How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
108 registered members (1978elcamino, aquariuscsm, apollo18, 2013ecof150, 2015_PSD, 28oz, 6 invisible), 2,447 guests, and 17 spiders.
Topics301,902
Posts5,205,072
Members70,798
Page 1 of 3 1 2 3
Home Router Recommendation #5343147 02/06/20 09:58 PM
B
benjamming Offline OP
B
What router would you recommend for home? It would also need good range as the house is one level with ~ 3500 sq ft and it's located in the study on one end of the house. A few phones (Apple), tablet (Android), & couple laptops (Windows 10). No home office. I don't think I would want Nest & the like but maybe I should.
Thank you.
Re: Home Router Recommendation [Re: benjamming] #5343160 02/06/20 10:09 PM
Quattro Pete Offline
Unless you can put the router in the center of the house, I think you will have coverage issues, unless you get a mesh system.
What are you using now?
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Home Router Recommendation [Re: benjamming] #5343167 02/06/20 10:18 PM
B
B
Thunderstorm took out Linksys WRT120N. Yeah I know, much better routers can/should be had. That's why I'm here asking. smile
Re: Home Router Recommendation [Re: benjamming] #5343190 02/06/20 10:43 PM
1
14Accent Offline
1
I've been very happy with my Asus RT-AC66U in my ~2200 two level house. It's an old place, with lots of plaster and all that, and signal both on the 5ghz and 2.4ghz bands is just fine. I hace at least 6 or 6 wireless devices running at any given time and I never have an issue with lag. I've never had a network issue, never had any crashes or dropouts.
The newer revision, the RT-AC66U B1 is basically the better -68U hardware in the -66U case. It's $90 on Amazon right now.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Home Router Recommendation [Re: benjamming] #5343199 02/06/20 10:56 PM
M
mattwithcats Offline
M
Go To Amazon, search for "Linksys Refurbished"
Anything above an EA2700 will work,
Your router should have at a minimum Wireless "N" in 2.4 and 5 GHz bands, along with gigabit wired Ethernet ports
A super cheap one...
https://www.amazon.com/Linksys-EA3500-Dual-Band-Certified-Refurbished/dp/B00L4HWY3E/ref=sr_1_22
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Home Router Recommendation [Re: benjamming] #5343222 02/06/20 11:13 PM
Skippy722 Offline
I had a single AirPort Extreme covering almost 5,200 sq ft over 3 floors, router is centrally located on the main floor. 5ghz doesn’t work downstairs on the far end of the house, but the 2.4ghz is still reasonably quick.... sadly they discontinued them.
Had good luck for the most part with a RT-66U, but I’m currently rocking a Netgear Nighthawk AX4.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Home Router Recommendation [Re: benjamming] #5343320 02/07/20 04:58 AM
Carmudgeon Offline
Consider a mesh system, like Orbi, or Eero.
Among consumer brands, Asus is one of the best at keeping up to date on firmware security patches and supporting their routers the longest. There are also alternative forks, like Merlin, to add more advanced features for some models.
Netgear only provides 90 days of free support, but they make good hardware and have pretty good software support. I'd go with Asus or Netgear long before Linksys (Belkin). TP-Link is good value, but I've never used one.
Some like to use higher grade stuff from Ubiquity, but it's more involved than the average Joe probably wants to get into to configure and set up.
Resist the urge to buy a Wi-Fi 6 (802.11ax) router. The standard is still new, with bugs to work out, and prices are higher.
Re: Home Router Recommendation [Re: benjamming] #5343351 02/07/20 06:19 AM
Donald Online Content
Online Content
You should get a mesh or multiple access points? Can you run Cat6 cable within your house? Then I would go with some Ubiquity gear that includes two wired access points.
2015 Ford F-250 w/Powerstroke
Re: Home Router Recommendation [Re: benjamming] #5343360 02/07/20 06:32 AM
T
tomcat27 Offline
T
We went mesh with an Orbi and have had zero issues or complaints from the kids, which was never the case with any other wireless access point if you want a single, we just put a tp-link ac1900 at a college house with 12 kids. Works well.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Home Router Recommendation [Re: mattwithcats] #5343366 02/07/20 06:42 AM
M
MoneyJohn Offline
M
I would not recommend Linksys routers, esp the series mentioned in the post. I don't remember the issue of my head but there was some security flaw that Linksys refused to acknowledge. That was the reason I didn't go for those routers and got T-Mo branded Asus router for just $50. Its going strong for 2 years with a ton of interference of other neighborhood routers. https://www.amazon.com/T-Mobile-Wireless-AC1900-Dual-Band-AiProtection-Complete/dp/B01MYTAURW
Wirecutter recommends https://www.amazon.com/dp/B07NF44X91 or for budget https://www.amazon.com/dp/B079JD7F7G I am personally not sold on MESH or Orbi systems from the price to performance standpoint.
If you are little handy, get a router that supports DD-WRT/OpenWRT or Tomato variants, even if its a couple of years older, it would work amazingly well.
Re: Home Router Recommendation [Re: Carmudgeon] #5343397 02/07/20 07:23 AM
O
OVERKILL Online Content
Online Content
O
This echoes my sentiments quite well. ASUS or Netgear would be a good choice if you aren't going with a mesh setup.
Re: Home Router Recommendation [Re: benjamming] #5343415 02/07/20 07:52 AM
M
madRiver Offline
M
How was performance of your previous router? If one router setup worked well without dead spots or slow areas I would just buy another modern single router one that people recommend.
If you had dead spots or slow areas a mesh system works incredibly well. I love my Google Wifi 3 puck mesh although I do have a the three with an ethernet backbone(wires between them). The speed is incredible (150Mbps - 250Mbps internet download speed) everywhere in home and my 1 acre yard its well covered.
Re: Home Router Recommendation [Re: OVERKILL] #5343444 02/07/20 08:25 AM
G
Gillsy Offline
G
I run an Asus at1900. It's been pretty solid with no issues. I also ran a lower end Netgear that was a solid performer. No more Linksys period!
Many are the afflictions of a righteous man
2019 Nissan Murano S
2018 Gravely ZT HD 52
2016 Kawasaki 650 Versys LT
2012 Mazda 3 Skyactiv 2 ltr
Re: Home Router Recommendation [Re: benjamming] #5343493 02/07/20 09:17 AM
H
hallstevenson Offline
H
A single-level, 3500 sq ft house ? I can't picture a house layout like that. Even a single-level typical ranch style aren't usually much over 2000-2500 sq ft.
Did the previous router cover it okay ? If so, I wouldn't worry too much - almost any quality router at Walmart, Best Buy, etc will work fine. When I say "quality", avoid anything $60-75 and under. As mentioned, try and relocate it closer to the center no matter what you get. 2.4 ghz band will give better range but slower speed while 5 ghz will give better speed but less range. No way around that typically.
Re: Home Router Recommendation [Re: benjamming] #5343495 02/07/20 09:18 AM
V
volk06 Offline
V
Google wifi mesh (nest). Easy to setup and use.
Page 1 of 3 1 2 3
