Too close to home..
by Mad_Hatter - 02/28/20 10:03 PM
Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
98 registered members (4WD, bbhero, AZjeff, A310, 69GTX, 12 invisible), 1,770 guests, and 17 spiders.
Topics302,061
Posts5,208,299
Members70,826
Anyone use a nut like this? #5343166 02/06/20 10:16 PM
F
Fitz98 Offline OP
F
I have some rusted out nuts pressed in the roof of my 2003 Suburban for mounting the roof rack side rails. I originally thought they were welded in, since there is not a nut from the underside. It looks kind of like a t-nut, but the flange is on the exterior side, so what prevents it from popping out?
I have already butchered one hole cutting and bending steel to slide a t-nut underneath and epoxied in place, but I feel there must be an easier, less destructive, more stable way.
Re: Anyone use a nut like this? [Re: Fitz98] #5343172 02/06/20 10:21 PM
P10crew Online Content
Online Content
Have you looked at nut serts?
Re: Anyone use a nut like this? [Re: Fitz98] #5343179 02/06/20 10:27 PM
T
tcp71 Offline
T
Google “blind rivet nut”.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Anyone use a nut like this? [Re: Fitz98] #5343183 02/06/20 10:32 PM
M
mk378 Offline
M
When the bolt is tightened the first time, part of the sleeve collapses and bulges out like a pop rivet, permanently securing the nut into the sheet metal.
Removal would be the same as a pop rivet-- drill away the top part until the bottom part is free to fall out. This should be possible without enlarging the hole in the car.
Re: Anyone use a nut like this? [Re: Fitz98] #5343187 02/06/20 10:33 PM
Online Content
[Linked Image]
Re: Anyone use a nut like this? [Re: mk378] #5343271 02/07/20 01:12 AM
T
tcp71 Offline
T
Generally they require a tool to,set and collapse the collar. Just tightening the screw makes them spin and not collapse.
https://www.mechanicalcaveman.com/best-nutsert-tool-review-rivnut-insertion-8mm/
[Linked Image]
Re: Anyone use a nut like this? [Re: tcp71] #5343327 02/07/20 05:15 AM
T
Trav Offline
T
[Linked Image]
2 nuts a couple of washers put any one of them in as good as a tool.
