Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
109 registered members (28oz, apollo18, 2013ecof150, 2012AccentSE, alchargo, Anduril, 5 invisible), 2,296 guests, and 19 spiders.
Topics301,901
Posts5,205,040
Members70,798
Page 1 of 3 1 2 3
Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic #5342451 02/06/20 06:24 AM
N
Navi Offline OP
N
$22 at Walmart
The Blackstone report highlights the difference between the 0W30 and the 5W30.
[Linked Image]
[Linked Image]
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342492 02/06/20 07:21 AM
Snagglefoot Offline
Thanks for the post and for paying for the VOA. I have it in my Burb with a 6.0.
It does a cold start every afternoon using the remote starter. Lowest temp this January was -24 C. 5w30 would suffice, but this was a touch thinner at that temp. smile
If you want the job done right......do it yourself.
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342496 02/06/20 07:26 AM
D1dad Offline
I have several qts of this to use up in an 08 impala. Is the moly being so low a concern?
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: D1dad] #5342526 02/06/20 08:18 AM
K
kschachn Online Content
Online Content
K
If it carries a needed specification or approval, why would the composition be a concern?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342543 02/06/20 09:10 AM
B
BMWTurboDzl Offline
B
Has anyone asked BS is they can test for the additives used in ACEA CX oils which are used in lieu of what is commonly found in ACEA Ax/Bx?
435i
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342558 02/06/20 09:28 AM
A
andreigbs Offline
A
+1 on thanks for paying to do a VOA on this oil. I'm planning to switch to it next OCI.
MB GLK250 Bluetec // 119,xxx miles // 33 MPG // M1 ESP 5w30
BMW X3 x28d // 52,xxx miles // 35 MPG // TBD
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342594 02/06/20 10:34 AM
c5z06 Offline
When I pull up the PDF to look at the KV @ 100*C it shows 13. How old was the oil that was tested ?
https://www.shell-livedocs.com/data/published/en-US/635c2f18-190e-435b-b7cc-a291201ed641.pdf
[Linked Image]
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342608 02/06/20 10:49 AM
A
andreigbs Offline
A
Based on Blackstone's report, the [email protected]*C is 12.38 which you could call 12.4 and flashpoint of 470*F or 243.3*C.
I don't see either of those value differences, compared to the PDF, as significant.
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: andreigbs] #5342611 02/06/20 10:53 AM
K
Online Content
K
Yes, flashpoint determination is very subjective and has a high repeatability value per the ASTM procedure. It also doesn't have much relevancy for oil service.
1994 BMW 530i, 252K
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: kschachn] #5342635 02/06/20 11:34 AM
I
Imp4 Offline
I
Because moly...
Some people are just insistent on it. Which never really made any sense to me.
Why is it that this anti wear additive is the one that many people focus on?
My question is not pointed at D1dad in particular but this example just highlights the phenomenon.
For those out there that would make a comment like this, can you please enlighten me?
Thanks!!!
cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342659 02/06/20 12:14 PM
O
OilUzer Offline
O
What other specs does Euro meet over regular PP 5W30?
Is this for diesel engines?
I started seeing Euro L in local WM recently.
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342671 02/06/20 12:29 PM
A
andreigbs Offline
A
Yes, the Euro L applies to modern diesels as well as gas engines. Here are the relevant specs:
- BMW LL-04
- MB 229.31 and 229.51
Note that there is an additional product called Euro LX (a 0w30) which carries these specs:
- MB 229.31, 229.51, 229.52
- VW 504/507
- Porsche C30
Some might say the LX is an even better oil, it certainly is harder to find. You can generally find the Euro L on the shelf at Wal-mart.
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342701 02/06/20 01:22 PM
sohccammer427 Offline
At one time there were three flavors available:
Euro L 5w30 is Dexos2 but has no VW approvals.
Euro LX 0w30 is VW 504/507 but no Dexos 2
Euro AV 5w-30 is VW 502.00/505.01/505.00
Not sure what that's all about.
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342703 02/06/20 01:26 PM
Snagglefoot Offline
Euro L 5w30
Re: Pennzoil Platinum Euro L 0W-30/5W-30 Full Synthetic [Re: Navi] #5342704 02/06/20 01:28 PM
Snagglefoot Offline
Euro LX 0w30
Page 1 of 3 1 2 3
