1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
26 registered members (Best F100, 53' Stude, Amenhotep, Aichiguy, Bjornviken, 5 invisible), 1,200 guests, and 18 spiders.
Topics301,933
Posts5,205,755
Members70,801
QSUD 5W-30 no longer HTO-06 rated #5342178 02/05/20 07:27 PM
K
kstanf150 Offline OP
K
Just recently bought a Lincoln MKC with the 2.0L turbo and was looking at oils with the HTO-06 spec. Not sure if the Honda spec is even relevant nowadays with modern oils, but noticed that QS no longer list it on their labels. Castrol and M1 still do.
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342198 02/05/20 07:54 PM
R
Rand Offline
R
Is that a direct injection only T-GDI engine?
I'd be looking for dexos 1 gen 2, api sn+ and other turbo engine certs such as jeep ms-13340.
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342200 02/05/20 07:55 PM
B
bbhero Offline
B
Yeah strange they don't mention it while Castrol and Mobil 1 do...
Given the HTO-06 is a old test.... One would think given the increased presence of turbo boosted motors. HTO-06 would be a good test specification to pass.
The Cam2 Dexos1 Gen 2 full synthetic oil I am running mentioned being HTO-06 approved.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342217 02/05/20 08:16 PM
CT8 Offline
Dexos1 Gen 2 full synthetic oil is probably a much more severe rating.
2015 F150 2.7
2018 F350 6.2
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342225 02/05/20 08:22 PM
W
wdn Offline
W
Don’t know about the missing certification, but the marketing blather on that label is hilarious.
Re: QSUD 5W-30 no longer HTO-06 rated [Re: wdn] #5342230 02/05/20 08:26 PM
SteveG4 Offline
Marketing WORKS (except with certain BITOG'ers)! smile
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: QSUD 5W-30 no longer HTO-06 rated [Re: CT8] #5342236 02/05/20 08:29 PM
K
K
That’s my thinking as well.....not gona lose sleep worrying about it.
Thanks CT8
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342243 02/05/20 08:40 PM
G
Gokhan Offline
G
That's because Honda/Acura HTO-06 (hot-tube oxidation '06) is an obsolete spec that was introduced in 2006 before API SN Resource Conserving/ILSAC GF-5 that tests for turbocharger deposits was introduced in October 2010. dexos1 Gen 2 that was introduced later is a far more strict spec for turbocharger deposits, which is what HTO-06 is about.
Honda oil specs explained (PDF)
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 4,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342244 02/05/20 08:40 PM
B
bbhero Offline
B
Actually I disagree...
The HTO-06 is actually a test that tests something Dexos Gen 2 does not.
Re: QSUD 5W-30 no longer HTO-06 rated [Re: bbhero] #5342252 02/05/20 08:49 PM
G
Gokhan Offline
G
See the presentation I posted. The only thing HTO-06 checks for is turbocharger deposits.
Honda/Acura HTO-06 was introduced in 2006 (hence the "hot-tube oxidation '06" test) before API oils started checking for turbocharger deposits with ILSAC GF-5/API SN Resource Conserving in October 2010. It has now become obsolete -- no new turbocharged Honda/Acura engine specs HTO-06 as far as I know. In fact new Honda/Acura vehicles simply spec API SN oils, which seem to meet the turbocharger-deposit requirements of HTO-06 oils back then. dexos1 Gen 2 is even more strict than API SN Resource Conserving for turbocharger deposits, and it's certainly superior to HTO-06.
Re: QSUD 5W-30 no longer HTO-06 rated [Re: Gokhan] #5342270 02/05/20 09:21 PM
B
bbhero Offline
B
And given turbos being a lot more on use now... Other then being a "old" test but still applicable today. More so than ten years ago...
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342369 02/06/20 02:05 AM
B
Bjornviken Online Content
Online Content
B
never seen a HTO-06 in viscosity 0w-30
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342372 02/06/20 02:16 AM
G
GMBoy Offline
G
I've been running QSUD 5W/30 in my Hemi Ram because it meets the Chrysler MS-6395 spec and it's about $5 less than Mobil 1 at Walmart.
Do you all think QSUD is equivalent to regular Mobil 1?
Re: QSUD 5W-30 no longer HTO-06 rated [Re: GMBoy] #5342447 02/06/20 06:14 AM
K
K
Absolutely, for the buck QSUD is a very good oil
Re: QSUD 5W-30 no longer HTO-06 rated [Re: kstanf150] #5342465 02/06/20 06:42 AM
R
Richie Offline
R
Good to hear as I just bought some for my daughters Honda CRV and my Lexus CT200H
