Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
23 registered members (Brian553, Donald1953, BlueOvalFitter, c502cid, ctechbob, bbhero, 1 invisible), 1,088 guests, and 16 spiders.
Topics301,932
Posts5,205,745
Members70,801
2015 Subaru Forester 2.5i Dealer 0w20 M1 #5342455 02/06/20 06:31 AM
R
ryan2022 Offline OP
R
Hi folks! This is my first UOA on our 2015 Forester. The vehicle has 72,000 kilometres (44738 miles), and the oil was drained at roughly 8 months and 7400 kms. (4598)
A mix of highway and stop and go/ short trip driving. The fuel was expected, probably contributing to the lower flash point. But otherwise a good reading as far as I can tell. I'n an attempt to green up our cars, we're aiming for 1 year or 10-12k kms. Roughly (6-7k miles)
Thanks for your time.
Ryan
Subaru 2.5L (FB25) DOHC
Mobil 1 0W/20 7,450 KM @ 8 month OCI
0 qts makeup
OIL TYPE & GRADE: Gasoline (Unleaded)
RYAN: Your Outback's engine is standing up to the stop-and-go use and cold winters, no problem. You can see typical 2.5L Subaru engine wear after ~10,000 km of oil use in the right column. Your metals are at about the same levels, and average wear is nice to see from pretty much any engine, so no problems are suspected for wearing parts. There's a little fuel, but 1.0% is most likely from normal use, like idling in the colder weather, for example. The TBN shows active additive remaining in the oil with a solid reading of 4.5 (1.0 is too low). Try 10,000 km next time.
MI/HR on Oil
7,450 MI/HR on Unit 71,900 1/20/2020
Attached PDF document
2011 Subaru Impreza Hatchback 5w30 Mobil 1
2015 Subaru Outback 2.5 Limited 0w20 Mobil 1 AFE
1995 Nishiki Navajo mountain bike....some kind of chain oil.
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5342464 02/06/20 06:41 AM
I
Imp4 Offline
I
Hey OP, you'll probably want to remove your personal information from the attachment.
A moderator can help if you can no longer edit the document.
Also, the UOA looks fine. Keep on motoring!!!
cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5342473 02/06/20 06:49 AM
Donald Offline
I would go between 6000 miles and 7500 miles OCI on my two (now one) Subaru vehicles.
I was using NAPA brand synthetic oil (on sale) 0W20. I do not think the engines are too demanding.
Your UOA looks fine. But it should using Mobil1 and under 5000 miles.
2015 Ford F-250 w/Powerstroke
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5342476 02/06/20 06:54 AM
R
ryan2022 Offline OP
R
Thanks guys! I wondered about that personal info. I'll ask on of the moderators to help me out.
I'm happy with it. Viscosity looked good, as did the wear metals. I went with a relatively standard Mobil 1 for the current change in the 0w20AFE. I'm thinking its similar to what was in this sample.
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5342525 02/06/20 08:17 AM
A
ARCOgraphite Offline
A
I've Been running 9+k mile (15k kms) OCI with LOWER wear than average.
changing a synthetic at 5-6k is way, way too short.
If dealer balks, show them the UOA.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5343352 02/07/20 06:20 AM
I
IMPALA08 Offline
I
What oil filter did you use?
2015 Subaru Forester 2.5 premium
2015 Vw jetta SE 1.8T
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5343373 02/07/20 06:48 AM
A
aquariuscsm Offline
A
Is this M1 afe in bulk form? Did you add a molybendum additive? Afaik,all M1 oils have around 70-80 ppm of molybdenum. Good looking uoa!
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5345114 02/09/20 07:50 AM
I
IMPALA08 Offline
I
I have the same car. I did uoa just before it came out of warranty at 5 months and about 4300 miles. Nothing out of the ordinary from black stone. They recommended going to 6000 And test again. I’m shooting for 8000 miles. But before that the CVT had a catastrophic failure, replaced under new 10yr/100000 mile warranty.
Presently in the car 4 qts M1 0w20 and 1 qt Ow40, that’s what was left in the stash. Car runs very smooth, and quiet
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: IMPALA08] #5345195 02/09/20 09:49 AM
T
Triple_Se7en Offline
T
Members here say Blackstone's reading of fuel dilution is far-from-ordinary. You may have high fuel dilution and Blackstone may not have flagged it.
Can you post your UOA here?
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
04' Chevy Colorado Castrol 0W40 & Wix
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5346059 02/10/20 10:44 AM
W
wdn Offline
W
The 2015 appears to be the last problem year for the Subaru CVT, good thing Subaru stepped up and offered the extended warranty. Had you ever changed CVT fluid on yours that failed? I am glad Subaru fixed the issue on the newer models.
Re: 2015 Subaru Forester 2.5i Dealer 0w20 M1 [Re: ryan2022] #5346135 02/10/20 12:03 PM
I
IMPALA08 Offline
I
I changed my CVT fluid at 30,000 miles with Castrol
