Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
73 registered members (alarmguy, AndyB, aba4430, 4WD, Aero540T, 94astro, 7 invisible), 1,615 guests, and 17 spiders.
Topics301,732
Posts5,201,639
Members70,766
Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? #5343128 02/06/20 09:25 PM
DooDahMon Offline OP
Greetings,
Just bought a 1999 26’ RV w/ Ford 6.8L V10 Triton w/ 89K miles. The owner of the last 3 years has used Valvoline Dino 10w40 but manual says 5W30. It has 1000 miles since last change. I’m going to be taking it this summer on 5K Road trip and thinking about going to full synth and just not sure. I use Mobil One 0w20’in my 2013 Prius V and Castrol Edge 0w40 in my 2007 BMW X5 so am a fan of synthetics. I at least want to use the Motorcraft 5w30 part synth that Ford suggests rather than the Valvoline 10w40 and a quality filter w/ silicone anti-drain back valve. Also should I consider high mileage oils? There are no leaks now.
Was hoping some of you smart Folks may have some advice?
Thanks in advance!
Re: Just got a 99 Ford 6.8L V10. Which oil? [Re: DooDahMon] #5343134 02/06/20 09:40 PM
1
14Accent Offline
1
That's a big, heavy, rolling brick of a vehicle. You're going to want something much beefier than a 5w30. That being said, a Mod motor will be happy running on basically anything you decide, from dino 5w30 to synthetic 10w40.
What kind of conditions will the RV see while in use? Hills, ambient temps, loads (water, waste, passengers etc).
Might I suggest this: Valvoline Premium Blue Extreme 5w40
Premium blue gets big thumbs up around this forum, and the extra protection of running a xw40 won't hurt anything. I would use a Fram Ultra filter, it's one of the highest rated filters on this board, as well as affordable.
Does the rig have an oil cooler? I believe on the mod's it's just a sandwich cooler between the filter and block. It's more of a warmer than a cooler, but if you aren't pushing 70 through the Nevada desert in August you should be fine.
There should be a 4r100 trans backing up that motor. Solid unit, definitely install a pan with a drain plug (if not equipped, many commercial chassis were from the factory) to make drain and fill's easy. Have the spark plugs been done? I believe '99 is still within the years that had too short of spark plug threads and tend to loosen up. I would recommend having all 10 done right now if they haven't been, and make absolutely sure they're torqued to the UPDATED spec from Ford.
Let's see some pics, BTW!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: DooDahMon] #5343136 02/06/20 09:44 PM
Samrsnow Offline
Edge/Mobil 1 0w40, or any 5w30 syn you prefer. MotorCraft isn't worth it if you can get a full syn for the same price, its all about licensing. Being that the truck is from 99' the oil specs on it shouldn't limit your options much.
1987 BMW e28 535is - mystery mileage (300,000+) Chevron 20w50 - Mahle filter.
Re: Just got a 99 Ford 6.8L V10. Which oil? [Re: DooDahMon] #5343140 02/06/20 09:48 PM
M
mpgo4th Offline
M
I'd go with the motorcraft 5w30. I used that in our Fleetwood Bounder with the same engine. Other than broken exhaust manifold studs we had no problems out of that engine. My dad has one in his pickup that he tows equipment with regularly. He uses what he has or gets from me cheap or free. And lets it go until he feels like changing it and hes had no problems out of his other than exhaust manifold studs. See a pattern here?
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: DooDahMon] #5343142 02/06/20 09:51 PM
O
oldhp Offline
O
welcome I would use Pennzoil conventional 5w30 with a FRAM Ultra filter. After you get back put in a full syn of your choice. The Castrol Edge 0W40 would be a good choice. Happy Trails!!! cheers
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Just got a 99 Ford 6.8L V10. Which oil? [Re: 14Accent] #5343155 02/06/20 10:05 PM
I just bought it tonight 99 Fleetwood Jamboree 26’ and haven’t even picked it up yet ;-)
It will be loaded up with 4 adults and going from Midwest to CA and back via southern route. I may lease it out on RVShare too.
I hadn’t heard about that Valvoline Premium Blue Extreme so many thanks for the tip. Fram Ultra sounds like the best vs the M1 one I have used.
It has new plugs and coil packs so all good there, but will
Check the torque for sure. New brakes/wheel bearings/drive shaft reconditioned/seals, 3 batteries, tires, belt, and it purrs.
Don’t think there is a mod oil cooler and don’t know yet much about the stock cooler.
Asked the seller about tranny fluid and he only said it looked fine, so I best be changing it. Thanks for the tip RE the pan.
It was only $14K and was completely redone inside, new roof, I mean this seller was legit and spent over $7K I parts and many many hours rehabbing it. My wife fell in love right away.
Would love to share the photos but not sure how to do it? Guess I can add to cloud and use the link?
Respectfully,
DooDah
Re: Just got a 99 Ford 6.8L V10. Which oil? [Re: mpgo4th] #5343159 02/06/20 10:09 PM
Ya heard about the manifold stud issues on this engine.
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: DooDahMon] #5343163 02/06/20 10:11 PM
G
Gebo Online Content
Online Content
G
I'd go with Ford's recommendations for oil and oil filter.
I think Ford has a TSB for the 1999 F450 V10 6.8 changing the oil viscosity and how to fill it according to the dipstick.
I copied below from the Amsoil website. I cannot verify it's accuracy beyond my simple copy and paste:
VISCOSITIES:
All TEMPS....5W-20 This specification has been updated from 5W-30 to 5W-20 per a Technical Service Bulletin from the manufacturer 5W-20 is the preferred viscosity.
CAPACITIES: With filter 6 quarts EARLY MODELS: Oil level should be no higher than 1/2 inch (12 mm) below maximum on the dipstick. LATE MODELS: Oil level should be no higher than 1/8 inch (3 mm) above FULL line.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: Gebo] #5343165 02/06/20 10:15 PM
Wow thanks for the info. I heard about some using 5W20 and the dip sticks can be off so you end up putting in 6.5 if fill to full mark. My gut says stay with at least a 30W.
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: DooDahMon] #5343170 02/06/20 10:19 PM
G
Gebo Online Content
Online Content
G
That is weird to be going to a 5W20 in a 1999 monster motor. I wonder why? And then on top of that, changing the fill volume. There is some issue they are trying to address.
I'd get my butt down to the best Ford dealer in my area and talk to the service mgr or the best mechanic. Just ask parts guy who the best mechanic is while you buy an oil filter.....
You may get an answer that will override your gut. IDK???
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
QS HM 10W-30
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: DooDahMon] #5343180 02/06/20 10:27 PM
1
14Accent Offline
1
The 5w20 thing was all about CAFE and Ford trying to eek an additional .1 MPG out of their engines. Absolutely NOTHING changed with the engine itself.
My 2003 Mercury Marauder spec'd 5w20 on the cap, but it only ever got a steady diet of Amsoil 5w30. 5k changes and multi-daily redlines and she never burned a drop. Also, what was at 225k miles.
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: Gebo] #5343181 02/06/20 10:29 PM
Now that’s some good advice. I usually try to stay away from dealerships but you make total sense. Thanks.
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: mpgo4th] #5343185 02/06/20 10:33 PM
B
bbhero Offline
B
This ^^^^^^^^^.
Is what I would run... A 5w30. Motorcraft is obviously a fine oil to run. Or Pennzoil, Valvoline ,Castrol etc 5w30.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: DooDahMon] #5343186 02/06/20 10:33 PM
T
tcp71 Offline
T
Back spec of the lighter oil bought ford EPA credits. Toyota did the same.
Use an Xw40 and have a great trip.
that is also the year of v10 that spits spark plugs. Only a few threads in the heads holding them in...DO NOT OVER TORQUE THE PLUGS.
Read through this:
http://www.rvforum.net/SMF_forum/index.php?topic=71295.0
https://www.ford-trucks.com/forums/933853-v10-spark-plug-blowout.html
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Just got a 99 Ford 6.8L V10 89k miles w/ Dino 10w40 Which oil? [Re: DooDahMon] #5343202 02/06/20 11:00 PM
Chris142 Offline
I would go with a 10w-30 myself.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
