Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
111 registered members (28oz, apollo18, 2013ecof150, 2012AccentSE, alchargo, Anduril, 5 invisible), 2,357 guests, and 20 spiders.
Topics301,901
Posts5,205,040
Members70,798
Page 1 of 4 1 2 3 4
You have no stash and someone gives you $25 for an OC #5342776 02/06/20 02:46 PM
J
jayjr1105 Online Content OP
OP Online Content
J
What do you buy?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342782 02/06/20 02:50 PM
CharlieJ Offline
Pennzoil Ultra Platinum, $22.97 on Walmart.com right now.
'07 Mazda3 2.3 : Shell Rotella Gas TRUCK 5w-30
'84 Mazda Rx-7 : Valvoline Maxlife 10w-30
Re: You have no stash and someone gives you $25 for an OC [Re: CharlieJ] #5342783 02/06/20 02:51 PM
J
OP Online Content
J
I should have clarified.... you need a filter for that oil change as well don't you?
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342788 02/06/20 02:53 PM
CT8 Offline
The lowest price oil that meets the specs.
2015 F150 2.7
2018 F350 6.2
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342789 02/06/20 02:53 PM
A
ad244 Offline
A
Rotella Gas truck
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342790 02/06/20 02:53 PM
J
JustinH Offline
J
supertech filter and conventional oil.
'16 Ford Escape
'11 Scion XB
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342794 02/06/20 02:57 PM
Bryanccfshr Offline
Depending on the capacity and the vehicle requirements. For a 5 qt or less change I would grab the super tech of the proper spec (Syn, Dexos whatever, samefor filter.
For 5 + to 6 quart the Havoline box of the appropriate spec and a filter and you are still in budget.
Don’t forget to get a proper drain plug washer and replace the old one if the vehicle uses them for the drain plug. most the engine oil drips I see are from bad worn out drain plug washers, and they are cheap.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342801 02/06/20 03:02 PM
J
OP Online Content
J
I'd probably go ST and ST filter and use the extra $6 for lunch
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342804 02/06/20 03:04 PM
B
BAJA_05 Offline
B
Quaker State High Mileage Syn Blend paired with a Fram Ultra at Wally World.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPPP 0W20 & FU (114K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342810 02/06/20 03:08 PM
The Critic Offline
Same. And I would look over the car for any needed work and ask for an opportunity to do those extra items. wink
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342812 02/06/20 03:13 PM
JohnnyJohnson Online Content
Online Content
2004 Corolla 139119
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342813 02/06/20 03:15 PM
2
2000Trooper Offline
2
Walmart supertech. $14 for 5 quarts, OEM oil filter from the dealer for $5, and a few snacks from walmart, or maybe a few of those giant beer cans filled the cheap [censored] for me and the boys to make it more of a hang out.
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342824 02/06/20 03:22 PM
sloinker Offline
Take that $25 and beg on the streets for more money. Ravenol and OE filters.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342828 02/06/20 03:25 PM
Duffyjr Offline
Mech charges $10, with tax I'd have to get ST conventional and no filter, I guess it's better than not changing it!
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: You have no stash and someone gives you $25 for an OC [Re: jayjr1105] #5342842 02/06/20 03:39 PM
slacktide_bitog Offline
PUP and Fram orange can at Walmart
Napa has M1 on sale $5.99/qt, and if you buy 5 quarts, you get a $10 rebate, making it $20
Pair it with a Napa Silver or Proselect to make the $25 quota
Page 1 of 4 1 2 3 4
