Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
98 registered members (2012AccentSE, alchargo, 28oz, Anduril, 2009Edge, Alfred_B, 7 invisible), 2,287 guests, and 18 spiders.
Topics301,901
Posts5,205,029
Members70,798
What do worn out shocks/struts feel like on a sporty car? #5342657 02/06/20 12:06 PM
B
brages Offline OP
B
I've experienced cars with worn out shocks or struts. Usually this makes for a soft, floaty ride. You go over a bump and the car just keeps bouncing.
What about more sporty cars with firm suspensions? When the shocks are worn out, how would you describe the ride?
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342670 02/06/20 12:27 PM
B
BMWTurboDzl Offline
B
Same as you described.
435i
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342673 02/06/20 12:33 PM
G
GoldDot40 Offline
G
About the same as you would feel with most any vehicle. Almost zero damping effect with little to no control over the spring rebound. Shock absorbers are designed to keep the tire planted to the road surface. Worn/weak shock absorbers will allow the wheel to bounce across bumps. Also upon a hard braking, if the front dives enough to bounce off the bump stops, you can loose brake efficiency because worn shocks and upset weight distribution. Sports car being a little lighter than a sedan or touring vehicle may not have as amplified symptoms, but they can still occur.
Equal Opportunity Offender
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342674 02/06/20 12:35 PM
A
andreigbs Offline
A
Dead shocks result in the wheel on that corner basically bouncing up and down without any control; the spring is doing all the work resulting in that boat-on-a-wave bounce feeling.
You may also hear knocking, especially if the strut mounts are gone as well.
Another sign is the frond end dipping extremely low when applying brakes firmly.
The best I can describe worn out suspension (mainly struts and springs) is loose, bouncy, unsettled.
MB GLK250 Bluetec // 119,xxx miles // 33 MPG // M1 ESP 5w30
BMW X3 x28d // 52,xxx miles // 35 MPG // TBD
Re: What do worn out shocks/struts feel like on a sporty car? [Re: GoldDot40] #5342675 02/06/20 12:38 PM
E
Egg_Head Offline
E
There must be a reason why you're asking this question...
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
1978 K-5 Blazer 400ci
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342715 02/06/20 01:37 PM
H
Hemispheres Offline
H
Floaty ride, car feels like it wants to pop a wheelie under heavy acceleration and also nose dives under braking conditions.
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342745 02/06/20 02:23 PM
Dave9 Offline
They start to ride like not-so-sporty cars.
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342778 02/06/20 02:49 PM
Skippy722 Offline
My 300 has the “performance” suspension, but it’s definitely starting to get a bit soft. Just gets softer and you don’t really notice it till you drive a new one.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342780 02/06/20 02:50 PM
CT8 Offline
Shocks dampen the springs oscillation of the spring
2015 F150 2.7
2018 F350 6.2
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342784 02/06/20 02:52 PM
supton Online Content
Online Content
I remember years ago, I put some Koni adjustable struts onto my Jetta, and i had them set to "pretty stiff". After a month I thought it was fine. Fast forward several years and way more than 100k. Local shop condemns the struts, so I had them replaced--Koni had a lifetime warranty, so I did get the struts back, so as to RMA them. They were truly dead.
But the shop installed my struts as dead soft. ! As a result I couldn't tell the difference in the ride at all. When the OEM's gave up, I could tell the floaty boat on some rough patches of road, but it was pretty infrequent.
I've come to the conclusion that I can't tell good from bad struts. shrug
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342806 02/06/20 03:04 PM
U
UncleDave Offline
U
bouncing, floating, and bump steer all combined....
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342811 02/06/20 03:10 PM
P
Pew Online Content
Online Content
P
Extremely harsh ride. The evo right now has blown struts on lowering springs and the ride is very harsh with zilch dampening.
Re: What do worn out shocks/struts feel like on a sporty car? [Re: Pew] #5342880 02/06/20 04:49 PM
U
UncleDave Offline
U
"Blown" feels like riding on a bicycle rim with a flat tire.
UD
Uncle Dave
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5342886 02/06/20 04:53 PM
1
1978elcamino Offline
1
Think of your cars ride as a bobble head.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: What do worn out shocks/struts feel like on a sporty car? [Re: brages] #5343022 02/06/20 07:14 PM
J
joekingcorvette Offline
J
It depends on the car. I had an 87 Corvette that I thought rode a little rough and maybe needed new shocks. I spent a lot of money on brand new
shocks on all 4 corners and I couldn't tell the difference. I think the shocks would have to be terrible to tell the difference on a sports car that takes corners well.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
