5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Need help d/l'ing vids from JVC GZ-MG27
by daves66nova - 02/26/20 10:18 PM
Need a riding mower
by FirstNissan - 02/26/20 08:32 PM
Just bot Quicken 2020 Premier for
by Ed_T - 02/26/20 08:31 PM
Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
28 registered members (Capt, bworley, blufeb95, carlprop, ArrestMeRedZ, 90Notch, 3 invisible), 1,262 guests, and 18 spiders.
Topics301,966
Posts5,206,599
Members70,808
ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? #5342187 02/05/20 07:41 PM
Chipdumper Offline OP
After about 6k miles I noticed my oil pressure would hold at about 22 PSI. I'm too busy to change the oil so I rolled with it until I changed the oil and about a week ago (1/29) and the oil pressure has been holding steady at 38-40 PSI. What is going on here? Why did I lose oil pressure after only 6k miles? I drive 130 miles roundtrip to work 7 days every two weeks. I'll try to post photos of the filter cut open as soon as I bring my cutter home from the hangar.
History:
1/22/2019 OIL CHANGE. Fill 6qt Mobil 1 5W-30 Synthetic, Wix filter 57060XP. 92,982
4/1/2019 OIL CHANGE. Fill 6qt Amsoil 5W-30 Synthetic, ACDelco filter UPF48R. 99,210
7/9/2019 OIL CHANGE. Fill 6qt Amsoil 5W-30 Synthetic, ACDelco filter UPF48R. 107,519
10/19/2019 OIL CHANGE. Fill 6qt ACDelco Dexos1 Gen2 5W-30 Synthetic, ACDelco filter UPF48R. 116,663
1/29/2019 OIL CHANGE. Fill 6qt Amsoil 5W-30 Synthetic, ACDelco filter UPF48R. 125,128
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342197 02/05/20 07:52 PM
Superflan Offline
Hi, welcome to BITOG smile
I think it could be a viscosity drop causing the oil pressure to get down. Maybe fuel dilution or something else.
And you made a typo writing the last date
‘01 Peugeot Partner 1.9 D, 15W40 E7, 273000 Km, running on WVO
Wife's '19 Suzuki Vitara 1.0 Boosterjet (TGDI), 5W40 A3/B4, 23000 Km
Backup ‘01 Toyota RAV4 3-dr 2.0 VVTi, 5W40 A3/B4, 170000 Km
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342210 02/05/20 08:09 PM
CT8 Offline
What vehicle and what was the care before the listed oil changes?
2015 F150 2.7
2018 F350 6.2
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342216 02/05/20 08:16 PM
Z
ZeeOSix Offline
Z
At idle? ... with the oil at the same exact temperature?
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342249 02/05/20 08:45 PM
Thanks for the typo alert; i just fixed it in my overall spreadsheet. I bought it used on 1/21/2019 from the second owner (old man; retired Lineman) who bought it in 2011 from Enterprise rental when it had about 17k miles. Thats the PSI at cruise 63MPH. Due to the AFM issues I did the software AFM delete (via HP Tuners) and also installed a catch can. I trap a TON of water! About 3-4oz of water-oil emulsion every 1000 miles or so. If I let it sit for a few days the water separates from the oil and it drains clear for several seconds lol. I have to use a coffee can to catch it its so much and just installed a ball valve drain...
[Linked Image]
[Linked Image]
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342268 02/05/20 09:17 PM
Snagglefoot Offline
If you see an emulsion in the oil filter you may have a coolant leak. Let us know. I take it you have a 5.3. The oil pressure gauge is at the top of the engine, driver’s side. Any plugging of the oil filter will cause an oil pressure drop at the sensor until it’s bad enough to open the bypass on the filter.
If you want the job done right......do it yourself.
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342286 02/05/20 09:55 PM
J
jhellwig Offline
J
The oil pressure sensors in those years like to go out. They are ever so fun to replace. There is also a screen under the sensor.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342288 02/05/20 10:01 PM
clinebarger Offline
Quick to blame the filter aren't we??
The only way to prove you theory is to hook up 2 pressure gauges & measure the Pressure delta across the filter, This also assumes the Bypass Valve in the filter failed as well.
1st pic....Pre filter tap. 2nd pic....Post filter tap.
The post filter tab is actually behind the block-off plate above the filter, I find it easier to find a extra block-off plate & drill/tap it to 1/8" NPT for the gauge whip.
Same for the pre filter tab.....Find an extra plug & drill/tap it.
[Linked Image from i.imgur.com]
2001 Chevy Camaro L92/4L80E
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: jhellwig] #5342290 02/05/20 10:09 PM
clinebarger Offline
Yes sir....The 3-wire, 5-volt referenced, Oil Pressure transducers are highly suspect, But the normal mode of failure is internal short to 5-volt making the gauge peg at max pressure. Scan data will read @140 psi with the key-on engine-off.
AFM engines have the screen.
I've installed hundreds of UPF48R filters over the years & have yet to have an issue with one.
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342325 02/05/20 11:22 PM
L
Linctex Offline
L
Chris, What kind of LS-swap are you working on?
I do not recognize that red aftermarket K-member and the front suspension.
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5342341 02/05/20 11:52 PM
clinebarger Offline
Those pic's are of my 2001 Camaro, During the 5.3L to 6.2L swap......Spohn is who fabricated the K-member, Car started life as a 3.8L V6 car hence the need for a V8 K-member. I actually wanted a stock one but couldn't find one in good shape.
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: clinebarger] #5343050 02/06/20 08:04 PM
Well after I changed the oil and filter the low pressure problem went away so its either the UPF48R filter or the ACDelco Dexos1 Gen2 5W-30 Synthetic oil. I'll cut open the filter and see if anything is obvious. I haven't seen such low pressure during the previous OCI's. I suppose it could get interesting in the next couple months; I drive about 3,000-3,300 miles a month. I'll report back.
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Snagglefoot] #5343055 02/06/20 08:08 PM
I do have the 5.3. The manufacture date code was a mere few weeks before GM made the change to the PCV input into the left valve cover (the incorporated a spray shield of sorts inside the valve cover). No coolant loss obvious on the dipstick or coolant reservoir tank. Engine runs excellent. I've never had any warning lights regarding the pressure; just a constant 20+ PSI noticed when at 60ish MPH on my way to work.
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5343401 02/07/20 07:31 AM
T
tundraotto Offline
T
Maybe filter was plugged and/or sludged, and filter bypass could not keep up?
Re: ACDelco UPF48R Ultraguard failure: low oil pressure after about 6k miles? [Re: Chipdumper] #5343515 02/07/20 09:40 AM
F
Farnsworth Offline
F
What is the engine temp? It looks like you need engine repair. Water in the oil would cause the oil pressure to drop. The previous owner had it stock and apparently everything was fine the 75k he drove it. So you read on the internet AFM has problems and assumed you have problems? It isn't the oil or filter you just proved it with the new change.
