Pecan Pie Cheesecake Recipe
by GumbyJarvis - 04/06/20 05:03 AM
Dewalt DXCM251 25-Gal Oiled Air Compressor
by The Critic - 04/06/20 03:40 AM
Windows File & Folder Fix Tool
by ZeeOSix - 04/06/20 01:53 AM
$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
F7daved, khouan, daniell, carguy1701, London
71106 Registered Users
66 registered members (2015_PSD, 4WD, atikovi, Astro_Guy, 77GrandPrix, Astro14, 9 invisible), 1,548 guests, and 14 spiders.
Topics303,661
Posts5,239,357
Members71,106
Page 2 of 3 1 2 3
Re: 2018 Raptor, Best Engine Oil Decision [Re: Samrsnow] #5343108 02/06/20 09:59 PM
R
RazorsEdge Offline
R
Originally Posted by Samrsnow
JJack, I see you live in Lafayette. I work at Fournet's Chevron next to Mel's Diner on Johnston. We don't typically handle RP, mostly Chevron, Havoline, Mobil 1 and Castrol Edge. We can see about special ordering you some if you don't just buy the oil/filter yourself and have us change it for a rack charge. Otherwise we can use M1 5W30 and our filter.
M1 runs 12.95/QT Havoline 11.95 and rotations are about 22.50 before tax.
Come by or give us a call, Talk to Dave https://www.fournetschevron.com/
Thanks - Sam
There you go man, service center close by where you're located.
Schaeffer Oil 👍😎
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5343119 02/06/20 10:10 PM
dblshock Offline
0/40...hammer down boy's, let'r go.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: 2018 Raptor, Best Engine Oil Decision [Re: Brian553] #5343153 02/06/20 11:03 PM
M
mpgo4th Offline
M
Originally Posted by Brian553
Lots and lots of options. If you are following a severe service OCI, any synthetic 30 weight should be just fine. Castrol Magnatec and Supertech are an example.
If you are following an extended drain interval, I would pick something at least certed to ACEA A3. Mobil 1 High Mileage 10w-30 is an example.
If the sky is the limit for oil price, I would probably stop myself at something meeting VW 504? Mobil 1 ESP 5w-30 is an example.
You're in Louisiana, so you don't need a 5w-30; I would probably opt for a 10w-30 if the line of oil offers it.
Oh and yes, this question gets asked a lot.
First off, I hope this doesn't come out rude or argumentative. I legitimately want to know what benefits there are to using a 10w30 over a 5w30. It's my understanding that both would act the same a normal operating temp so why worry about the heavier 10 rating at cooler temps? Again I'm asking to understand and learn, not disagree. Thanks.
Re: 2018 Raptor, Best Engine Oil Decision [Re: mpgo4th] #5343254 02/07/20 01:10 AM
J
john_pifer Offline
J
Benefit of a 10W-30 over a 5W-30:
To explain briefly and in basic terms, a 10W-30 will hold up better over time than a 5W-30, especially in TGDI engines.
Multigrade oils use polymers that are like spaghetti in that, when they heat up, the polymeric molecules stretch out. This has the effect of thickening the oil, which allows it to flow well at lower temps, but also to provide good viscosity and protection at higher temps.
A very basic article on VII:
https://www.machinerylubrication.com/Read/29842/viscosity-index-improvers
The drawback is that these polymers get chopped up over time and miles, especially in higher powered engines. That results in viscosity loss.
The greater the spread between an oil’s winter rating and summer rating, the more of these polymer viscosity index improvers (VII) must be used.
Oils that have a narrower spread tend to hold up better over time. They’re more stable, with better Noack volatility ratings. A good, stable oil with a good Noack score is always good, especially for turbocharged engines, and helps prevent coking in the turbo.
And, with the OP being in Louisiana, he’s not typically going to see temps low enough to make a 5W or 0W oil necessary.
Again, I’d suggest Mobil Delvac 1 5W-40 in that engine. Or, if he really wants to stay with a 30W, I’d go with a thicker 30 like the M1 High Mileage 10W-30, Pennzoil Platinum Euro LX 5W-30, or M1 ESP 5W-30. All of those have HTHS of at least 3.5. So, they’ll resist shear and stay in grade in that beast.
It’s a premium truck with a high-performance powertrain. It deserves a great oil.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5343286 02/07/20 03:57 AM
M
metroplex Offline
M
I haven't seen many 5W-30s handle EcoBoost or GTDI engines very well beyond 7500 miles under normal use. Timing chain wear is a big issue that doesn't seem to be shown via UOAs.
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5343287 02/07/20 04:02 AM
W
Ws6 Online Content
Online Content
W
My cx5 is DI and turbo. I use mobil 1 5-30 EP due to dexos gen 2, sn+, ht06, and low Ca. I do oil changes every 5k mi, and use the OEM Mazda JDM made filter.
2019 CX5 Grand Touring Reserve
Re: 2018 Raptor, Best Engine Oil Decision [Re: madeej11] #5343463 02/07/20 09:42 AM
G
Gillsy Offline
G
Originally Posted by madeej11
Was that regular RP or the high performance oil? A very popular choice for the Ecoboost engines is Castrol Magnatec or even QSUD both of which I believe carry the Ford requirements and would be good for a 5k oci.
Magnatec goes into everything I own. I've tried many, but keep coming back to Magnatec. I like the way the engines run.
Many are the afflictions of a righteous man
2019 Nissan Murano S
2018 Gravely ZT HD 52
2016 Kawasaki 650 Versys LT
2012 Mazda 3 Skyactiv 2 ltr
Re: 2018 Raptor, Best Engine Oil Decision [Re: john_pifer] #5343793 02/07/20 03:55 PM
M
madeej11 Offline
M
You talk about a narrow spread being better, then you go and suggest 5w40. Hello.
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5343806 02/07/20 04:07 PM
N
Navi Online Content
Online Content
N
see attached
[Linked Image]
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5344153 02/07/20 10:54 PM
G
Geoff Offline
G
Simple: HTHS 3.5 or above. Pennzoil Platinum Euro 5w-30 Dexos2 rated (Wallmart), Mobil 1 ESP 5w-30 or any other ACEA A3 oil.
2020 Chevy Camaro ZL1 1LE
2019 Jeep JL Wrangler
2015 Audi A3
2013 Chevy Camaro LS3/NPP
2008 Chevy Suburban [sold]
2004 Land Rover Discovery
2007 Supra 22V
Re: 2018 Raptor, Best Engine Oil Decision [Re: madeej11] #5344583 02/08/20 12:59 PM
J
john_pifer Offline
J
An oil having a more narrow spread between the W rating and hot rating is usually an indicator that the oil will have a better Noack score, but it’s not the end-all be-all.
Comparing 5W-30 with 10W-30, in Louisiana climate, yes, I’d pick 10W-30, as I think it’ll hold up better. But I think the Raptor deserves a 40W. And there’s not a full-synth 40W with a narrower spread than 5W-40, to my knowledge.
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5379836 03/18/20 07:32 PM
M
madeej11 Offline
M
Yes John there is. Amsoil Premium Protection 10w40.
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5379889 03/18/20 08:53 PM
B
Black_Thunder Offline
B
Castrol
I'd buy Callahan autoparts if I could.
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5380008 03/19/20 03:31 AM
4WD Online Confused
Online Confused
That’s a power intensive engine (stressed parts) and TDI … so folks don’t need to throw in lube suggestions that are not LSPI formulas. There are some sidetracks in this thread below … but you might pick up a couple nuggets from it
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5224595/1
Re: 2018 Raptor, Best Engine Oil Decision [Re: JJack] #5380010 03/19/20 03:51 AM
O
Olas Offline
O
There is no *best* oil.
If you're on a tight budget then the best oil is the cheapest one
If you race in the desert then the best oil is Redline
If you drive a Cummins with stuck rings the best oil is VPBR
If you live in the Australian outback then the only oil is 40w70
If you work for CAFE then the best oil is 0w8
You just need to pick something appropriate wink
Page 2 of 3 1 2 3
