with Honda 3.X and Lifeguard 8.
I have succesfully used maxlife on Honda’s calling for Z1, DW-1, Toyota’s calling for T-IV, having said that.
I am starting to wonder what is going on in the ATF industry, either Ashland is spot on and OEM’s are just making it difficult for customers with OEM specific fluids or is Ashland misleading us with their universality?
One thing about the Honda 3.1 fluid, after 82k miles it was still nice and green, unlike the WS fluid which is cruddy looking at 30K.
Anyone try Maxlife ATF in the ZF9HP transmissions yet?
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5343274 02/07/20 01:19 AM
discountdon Offline
even I wouldn't do that sick
Valvoline MaxLife MV ATF is recommended for trannys that orginally specifies Z-1, DW-1, and ZF Lifegaurd 8 for example... nowhere does it say anything about Honda 3.1 or ZF LifeGuard 9...
if I was going to cheap out on an out of warranty ZF9HP tranny - I would only run MaxLife with FM additives from LG to convert it to 'close enough' to OEM's requirement of highly modified FM's:
[ link to conversion chart ]
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5343276 02/07/20 01:26 AM
discountdon Offline
there's only 1 Valvoline MaxLife ATF that I know exists
LINK HERE - from manufacturer
LINK HERE - PI sheet as of 10/21/2019
OP where's your source that says it's now good for Honda 3.x???
Re: Maxlife ATF now sates Honda 3.x compatible [Re: discountdon] #5343303 02/07/20 04:05 AM
W
wdn Online Content
Online Content
W
Actually discountdon it does claim Honda 3.1 on the datasheet in your link.
Valvoline’s disclaimer though is hidden in plain sight on their same datasheet.
Quote
however, it should be noted that MaxLife Multi-Vehicle ATF is not an OEM licensed product. The respective vehicle manufacturers have neither evaluated nor endorsed MaxLife Multi-Vehicle ATF in these applications.
Re: Maxlife ATF now sates Honda 3.x compatible [Re: wdn] #5343311 02/07/20 04:40 AM
discountdon Offline
blush my bad blush
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5343344 02/07/20 06:00 AM
T
Trav Offline
T
IIRC the fine print says it can be used instead of Maalox and Pepto too. Run OE fluids.
Re: Maxlife ATF now sates Honda 3.x compatible [Re: wdn] #5343348 02/07/20 06:13 AM
Drew7a Offline OP
Does anyone know if there is a VOA on Lifeguard 8 or Honda 3.1 to see how it compares?
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Trav] #5343358 02/07/20 06:30 AM
Drew7a Offline OP
[quote=Run OE fluids.[/quote]
I respectfully disagree that OE fluids are always the best.
As an example my 08 Honda specs Z1 and the manual clearly stated damage will occur if you use anything else. It always shifted rough, a few years later the dealer said there was a TSB and they drained the Z1 and replaced with DW-1 and the car shifted slightly better, even though it was originally designed for the Z1 they now recommended DW-1.
I DF the fluid every 20K with Dw-1, at 200k the car had a had a hard clunk when down shifting, I thought tranny was on it last leg, so I said what the heck and switched to Maxlife with LG red and car has never shifted so well.
I know this is anecdotal information and confirmation bias, but how can Honda just absolutely spec one fluid at the time of manufacture and then switch mid stream? Better engineering and design of DW-1? I know Honda does not make the ZF trans and they probably did not do much research on fluids and relied on ZF as Honda 3.1 and Lifeguard8 are identical.
I am however starting to doubt that maxlife is compatible with everything. crzy
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5343367 02/07/20 06:42 AM
Drew7a Offline OP
I forgot to add I visited the Amsoil website to see if any of their fluids are "compatible" with Honda 3.1 and their online product application guide states: "No Amsoil Product Recommendation" .
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5343431 02/07/20 08:17 AM
H
hallstevenson Offline
H
...but how can Honda just absolutely spec one fluid at the time of manufacture and then switch mid stream? Better engineering and design of DW-1?
Because Honda considers DW-1 to be an evolution of Z-1 fluid. Think of it as Z-1 v2. If I'm not mistaken, the formulation between the two, i.e. the additives they use, didn't change much, but the base oil changed from non-synthetic to synthetic.
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5343432 02/07/20 08:17 AM
Brian553 Offline
+1
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5343503 02/07/20 09:29 AM
T
tig1 Offline
T
Several of the ATFs claim they are compatible with a wide range of trans. Most important thing I have been told by trans re-builders is try to keep the VIS close to the factory spec. I use M1 ATF(2007 ) and M1 LV ATF(2017) and neither are spec'd for Ford trans, but the VIS is close and have had great results in both Fords.
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Maxlife ATF now sates Honda 3.x compatible [Re: Drew7a] #5344323 02/08/20 07:08 AM
T
Trav Offline
T
Amsoil ATF ran well in the older (up to mid 2000's) Honda, Toyota and Subaru units as well as anything using a dex III spec fluid but today its different.
I have drained 100K Amsoil ATF out of a old Honda with over 100K on the fluid mixed driving too not just highway and it was still cherry red. Choosing the correct lubes is important and the decision to go with non OE spec lube should be taken seriously and researched thoroughly.
Just because Joe has run it for years and the product has a following doesn't mean diddly. if it works in X it may not work the same in Y.
Re: Maxlife ATF now sates Honda 3.x compatible [Re: tig1] #5344388 02/08/20 08:41 AM
doitmyself Offline
To counterpoint your statement, I also remember discussions here (Molakule involved) where it was questioned whether viscosity differences, within reason, were not as critical as suggested by some. I think (don't remember) that maybe the argument was about the multi vehicle fluids that have a viscosity in the middle (around 6) between the low viscosity and the older higher viscosities being o.k. in the low viscosity recommended camp. It was just anecdotal speculation, I think, but maybe Molakule will chime in.
For those of us where the OEM fluid costs upwards of $20+ per quart, these fluid wars are difficult. Even more so for those who can't diy. When I investigated service garage/dealer Hyundai tranny fluid change in my region, all 6 garages used either BG or Valvolene products instead of SP4 M, even during the warranty period. Go figure.
Re: Maxlife ATF now sates Honda 3.x compatible [Re: doitmyself] #5344442 02/08/20 09:33 AM
T
Trav Offline
T
I totally understand where you are coming from with this but is not as simple as just a viscosity issue there are many other considerations to be taken into account.
Anti wear additives and seal compatibility can in some cases play a greater role. I can only share my own experience but many vehicle manufacturers recommend synthetic fluids but are adamant about running a mineral based transmission fluid.
Seal compatibility has been an issue in the past with some fluids. The other point to consider is if the fluid is not 100% compatible excess wear can be happening without you seeing any obvious signs like in an engine of it until the unit fails in some way, it may take a longer time and when it happens most people just contribute it to a blown transmission and accept it at that. In fact if spec fluid was used it may not have had any issues at all and may still be living a happy life.
I used to rebuild a lot of CV axles (still do a few here and there) using new joints from SKF and few others I buy in Europe, some joints take a very special grease that cost almost $50 for 7oz, the grease is really that special. After many hours of research and help from Mola I have found a few of what seems to be real alternatives, one really looks great.
Not cheap grease but cheaper. I will run 4 different greases in 4 joints for a year before accepting it as a replacement, for other peoples joints they will continue to get the super expensive stuff until I am 100% sure it will hold up.
