school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
99 registered members (53' Stude, 28oz, 92saturnsl2, AdditionalD, 6 invisible), 2,313 guests, and 27 spiders.
Topics301,661
Posts5,200,132
Members70,751
Effectively fitting a Roof Rack to an 8th Gen. Corolla ('98-'02) #5342942 02/06/20 06:07 PM
Cdn17Sport6MT Offline OP
Please view the attached graphic... and perhaps magnify it for better review. I refer to the green line... in which I attempt to show that the drip-edge on my Corolla protrudes below the underside of the roof profile where you would hope that it were flat. The roof rack then (if it were flat) would have good, solid "purchase" to a structurally solid part of the roof... and so you could tighten-down the rack with full confidence.
My graphic shows a red cross-section element... added to the "hook adapter leg" of the roof rack... say, with a 'wee bit of vinyl or compressible material on its top, so that it does not grate against the underside of the roof profile on the car. This latter bit of vinyl is NOT shown on the graphic.
Can I ask folks to comment on whether anyone else has had this issue or is worried about the design of the roof (and the rack)... making a roof rack fit poorly or insubstantially? I do note that the types of roof rack that are designed for a car with a drip edge.... do NOT fit the Corolla, 'cuz the gap between drip edge and the rest of the top of the roof profile is so narrow (and they, too, have this SAME problem with the drip-edge protruding below). I could be wrong with this... but this is my impression.
I certainly do note that the red element would have to be a minimal thickness... to JUST allow the green element to clear... lest the door frames foul the hook adapter tower.
Comments, please!
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
Re: Effectively fitting a Roof Rack to an 8th Gen. Corolla ('98-'02) [Re: Cdn17Sport6MT] #5344200 02/07/20 11:49 PM
Bump...
Does no one 'round here have a Corolla of that vintage ('98 - 2002) anymore???
I know, I know... it's off the ark...
Well, I don't drive nearly as much as you 'Mericans....
Re: Effectively fitting a Roof Rack to an 8th Gen. Corolla ('98-'02) [Re: Cdn17Sport6MT] #5345734 02/09/20 10:13 PM
N
nthach Offline
N
Get the right fit kit from Thule or Yakima, it will make things go by a lot easier. Looks like that rack is one of the older Yakima Control Towers that uses the drip rail, you need the Q Towers that uses Q Clips or the Thule/Inno equivalents.
One thing I cannot stress enough with a roof rack is to ensure ALL the tension is equal at the bar to tower interface, since the T-bolt that secures the crossbars is also the the one that controls the clamping force to the roof rails/pillars. Make sure the marks are within a mm of each other.
Re: Effectively fitting a Roof Rack to an 8th Gen. Corolla ('98-'02) [Re: Cdn17Sport6MT] #5345803 02/10/20 12:53 AM
I have a Sportrack that fits a 97 Civic EX 2 door.... possibly the SR1005?. I cannot get the (correct) SR1008 fit-hooks separately. Regardless, that (as it happens to be) plastic drip rail that hangs down (green in the diagram, above) is the point of contact with the fit-hook. Seems 'real insubstantial to me...
Re: Effectively fitting a Roof Rack to an 8th Gen. Corolla ('98-'02) [Re: Cdn17Sport6MT] #5347100 02/11/20 11:49 AM
N
nthach Offline
N
The fit clip(the metal part) looks like a Yakima Q-clip to me but there are differences between the brands. The shape of the metal clips is critical as it will allow the rack towers to sit securely against the body's upper rails/roof pillars and provide the tension to safely allow load.
I wonder if this rack system is a copy of a Thule system?
Re: Effectively fitting a Roof Rack to an 8th Gen. Corolla ('98-'02) [Re: Cdn17Sport6MT] #5347196 02/11/20 01:29 PM
cjcride Offline
Good tips already here.
You may want to check Toyotanation.com
