I have about 8000 miles on the current oil (mix of Mobil 1 5W-30 EP and Mobil 1 AFE 0W-30). The oil filter is an Amsoil filter with about 14,000 miles on it. The car is a Lexus IS350 (3.5L V6). 6.6 quart capacity, and used about 0.5 quarts over the last 8000 miles.
If it helps, this is the last UOA: https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/download/Number/14654/filename/Untitled.png
Should I keep running the oil out to 15,000 or so miles or should I take it to a quick lube place?
I usually do oil changes myself but I've recently moved and downsized and had to get rid of my jack and much of my tools.
Would it be better to run the oil more or let some monkey touch my car?
