Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
38 registered members (BlueOvalFitter, Blkstanger, Aichiguy, 97prizm, 74Widebody, 2 invisible), 1,058 guests, and 20 spiders.
Topics301,812
Posts5,203,170
Members70,784
My Wife's Flight This Morning had Lightning Strike & Engine Failure !! #5342586 02/06/20 10:18 AM
L
LoneRanger Offline OP
L
Few hours ago, American Eagle (American Airlines) flight # 4719 Evansville IN to Charlotte NC. She says about half hour or so shy of arrival to Charlotte, super loud bang and bright flash shook plane. Lots of turbulence. On the ground they see fire trucks approaching the aircraft, lights on. Flight crew then announces that the loud bang and flash in flight was a lightning strike that caused an engine failure. Other flights have been grounded at Charlotte due to the weather and incoming flights cancelled at departure airports destined for Charlotte. Aircraft was likely a CRJ 200 or variant, as that's what American tends to fly out of Evansville.
'19 F-150 2.7 twin turbo DI V6 .....(Motorcraft synblend 5W30 SN+)
'19 GMC Terrain 1.5 turbo DI I4....(Warren 0W20 1DexosGen2)
'16 Moto Guzzi NTX 1151cc v-twin (Eni 10W60)
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342590 02/06/20 10:25 AM
FowVay Offline
We've been hammered all morning here in Atlanta with heavy rain and wind. I'm glad that the flight ended safely for your wife. It's going to be a long day for us.
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342591 02/06/20 10:26 AM
c502cid Offline
Just checking Flightaware it shows it took quite a few turns to move around the storms. Still arrived early though. Was an Embraer ERJ-145.
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342640 02/06/20 11:37 AM
L
L
I should've noted in OP that they did land without any drama.
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: FowVay] #5342649 02/06/20 11:57 AM
B
BMWTurboDzl Offline
B
Yep. Just dropped my wife off at Hartsfield. Her outbound flight has been delayed 3 hrs already.
435i
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: BMWTurboDzl] #5342725 02/06/20 01:51 PM
F
ffhdriver Offline
F
Several years ago my wife and I were on an Orlando to Atlanta flight that was hit by lightning. There was a loud noise and a bright light inside the plane which got everyone's attention. Pilot told us there were no problems.
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342732 02/06/20 02:05 PM
K
kschachn Offline
K
Much of the time when a transport category airplane is hit by lightning neither the passengers nor the pilot know it happened. It is later discovered by maintenance during an inspection through burned rivets and tracks. Only the large hits are noticed.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342739 02/06/20 02:18 PM
G
gman2304 Offline
G
I’m an hour North of Charlotte and it’s been raining buckets with high winds, lightning, and thunder all day.
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342756 02/06/20 02:32 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I just studied a case where a helicopter crashed in flight. Investigation showed the helicopter was struck by lightning while on the ground before the flight. The lightning damaged some powertrain components.
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342769 02/06/20 02:42 PM
A
Alfred_B Offline
A
Lucky it was the end of the flight and the communications were not fried. Last year there was one in Russia where the plane got struck a few minutes after takeoff and which fried the electronics. No way to tell ground of the problems and a very bumpy landing after returning to the airport. The plane bounced 3 times, I think and then caught fire.
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342777 02/06/20 02:47 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
50 years ago I toured Jackson airport (small aircraft). They mentioned a backup system where the tower would communicate with aircraft using a blinking light beam.
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342876 02/06/20 04:35 PM
R
ragtoplvr Offline
R
I used to lighting test our equipment, not aircraft. Great fun. Such memories.
Cut our warranties WAY way down. But in the end, if lighting want to win it will.
Rod
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5342983 02/06/20 06:37 PM
J
JC1 Offline
J
Thank goodness! I'm sure she was frightening when that happened. Kudos to the pilots for landing safely.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5343302 02/07/20 04:04 AM
dlundblad Offline
Good thing she made it drama free.
Oh the beauty of a twin engine aircraft. Lol
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: My Wife's Flight This Morning had Lightning Strike & Engine Failure !! [Re: LoneRanger] #5343475 02/07/20 09:02 AM
L
L
